Question about Canon PIXMA MP460 All-In-One InkJet Printer
After you load paper printer says no paper loaded. It catches paper but does not send it through.
  • 1,602 Answers
YOU HAVE FAN THE PAPER BOTH ENDS LONG WAYS FAN THE PAPER, WIDE OR SIDE OF THE PAPER NEEDS TO BE FANED,
ASSIST THE PAPER INTO THE FEEDER MAKE SURE THERE IN NO FORIEGN OBJECT IN THE FEEDING AREA MAYBE PENCIL OR PEN FELL DOWN THERE,
STICK YOUR HAND BEHIND THE PAPER AND PUSH THE PAPER FORWARD UNTIL PAPER STARTS TO FEED YOU HAVE TO DO EVERY TIME YOU LOAD NEW PAPER UNLESS YOU PLACE NEW PAPER BEFORE IT RUNS OUT OF PAPER, THIS IS A PICKUP ISSUE FOR THE PRINTER,
ROD
Posted on Feb 02, 2009
  • ROD GANDY Feb 02, 2009
    ROD
Printer model : hp425 dw I get this message: "Load
send back under warranty, first check there is not a paper jam.
Oct 28, 2017 | Office Equipment & Supplies
Hello, I have a question about the HP 1312 all in one printer. Does it print on legal size paper and where do I load the legal size?
Yes, it can print on legal size paper. Do the following:
Lower the paper tray, and if necessary, slide the paper-width guide to the outermost position.
Fold out the paper-tray extender to catch paper as it exits the device.
Tip: For best results when loading legal-size paper, fold in the paper-tray extender before loading the paper to avoid a paper jam.
May 13, 2011 | HP Office Equipment & Supplies
How do i load paper?
A4, Letter, or legal-size paper can be loaded. The minimum size that can be loaded into the ADF is 3x5 in. When you load small paper sizes, place your original in the center of the tray and adjust the paper guides to the edges of the paper. When making copies, sending faxes or scanning, load your original document into the feeder, face down.
I hope this information has been helpful. Thanks.
Dec 28, 2010 | Lexmark X4270 All-In-One InkJet Printer
IMy wife pulled the paper tray completely out of
Loading your paper
Paper loading tips:
● Load paper with the side to be printed facing down.
● You can print photos and documents on a wide variety of paper sizes, from
8 x 13 cm (3 x 5 inch) up to 22 x 61 cm (8.5 x 24 inch). The 10 x 15 cm
(4 x 6 inch) photo paper is available with and without tabs.
● Before loading paper, pull the Main paper tray out (use the Main tray release or
the tray grips) and slide out the paper-width and paper-length guides to make
room for the paper. After loading paper, adjust the guides to fit close to the edges
of the paper without bending the paper. When finished loading paper, push the
Main tray back in all the way.
● Load only one type and size of paper at a time in the same tray.
● After loading paper, extend the Output tray extension to catch your printed pages.
Use the directions in the following table to load the most commonly used paper sizes
into the printer.
Paper type How to load Tray to load
Any supported
photo or plain
paper media
1. Extend the Main tray by
pulling it out with the Main
tray release or the tray
grips.
Load the Main tray
Chapter 2
(continued)
12 HP Photosmart 8200 series
2. Slide the paper-width and
their outermost positions.
3. Load paper with the side
Check that the stack of
paper is no higher than
the top of the paperlength
guide.
4. Adjust the paper-width
inward until they stop at
5. Push in the Main tray all
the way in.
6. Make sure the light on the
Photo tray button is
turned off to enable
printing from the Main tray.
Load paper and adjust guides inward
1 Paper-width guide
2 Paper-length guide
1 Push the Main tray all the way in
Aug 03, 2010 | HP Photosmart 8250 InkJet Printer
Photo printing errors
This is not the fault of printer. Choose those type of photo paper, whose thickness is equal to executive bond paper. This type of printer do not catch the thick photo quality paper
Apr 09, 2010 | HP PSC 1610 All-In-One InkJet Printer
The printer keeps saying that the paper isn't loaded, and it's not catching the paper to send it through. How do I get it to grab the paper, and why is it saying there's no paper loaded?
Hi
Please check for a lever on the area where paper goes out? most all in one printer from epson has this lever where you can toggle to grab paper or envelope.
Hope this helps
Apr 01, 2010 | Epson CX8400 All-In-One InkJet Printer
Brother MFC-8840d ADF feed problem
Hi, the left hinge is spring loaded to keep the lid open. This applies a lot of pressure on the pivot point of the hinge (steel pin/plastic hinge) that elongates the plastic holes and raises the lid from the scanner. As the paper leaves the scan window, a ramp next to the scan window sends the paper up to the tray, just past that ramp under the lid is a lip that guides the paper to the tray. With the hinge stretched, the lip is too high and catches the end of the paper at the rear only, and jams the paper. If you press on the cover (with the new hinge) and it does not catch then you have installed a bad hinge. Also ensure that the top part of the hinge is on the guide pins under the cover.
Jul 29, 2009 | Brother MFC-8840D All-In-One Laser Printer
C 4180 photo smart printer, not loading 4x6 photo paper
You could try stacking more paper behind it, thereby creating more pressure on the paper feed.
May 06, 2009 | HP Photosmart 4180 All-in-One Printer
Photo paper loading
is this still current issue?
Apr 15, 2008 | Canon PIXMA iP1600 Printer
Paper feed not working
remove the paper from the machine and look where it feeds in. There should be some rubber rollers, try cleaning them with a rag and some rubbing alcohol. If this doesn't work let me know. Also fan the paper before loading it. John
Jul 07, 2007 | Cannon i70 Printer
Canon PIXMA  MP460 All-In-One InkJet Printer Logo
125 people viewed this question
old marine
old marine
