Question about Brother HL-2040 Laser Printer
Dr 360 reset procedure
Does anybody knows how to reset the drum unit dr 360?
Thanks,
Sergio
email:bulktoner@yahoo.com
  • 5 Answers
1. The Drum LED blinks if the drum unit is near the end of its life. Use the drum unit until
you have a print quality problem, then replace the drum unit with a new one.
2. The Drum LED continues to blink if the drum counter was not reset when you replaced
the drum.
To reset the drum follow the instructions below:
a. Open the front cover of the printer.
b. Press and hold down the white button (shown as blue in the image below) for
about 4 seconds until all the LEDs light up. Once all 4 LEDs are lit, release the
button.
c. Close front cover
Posted on Dec 10, 2009
03130031-2F52 error
my printer suddenly stopped working and is showing the following error code 03130031-2F52. If anybody know how to fix it, please email me at alaevphoto@yahoo.com. thank you.
Oct 21, 2012 | Canon imagePROGRAF iPF8000 Printer
I replaced my drum and the output quality is poor and light in areas
did you clear the required counters and run required procedures? If not the machine still thinks it has a old drum because counter was not cleared only way copier will know it has a new drum
Mar 23, 2012 | Brother DCP 8060, 8065DN, HL 5240, 5250DN,...
Drum end soon
Sounds like you need to replace the drum unit soon. Here is a new one that you can buy that is compatible with your printer: http://www.amazon.com/Brother-DR360-DR-360-Drum-Unit/dp/B001QTY5QE/ref=sr_1_9?s=office-products&ie=UTF8&qid=1305153837&sr=1-9.
May 11, 2011 | Brother MFC-7340 All-In-One Laser Printer
Error and drum lights are blinking i dont know what to do
First clean the corona wire. Next check for a paper jam. The drum is possibly at the end of life; the drum is part DR-360.
To clean the corona wire, remove the drum and toner assembly from the unit and gently move the green tab from right to left and then left to right several times. Return the tab to the home position before returning the unit to the printer. See http://welcome.solutions.brother.com/BSC/public/us/us/en/faq/faq/000000/000200/000008/faq000208_021.html?reg=us&c=us&lang=en&prod=hl2170w_all&Cat=7 for pictures.
To replace the drum, slide the drum and toner assembly out of the printer. Push down the green lever to unlock the toner cartridge and take it out of the drum. Unpack the new drum. Put the toner cartridge in the new drum. The green lever should lift automatically if you have the cartridge fully installed. Return the assembly to the printer. Then reset the drum counter by pressing and holding the white button until all 4 LEDs light. Then release the button. Finally close the front cover. Check that the Drum LED is off. For pictures, see http://welcome.solutions.brother.com/BSC/public/us/us/en/faq/faq/000000/000100/000054/faq000154_036.html?reg=us&c=us&lang=en&prod=hl2170w_all&Cat=7
I hope this helps.
Jun 11, 2010 | Brother HL-2170W Laser Printer
Dr-360 mfc drum reset
Brother MFC-7345n. DR-360 With power on and door open hold down the Clear/Back button. When asked new drum 1 for yes and 2 for no. Press 1 for yes to reset drum life
Feb 02, 2010 | Brother HL-2040 Laser Printer
Brother DCP-9045 CDN end of Belt Unit life override, how too? I have a Brother DCP-9045 CDN and it tells me the Belt Unit needs replacing. However it works fine and I am convinced there is more life in...
Turn your printer off. Turn it back on again, go to menu -> Machine Info -> Reset Menu, choose Belt Unit, OK, then reset the counter pressing 1, then press stop/exit. Same for drum.
If however this won't work, go to the following page and look at the instructions. Do what it says, but just pull out the drum unit and put it back in, the same with belt unit, just pull it out and put back in.
Then do the reset procedure as described. Should fool the printer ;)
Nov 28, 2009 | Office Equipment & Supplies
Brother DCP-9045 CDN end of drum life override, how too? I have a Brother DCP-9045 CDN and it tells me the Drum Unit needs replacing. However it works fine and I am convinced there is more life in them. ...
Link: Brother instructions
Brother MCF-7340 first time toner replacement
If this model comes with the drum separately of the cartridge, only replace the cartridge. There's no need to change it every time. until prints start to get lines or dots. Don't expose the drum to light too much.
Jul 30, 2009 | Brother MFC-7340 All-In-One Laser Printer
I have changed the drum unit on Brother HL2170W but the drum LED
Make sure that the printer is turned on and the Drum LED
is blinking. Open the front cover of the printer
Press and hold down the Go button for about 4 seconds
until all the LEDs light up. Once all four LEDs are lit,
release the Go button.
take the drum unit out and put it back in, close the door
Jun 26, 2009 | Brother HL-2040 Laser Printer
Brother HL-2040 Laser Printer Logo
2,323 people viewed this question
CheckitRight
CheckitRight
Ron Dufek
Ron Dufek
James Cagle
James Cagle
