Question about Akai Mpc1000 128mb Ram Expansion System
RAM MEMORY SLOT EARS BROKE OFF--MPC2500
I NEED TO REPLACE THE RAM MEMORY CARD SLOT IN MY MPC2500. DOES THE SLOT JUST SNAP IN AND OUT. I CAN BUY ONE OFF OF THE INTERNET BUT IF THERE IS ANY SODDERING INVOLVED IM NOT GOING TO FIX IT MYSELF. IS THIS PIECE EASILY REPLACED?
    Problem Solver:
  • 13 Answers
Replacing the slot on your machine will no only include soldering, but you're talking about soldering AT THE VERY LEAST 168 connections. When a slot goes bad, it is not deamed a "repairable" situation. The best solution, unfortunately, is to replace the motherboard and salvage the processor, ram, etc.
Cheers!
-E
Posted on Mar 05, 2009
Ram not working
Step 1:
A memory slot is a slot in your motherboard where you place your RAM (Random Access Memory) card. In layman's terms, the RAM is the "temporary memory" that the computer utilizes whenever it is turned on. If the computer cannot detect a RAM card installed in one of your memory slots, you have to troubleshoot the problem immediately.
Ensure that the problem is with the RAM slot and not the memory card. Turn off the computer, unplug all devices connected into the ports of your computer and open the computer casing. Refer to the manual of the computer to know the specific steps to follow in opening the computer casing. Remove the memory card from the RAM slot. To do this, unlock the card using both hands. Pull the card away from the slot to remove. Inspect the RAM card for any apparent physical damages. Wipe the card with a clean cloth to remove dust. Also wipe the memory slot in your motherboard. Place the RAM card back into the memory slot. Press the card into the slot until it clicks into place. Close the computer casing, connect the cables back into their respective slots and turn on the computer. Turn on the computer and see if the memory is detected. If the computer does not boot up, the RAM card is not detected by the computer. Assuming that you have two memory cards installed in the computer and the computer boots up, check if the second memory card is detected by the computer. Click "Start," right-click "Computer" and then "Properties." Under "System," check the amount of "Installed Memory (RAM)." If the RAM is not detected, the RAM slot or the RAM card itself may be malfunctioning. Place the RAM card into another memory slot in your motherboard and see if the card is detected. If it is detected, the other memory slot is malfunctioning. Do not install any RAM card into it to avoid further damage. If it is not detected, the RAM card may be malfunctioning. Insert another RAM card into the slot. If the RAM card is detected, the slot is malfunctioning.
http://www.youtube.com/watch?v=wGp5AiyJInI repair memory slot
Feb 23, 2013 | Computers & Internet
Can I upgrade the video card on a Gateway E4300 to work with Shader 3 graphics (Eve Online)? Or do I have to buy a new computer?
You only really need to upgrade the video card and the PSU (most video cards need more power than what most companies like dell and gateway provide.). So no need to buy a new computer.
Mar 22, 2011 | Computers & Internet
Does not recognize ram after removing and reinstalling
Try to insert the memory/ram into other memory slots on the computer. Also, try to get an eraser and erase the part of the memory that is being inserted. If it still does not recognize it, then you may need to replace the memory.
Aug 05, 2010 | HP Compaq dc5750 PC Desktop
MEMORY/RAM problem, system won't acknowledge both slots of memory
You might have on-board VGA card which take 8 Mb (shared) in memory taken from extended memory card.
My suggestion, use exactly similar memory card ( same PC clock, either 400/533/667/etc. If this won't work, try to clean the memory slots with brush.
Apr 10, 2010 | Computers & Internet
I want to install 1GB of memory. I need step by step directions
Remove side of PC (left hand as you look from front) locate memory slots, make sure retaining clips are open, insert memory (correct way up) with firm pressure but do not force. Retaining clips will automatically click home. Replace side of PC.
Sep 07, 2009 | Gateway 310 XL (310XLSP) PC Desktop
RAM Beep error on HP Laptop
yes you buy a new one ram install it then solve this problem
Aug 27, 2009 | HP Pavilion dv6000z Notebook
E Machine T6528
open up the side door before you do anything else. Look for a stick or RAM that looks like the one your going to be putting in. When you find the extra slot that the RAM is going in, your going to find two latches one on each side of the RAM slot. The memory itself is slotted meaning it can only go in one way. Put the memory in and line up the slot with the hold on the bottom of the RAM. It should snap into place and the latches will hold the memory into place.
As far as the video card is concerned, its going to go into a long white slot, it also can only go in one way, the metal part of the card will face the outside of the back of the computer and the card will snap into place. After you do this you might need to have to put a screw into the metal slot of the video card to keep it in place.
At this point you can hook up the monitor to the external video card and the thing you might have to do is install the drivers for the video card when you get into windows. It might not detect the video card properly which is why you might have to intstall the software for it.
Also do the memory first to make sure the computer sees it and boots up. If it does then turn the computer off and then do the video card. That way if there is a any problems it will be easy to figure out where the problem is right away.
Jun 21, 2009 | E-Machines T6528 PC Desktop
How do you install ram in a toshiba a105-s4344 laptop
I take it that you already have the correct RAM you need. Wiith that, power off your notebook, unplug it, turn it over and your will see the larg cover closer to the right of the notebook. Unscrew the screw to release the memory cover and place it to the side. Be carefull with static when handling your memory card, install the card into any open slot in your notebook. (The memory card will go in the slot at a 40 degree angle and then 'snap' down into place. Replace the memory cover (the large piece you took off at the begininig.) power up you notebook and the new memory should be registered and ready for use. Good Luck.
Feb 02, 2009 | Toshiba Satellite A105 Notebook
Adding memory to Toshiba A75-S211
you buy the memory here for a great price or anywhere online instructions are on the page
it replaces the 512
http://cgi.ebay.com/1GB-DDR-333-for-Toshiba-Satellite-A75-S211-Memory-RAM_W0QQitemZ250353026446QQihZ015QQcategoryZ158897QQssPageNameZWDVWQQrdZ1QQcmdZViewItem
  • Memory Card for Toshiba Satellite A75-S211 Memory RAM- Designed and Optimized
  • Toshiba Satellite A75-S211 Memory RAM Memory Upgrade -Easily installed
  • More Memory Equals - More Speed for your APPS
  • The Toshiba Satellite A75-S211 Memory RAM has a memory card slot or slots, that allows you to add more memory to your Toshiba Satellite A75-S211 Memory RAM, giving you enhanced performance and speed. You will see the Immediate speed increase in your computers performance.
    Stop waiting for programs, and functions to happen, STOP WAITING!!! Start enjoying technology as you should.
    We work directly with our memory card manufacturer to insure perfect compatibility with the Toshiba Satellite A75-S211 Memory RAM. Only using the highest quality memory chipsets for our memory cards, so you are assured compatibility and performance. All of our memory cards are Designed and Optimized for Toshiba Satellite A75-S211 Memory RAM . Technical specialists have personally verified our memory cards compatibility with the Toshiba Satellite A75-S211 Memory RAM.
    Worry Free Installation: Just Follow these Steps Desktop and Laptop instructions below.
    Desktops
    1. Unplug Power cable
    2. Remove Case
    3. Slide memory card in Open slots- the memory card will only fit in one way
    4. Snap the side clips in place
    5. Close Case and Power Up
    6. You are ready to go.
    Laptop
    1. unplug and remove Battery from laptop
    2. Open memory compartment on bottom using Philips screw driver
    3. inset memory in open slot, if no open slot remove current memory by pinching metal clasp on side of memory
    4. Close compartment and power up you are off and running.
    Jan 26, 2009 | Toshiba Satellite A75-S211 Notebook
    Wi-fi ability lost with RAM upgrade
    It is possible that the WiFi card was dislodged or inadvertently snap out of position. Should you venture on a DIY, pls remove the bottom panel covering the memory and/or add-on cards. The WiFi card would be the one with one or two black or gray small cable/wire with connectors at the end. Unsnap the said WiFi card, partially remove/pull from the slot, re-insert and snap back. It may be necessary to wiggle a little bit to ensure that the pins are in contact with the corresponding slot pins. Thereafter, close the lid/panel cover and reboot the laptop.
    Should problem persist, you may need to return the unit to whoever replaced the memory and present your concern.
    Hope this be of initial help/idea. Pls post back how things turned up or should you need additional information.
    Good luck and kind regards.
    Thank you for using FixYa.
    May 04, 2008 | Toshiba Satellite A60 Notebook
    275 people viewed this question
    Top Akai Audio Players & Recorders Experts
    Michael Harrier
    Vernon Taylor
     Grubhead
    Grubhead
    Are you an Akai Audio Player and Recorder Expert? Answer questions, earn points and help others
