Question about Yahoo Messenger
Cannot install yahoo messenger
When trying to install yahoo messenger it goes all the way to 100% but then just stays there without actually installing the program. What can I do?
  • Anonymous Feb 03, 2009
    i keep on installing yahoo messenger several times now but when it gets to 100% it just stay as it is it is not installing, instead it syas the installation process is cancelled or interrupted even thought its the only program running in my network and pc.
  • 20 Answers
This can be the result of also having a program called "Speedbit Video Accelerator" installed on your computer. Speedbit Video Accelerator is a program that one can install to allow YouTube videos to stream faster and easier. However, this program can result in the installation or usage of Yahoo! Messenger to become laggy or hang up, resulting in the inability to use Yahoo!.
Check to see if you have Speedbit Video Accelerator by going to Control Panel, and then Add and Remove Programs. If you have this software, it is best to remove/uninstall it, otherwise you will be unable to install and use Yahoo! Messenger. Once Speedbit Video Accelerator is uninstalled, you can then attempt to install Yahoo! Messenger once more.
This should fix the issue. If it does work after uninstalling Speedbit Video Accelerator, it is best to keep Speedbit uninstalled, as it can cause problems once Yahoo! is installed as well.
Posted on Feb 17, 2009
Why i cant use vedio or voice call in UAE
All Yahoo messenger versions don't have built-in Voice and Video features. The most common (for all users) is the u.s. version with full featured version. And there's no problem using the U.S. version in UAE or Africa etc.. If you need one, you can download it from the links below:
1. Yahoo messenger U.S. version Online installer. Open the link and click the "Download Now" button. After it's downloaded, you have to install it and the installation will take some time with this version since the actual database files are to be downloaded from the Yahoo server.
2. Yahoo messenger U.S. version Standalone, offline installer. With this installer, you'll be able to install the yahoo messenger directly without another download process. It may take longer to download, but will take less time during the installation.
Good luck.
Thanks for using FixYa.
Aug 14, 2010 | Yahoo Messenger
Gyache's Yahoo Problem
my friend try to reinstall your yahoo messenger to fixthe problem. you can download this offline installer to make your installation 90 - 100 % success. Yahoo Messenger
just click the link i provided then download the installer and install it. Hope this helps your problem. Thanks
Jun 26, 2009 | Yahoo Messenger
100 percent and then nothing
1. Try do download latest version.
2. take you memory stick, go to your frined get the installation file on that and the install it from memory stick on your pc.
3. contact yahoo technical support.
http://help.yahoo.com/l/us/yahoo/messenger/contactus/contactus-01.html
Feb 25, 2009 | Yahoo Messenger
How much of time the installing yahoo messenger will be taken?. I tried so many times. Yahoo messenger installing shows 100% completed and it started another time downloading.How many times it will shows...
maximum of 10 mins. if you already download the yahoo exe. then if system updating configuration pls wait is appear for a long minute of time... then you did not properly uninstall the previous version of the messenger... kindly uninstall it and delete the remaining folder of yahoo in program files/ yahoo folder....
Feb 22, 2009 | Yahoo Messenger
Yahoo messenger
download a latest copy yahoo messenger, sometime when your yahoo messenger become old it cant log you in download from here...... this link is yahoo messenger standalone installer
Click here to Download
install yahoo messenger then log in again
This will help. Thanks please keep updated. please do rate the solution positively .Thank you for using Fixya
Regards
manish
Feb 20, 2009 | Yahoo Messenger
When trying to install yahoo messenger it goes all the way to 100% but then it just stays there and does not actually install the program. What can I do?
I Have Had This Problem Many Times The Program Is Usually Fully Operational Although It States It Doesn't Finish So I Would Recommend Trying To Run It Once It Has Gotten To %100 And If That Doesn't Work You May Need To Install Another Version Of Yahoo.
Feb 02, 2009 | Yahoo Messenger
Yahoo messenger 9.0 won't install fully
Try to uninstall it and install lower version like YM 8.0
Nov 28, 2008 | Yahoo Messenger
Downloading YM 9.0 it goes to 100% and never prompts completion
Hey,
it might happen if you are trying to download yahoo messenger directly from yahoo.com.
You may use software sites to download yahoo messenger version 9 and more likely it would work n vista.
One of the link is :-
http://www.download.com/Yahoo-Messenger/3000-2150_4-10029188.html?tag=mncol&cdlPid=10888512
I hope it wl slve ur question.....
Nov 15, 2008 | Yahoo Messenger
Error In installing Yahoo Messenger
Go to the toolar and click on Tools. Pull down the menu and click on internet options. The first tab is generally and you will see the option to delete your cookies, history etc. DO it. Then:
Be sure that you are doing a CLEAN download and install. Turn off all running programs including and escpecially your virus/firewall program. Look through the little icons on the lower right and turn off everyone that you can. Your firewall will actually stop a clean download. After you have downloaded and installed messenger, do a restart and make sure that your virus control is running again.
I hope this helps. Good luck to you!
Aug 08, 2008 | Yahoo YHT-630 System
Yahoo Messenger Logo
143 people viewed this question
Top Yahoo Computers & Internet Experts
micky dee
Mike
fixrfast
Level 1 Expert
Are you a Yahoo Computer and Internet Expert? Answer questions, earn points and help others
