Question about Epson Stylus Photo R200 InkJet Printer
Is there a way of manually cleaning a printhead?
Because automatic printhead cleaner will not clean my dark cyan printhead
  • 353 Answers
Are you confident you have a good Cyan cartridge from which the ink is flowing properly. For example, are you sure you removed the yellow tape from the cartridge before you installed it? Is it low on ink? Even though the Status Monitor says the cartridge has plenty of ink, it may not. This is because the Status Monitor only estimates how much an ink cartridge contains based on how much printing & head cleaning has been carried out since new. There are a number of reasons for it to get it badly wrong, or it may simply be faulty (e.g. an out-of-date cartridge that has dried-up). If in doubt change it for a new one.
Apart from a dud cartridge, air trapped in the nozzles can inhibit ink flowing. This is usually caused by unsatisfactory cartridge replacement e.g. taking out the old cartridge too long before installing the new. Tackle this with head cleaning cycles. But, do not carry out more than 2 or 3 cleaning cycles in a row; once ink starts to flow, as shown by a nozzle check print, leave it to stand for 24 hours before trying 2 or 3 cycles again. Patience is the key.
If these steps produce no improvement, then you can try the following head-soak process. Turn the printer on, and as soon as the print head moves, pull the power cord out of the back, or turn the printer off at the mains. You may now carefully move the print head by hand over to the left hand side out of the way. Look inside the print head parking area on the right and you will see a small rubber cup that comes up to cover the print nozzles when the head is parked (to stop it drying out). Use a syringe or dropper to fill this cup with head cleaning fluid or distilled water. DO NOT USE TAP WATER. Carefully push the print head fully into its parking position so that the cup full of fluid comes up over the print head. Leave this for at least 24 hours, then try a head clean or two again. If still nothing, report back.
Posted on Feb 10, 2009
  • Frank Palaisy
    Frank Palaisy Jan 25, 2015
    Hi, I recently got a second hand Epson Stylus Photo R200 and it came with extra ink that worked fine but before I used that up I looked into getting auto resetting cartriges for it and bulk ink. These cartiges arrived empty and I did not fill them right away figureing it was best to do so right before they were to be used. All ink had been working but the yellow that seemed to have leeaked out as the lable on the cartrige of the original batch was stained yellow. Now that I have put the auto resetting cartriges in to use filled only 2 of the 6 colors print and one leaves just a dash when doing the nozzle check. I have done what was suggested here and was woundering what more could be done to get the printer working again. While it printed it had great quality even for not having yellow most of the time;(when I printed a test page the yellow worked too). Hope you could help, Frank
  • Gerry Millward
    Gerry Millward Jan 26, 2015
    Hi Frank
    I regret that I no longer support fixya due to the appalling bad management of the system. It is virually impossible to find an answer to one's problem, even though the answer almost certainly is in there somewhere.
    However, your problem raises a lot of questions. My suggestion is to buy a set of normal clone cartridges (they are very cheap) and see if you can persuade the print head to start printing properly. Install the new cartridges first and then give the print heads a good long soak. Do not waste ink in a cleaning cycle until you have done this. If this works, replace the cartridges with your refillables. If they still do not work, try and get a refund from the supplier. For older printers, it is not cost effective to use refillables since the standard (clone) cxartridges are so cheap.
My mp780 will not print light cyan or magenta...It prints all the dark colours on the print test perfectly but leaves the light ones missing. I have tried a new printhead and it has new canon cartridges....
Most likely the print heads are dirty and need to be clean. The user manual for the Canon should tell you how to do that, but in case you don't have the manual, you can get it here: http://goo.gl/iIylF
Mar 06, 2011 | Canon PIXMA MP780 All-In-One InkJet...
HP designjet 1055cm plus: Installed new toner, printheads and printhead cleaner packs and the black one is failing? Said, alignment so reinstalled. Still failing. Help!
hello,
Try to reconfigure your printer setting and then run diagnostic on your printer to know the status of your printer if it still supports the new toner , printer heads you install.
Thanks
Jul 31, 2009 | HP DesignJet 1050c InkJet Printer
MP830 Canon - NOZZLE CHECK does not print light cyan line
You will need a new printhead, QY6-0061-000, runs around $60.00 well worth it for your machine.
Sep 08, 2009 | Canon PIXMA MP830 All-In-One InkJet...
When printing colour, black appears green
A worn out printhead can allow inks to contaminate each other, after cleaning you need to check your cartridges, if yellow is a brown color, you are getting contamination and need to replace the printhead. Black is hard to tell but when cyan gets too dark it's contaminated as well.
Aug 12, 2009 | Canon BubbleJet i560 InkJet Printer
Cyan ink tank not printing
clogging in cyan nozzles in printhead. try to clean or deep clean printhead from printer software.
Sep 17, 2008 | Canon PIXMA MP510 All-In-One InkJet...
No printing on right side, I replaced the imaging drum but that did not solve the problem.
There are two possible solutions to this common problem.
1) The Cyan cartridge may not be in 100% of the way. If the handle of the Cyan cartridge prutrudes even slightly, it can obstruct the printhead for the black developer. Remove and reinstall the Cyan cartridge and test.
2) The printhead is dirty, with some toner spillage on the printhead. All new imaging drums also include a new cleaning pad for the cleaning wand.
The cleaning wand is designed to clean toner off of the printhead. you can see this in your printer manual, but basically, just open the front cover, pull the the blue handle on the right side forward ( this opens the access cover for the cleaning wand on the right side of the printer ).
gently pull the cleaning wand out ALL THE WAY, then slide it back in ALL THE WAY. do this several times.
The cleaning wand is intended to travel across the print head in only one direction, which is why you should make sure that it is pulled all the way out.
One of these two solutions should fix your problem. If the problem is resolved, but then reappears after a short time, then you have a defective developer that is leaking toner on the print head. The color of the defective developer can be determined by the color of the cleaning pad after cleaning the printhead as discribed above.
Sep 07, 2008 | Dell 3100cn Laser Printer
HP Business Inkjet 3000
you may wish to clean the nozzles, and do a clean and calibrate
May 07, 2008 | HP Business Inkjet 3000 Printer
Printing problem
Are the problem prints all from the same source? If so the problem could be on the transmission end. Can you connect to your fax and print to it from a local workstation? If so print several images with dark solid patterns and see if it is actually the printhead. Try printing in cyan, magenta, yellow, and black colors to to rule out each individual printhead.
Jan 03, 2008 | Sharp UX B700 Plain Paper Inkjet Fax
Phaser 8500 cleaning page
You can't. Just simply stated. It is the way it's designed.
Per Xerox below
NOTE: The automatic printhead cleaning cycle cannot be disabled.
The printer performs automatic printhead cleaning cycles to remove air bubbles or foreign matter that can cause a printhead jet to malfunction. An automatic printhead cleaning cycle is performed when the printer is first powered ON, or if the ink has cooled to the point that a cleaning cycle is required.
Powering OFF the printer longer than 3 or 4 minutes will also cause the printer to perform a printhead cleaning cycle when the printer is powered back ON, which uses ink. To minimize ink consumption, keep the printer powered ON at all times.
Sep 13, 2007 | Xerox Phaser 8500N Printer
Epson Stylus Photo R200 InkJet Printer Logo
767 people viewed this question
Top Epson Office Equipment & Supplies Experts
Alun Cox
Are you an Epson Office Equipment and Supply Expert? Answer questions, earn points and help others
