Question about Maytag PYG2300A Gas Dryer
Mytag Dryer Start on but does not heat
My maytag dyer start on (motor runing) but does not heat,
I reviewed the thermal fuse (I bay pass it) but still the same problem.
Would you help me withi this trouble.
best regards
  • mfrank499 Feb 16, 2009
    Dryer runs but does not heat.
  • 11,896 Answers
Heating element is shot
Posted on Feb 02, 2009
I have a Kenmore Dryer, Model 96292110. It runs, but it does not heat the air. I have checked the circuit breakers. They are fine.
If your Maytag dryer has mysteriously stopped producing heat, a blown thermal fuse may be the cause of your problem. In Whirlpool dryers,thermal fuses are safety switches that are designed to disrupt the flow of electricity to your dryer's heating mechanisms once the dryer reaches a predetermined maximum temperature, usually somewhere around 180 degrees F.
Thankfully, troubleshooting the thermal fuse in a Maytag dryer is easier than it sounds.
Instructions And Things You'll Needed.
  • Screwdriver,Towel,Electrical tape,Replacement thermal fuse, if necessary.
1 Clean out thelint screen in your Maytag clothes dryer. Lint buildup can cause your dryerto overheat, triggering the thermal fuse to disrupt power to your dryer'sheating mechanisms. Take the lint screen out of your Whirlpool dryer and washit in warm water. Dry the screen thoroughly before replacing it.
2 Look behindthe dryer to check its flexible exhaust hose for kinks or obstructions.Disconnect the exhaust hose from the back of your dryer and clean out any lintthat has built up.
3 Go outside andcheck your Maytag dryer's exhaust vent for obstructions. Lint buildup, birdnests or other obstructions in the outside exhaust vent can trigger yourdryer's thermal fuse.
4 Disconnectyour dryer from its power source before attempting to access its thermal fuse.
5 Access the thermal fuse in your Maytag dryer byremoving the back panel. Remove the screws that hold the back panel in placeand it should easily come free.
6 Look betweenthe dryer's blower housing and exhaust to locate its thermal fuse. The thermalfuse in a Whirlpool dryer looks like a white plastic strip that has two wiresconnected to it.
7 Bypass the thermal fuse in your Maytag dryer whileyou perform a quick diagnostic test. Use electrical tape to tape together thetwo wires connected to the thermal fuse. Reassemble your dryer and plug it backin. Set the dryer to a timed heated drying cycle and press "Start."If the dryer produces heat with its thermal fuse bypassed, it means the thermalfuse needs to be replaced.
8 Replace a blown thermal fuse in your Maytag dryer.Disconnect the power and remove the back panel. Remove the electrical tape thatyou used to perform the diagnostic test and disconnect the wires from thethermal fuse. Remove the screws that secure the thermal fuse to the dryer anddiscard the blown fuse. Attach the replacement thermal fuse by replacing andtightening the screws. Attach the wires to the new thermal fuse.
Thanks for using fixya.
Jul 31, 2011 | Kenmore Dryers
Dryer wont start
If the problem you are having is that your Maytag gas dryer is not starting, these are the parts you will need to check until you find and correct the problem.
You need to make sure that the wall outlet has 120 volts presents in it, in order for the dryer to be able to start. Connect a good working hair dryer in the wall outlet, if the hair dryer works, then you know that the wall outlet is not the problem.
Most gas dryers have one thermal fuse and some have two thermal fuses wired in series with the motor. If any of the thermal fuses are blown that could be one of the reasons of your dryer not starting.
The timer is the distribution center in the dryer, the timer will send the right voltage to each of the individual parts in the dryer. Most common problem with the timer, is burnt contacts.
The motor is in charge of turning the tumbler, turning the blower to circulate hot air inside of the dryer and making sure that the heating element won't come on when the dryer motor is not running. A bad or weak motor could be the reason for your Maytag gas dryer not starting.
The door switch is a safety device use to prevent the dryer motor from starting or running when the door in the dryer is open. Burnt contacts or a broken actuator on the switch could be the reason that the dryer is not starting.
The push to start switch is single pole single throw switch that is use to start the motor. Once the motor starts running the switch is no longer in the motor circuit. A bad push to start switch could be the cause of your dryer not starting.
Burnt terminals or wires on the cord could be the reason for your dryer not starting.
As you can see, if any one of these parts fails the dryer will not start.
please comment on these post by staying how helpful.
Dec 21, 2010 | Maytag MDG308DAWW Gas Dryer
No heat from dryer maytag atlantis mde7600ayw had heating element them fuse and thermostat checked ok check ciruit breaker turn on and off decided to replace fuse dyer still didn't heat check outlet...
most dryers have a thermal switch or breaker in the cavity somewhere, they can become worn over time and will stop heating, the item probably looks like a copper arm that touches a contact similar to a old morse code key by looks
Sep 18, 2009 | Maytag Atlantis MDE7400AY Electric Dryer
Whirlpool dryer WED5530SQ0, heats but does not run
So,. basically your drum doesnt turn. SO your getting heat still even though the drum isnt turning. Is this right? Sounds strange??? Do you hear any humming noise when you push the start button? I need to know a little more about the problem because im kinda confused as how you decribed the problem. Iv never seen a dryer heat but the drum not spinning. especially your model dryer. Its electric heat right? because if the drum doesnt spin, maybe your motor is bad. and if your motor is bad, then your heating element wont heat up because the centrifical switch in the motor is not switching to complete the circuit to the heating element. So this is why im confused when you said" Dryer heats when knob turned but when "push button" pressed, drum doesnt run." Because your belt wraps around the motor pully and the motor is what makes the drum turn. Like i said, i never seen this model dryer heat with out the motor operating. So if you can give me some more info, ill do my best to help you out....Thanks!!!!
Jul 30, 2009 | Whirlpool WED5500S Electric Dryer
Maytag neptune dryer mde5500ayq replaced old motor with new motor starts up first time alright I turn off and it will hesitate to restart. most times it will not restart. Humms then kicks out. I have no...
Compare the wiring connections on both motors. They may be marked. They may be different. Careful examination will determine the start and run wires. Other wires turn on the heat once the motor reaches running speed. The thermal fuse for the motor is internal and unservicable. The hi limit sensor will control the heat, but will not necessarily turn off the motor.
Apr 23, 2009 | Maytag Neptune MDE5500AY Electric Dryer
My Whirlpool Duet Dryer is not heating up. Unit is only Two year
If it is a gas dryer. Sounds like thermal fuse. It costs about $12.95. Most appliance part stores carry it all the time. Very easy to replace. Also can be ignition switch (also cheap). If you know someone who is mechancally inclined, after removing fuse,they can run an electrical jumper cord to the two open ends. If the dryer begins drying, then it is definitely the fuse.
Go to Whirpool site and get part number and diagram to fix. Maytag repair can help at a costly figure after they order part since Whirpool bought Maytag.
Dec 21, 2008 | Whirlpool Duet GHW9150P Front Load Washer
Thermal Fuse
do u mean that the drum wont go round if so then it could be your mains filter which is faulty this is situated next to your motor either a plastic/metal cyclinder with wording on it will only be about 4in in length
Aug 12, 2007 | Maytag MDE2600 Electric Dryer
Open Questions:
Maytag PYG2300A Gas Dryer Logo
105 people viewed this question
Top Maytag Dryers Experts
Dan Webster
Dan Webster
Tim Whalen
Are you a Maytag Dryer Expert? Answer questions, earn points and help others
