Question about Plantronics Explorer 330 Headset
Need Plantronics 330 bluetooth headset manual
I just paired my bluetooth with a newer phone, and I can't remember how to use it. I can't fine my manual, so I was wondering if there is one I can print off the internet.
I finally found the manual on the internet. Thanks for your time anyway.
Posted on Feb 03, 2009
Plantronics 330 unable to get the bluetooth in discovery mode
Once you make your cell phone discoverable, then put the Plantronics Explorer 330 headset into pairing mode by holding the call control button until the headset flashes red and blue. Click on the link below for the Explorer 330 user guide with the pairing instructions.
Plantronics Explorer 330 User's Guide
Good luck from Headsets Direct!
Jan 05, 2011 | Plantronics Explorer 330 Headset
Plantronics 330 connects to phone but no volume on the headset/microphone
Remember that newer phones are like small computers, so they may become corrupt over time and you may need to reset them every so often. Simply turn your phone off and remove the battery for a few seconds, then replace the battery and turn it back on again. If this does not resolve the issue, delete the pairing information for your Explorer 330 headset and pair it with your phone again. The link below for the Plantronics Explorer 330 has the pairing information.
Plantronics Explorer 330 Pairing Information
Dec 31, 2010 | Plantronics Explorer 330 Headset
My plantronics 330 is paired to my iPhone 4. It works fine with the phone, but with no other applications. I want to hear the mapquest voice directions on my iPhone through the ear piece but it doesn't...
If you would like for your Bluetooth headset to stream music or any other audio applications to your phone, the Bluetooth profile in both devices must support Advanced Audio Distribution (A2DP) for audio streaming. Unfortunately the Explorer 330 does not support this newer technology. I would suggest updating your headset to a newer model but remember your phone must also support A2DP. The Plantronics Voyager Pro+, Voyager Pro HD & the M1100 Bluetooth profiles support A2DP. I will include a link for Bluetooth headsets below.
Bluetooth Headsets that support A2DP
Nov 21, 2010 | Plantronics Explorer 330 Headset
When I cmate the bluetooth to the cell phone (motorola Razor) I can not hear the caller. They can hear me but I have to listen from the phone to hear them. Did I connect wrong?
Remember that newer phones are like small computers, so they may become corrupt over time and you may need to reset them every so often. Simply turn your phone off and remove the battery for a few seconds, then replace the battery and turn it back on again. If this does not resolve the issue, delete any pairing information for your Explorer 330 headset and pair it again with your phone, carefully following the instructions on the link below for the Plantronics Explorer 330 User's Guide.
Jul 21, 2010 | Plantronics Explorer 330 Headset
How to connect plantronics 330 bluetooth headset with my iphone 4
When joining (or pairing) a Plantronics bluetooth headset to another device a lot depends on the other device. Assuming that you know the necessary steps of your phone or PC for connecting a bluetooth device, all Plantronics headsets pretty much follow a set pairing procedure for connectivity. This one is for the Discovery 975:
1 Turn on the Bluetooth feature on your phone.
2 Turn the earpiece on. Press and hold the call control button until the indicator flashes red/white.
3 Use the commands on your phone to locate and select your earpiece. 9xx Plantronics.
4 If prompted for the PIN code or Passkey, enter 0000.
Pairing is successful when the indicator on your earpiece flashes white.
Note If your phone supports Secure Simple Pairing (SSP), you will not need to enter a PIN code or Passkey.
Jul 20, 2010 | Plantronics Explorer 330 Headset
CAN'T GET BB9630 TO CONNET TO PLANTRONICS 320 BLUETOOTH
again the battery for a few seconds, then replace the battery and turn it back on again. If this does not resolve the issue, delete any pairing information for your Explorer 320 headset and pair it again with your phone, carefully following the instructions on the link below for the Plantronics Explorer 320.
Plantronics Explorer 320 User's Guide
May 05, 2010 | Plantronics Explorer 330 Headset
Bluetooth code Plantronics 330 to LG AX300
try these codes
1234
4321
9876
6789
9999
0000
one of them will work
best of luck
please remember to rate me.
Mar 06, 2009 | Plantronics Explorer 330 Headset
New cell phone won't "see" bluetooth earpiece
The headset will automatically pair with the last device that it was paired with. You may want to remove that just in case. I am sending the users guide along with this. Also always start with the blue tooth turned off, the pass key is 0000 (four zeros).
Plantronics Explorer 300 Series User's Manual
Feb 14, 2009 | Plantronics Explorer 330 Headset
I cannot connect my 330 bluetooth to my phone, and I also cannot
Once you make your cell phone discoverable, then put the Plantronics Explorer 330 into pairing mode by holding the call control button until the headset flashes red and blue. Here is the link below for the Explorer 320 user guide which has the pairing instructions, it will be the same for the 330.
Jan 10, 2009 | Plantronics Explorer 330 Headset
Troubleshooting?lost manual
Begin with headset turned off.
1. Press call control button for
6 seconds. Release button when
indicator light flashes blue and
red. Headset is ready to pair with
Bluetooth device.
NOTE The headset can pair to
multiple Bluetooth devices, but
will only connect to one device
at a time. The headset will automatically
connect to the last
device to which it was connected.
2. While the headset is flashing red
and blue, use the phone menu
to search for Bluetooth devices
and select “3XXPlantronics”.
3. When prompted for passkey enter
0000. Headset will flash blue when
paired successfully.
Apr 15, 2008 | Plantronics Explorer 330 Headset
Plantronics Explorer  330 Headset Logo
667 people viewed this question
Top Plantronics Radio Communications Experts
LeAnna Mathews
LeAnna Mathews
Level 1 Expert
shaun taylor
Michael Vincent Cruz
Are you a Plantronics Radio Communication Expert? Answer questions, earn points and help others
