Question about Sony KP-51HW40 51" Rear Projection Television
Convergence problem screen turns blue and shuts off and the timer light then flashes red a few times
  • Shahid Electronics
    Shahid Electronics May 11, 2010
    This problem of Blue Gun, not convergence section.
    Blue Gun may be replaced in this case. Call TV tech to confirm the problem and solution.
  • Sony Master
  • 5,138 Answers
Replace blue tube.
Posted on Feb 12, 2009
I have a large sony hd read projection / a few days ago - i started getting faint green lines that are arched - higher in the center - symmetrical, an about 1.5 inches apart - a few times , the tv has...
All projection TV sets have two very common problems. One is convergence ( 3D/Warped video) the other is CRT fluid ( Dull Video). Here are more details and solutions for both.
Common Problem #1) Convergence has gone out
Projection TV sets need to have all three colors - RED - BLUE - GREEN - lined up correctly on the screen in order for the video to look normal. When its out of alignment the video will look 3D, wavy, distorted, etc. Most of the time you just need to adjust your convergence in the TV menu. If you cannot adjust it in the menu - then your convergence is broken and needs to be repaired.
This is a very common failure on these projection sets and a fairly simple DIY fix. All projection sets including Samsung, RCA, Sony, Philip Magnavox, Panasonic, Pioneer, Akai, GE, JVC, Toshiba, and others at some point will have the same problem.
Common Symptoms include....
  • Screen looks 3D
  • Colors don't line up
  • One or more colors can't be adjusted when using the convergence menu.
  • Screen is bowed or warped.
  • TV shuts off after powering on. Power light will blink. TV may also make a chirping noise.
Here are some pics of convergence problems.
Common Problem #2) CRT Fluid is Cloudy
Projection TV tubes have a liquid coolant that is used to keep them from overheating. After many years the coolant in the blue and green tubes will become cloudy and cause the screen to look dull, red/orange, etc. You may even see halos around images.
Picture of a set that needs the fluid changed.
TV set after fluid change
69189a5.pngSOLUTION
You can see some more examples and find a fix using this link on Fixya http://www.fixya.com/support/r2861467-solution_video_looking_whiteish_dull
Jan 09, 2011 | Sony KP-57WV700 57" Rear Projection HDTV
When i turn on the tv there is no sound only clicking sound and no picture. then it atomaticly turns off. also the lamp light flashing red? not sure what is wrong.
  • Screen looks 3D
Here are some photos of convergence problems.
Here is a quick test....
Using your original remote go-to the settings menu then goto the convergence section.
Try to adjust the red and then the blue convergence.
You should be able to move RED and BLUE in all directions - up, down, left, and right. And you should be able to get the grid straight.
If you can't move them in all directions or cant move them far enough your convergence chips are bad and should be replaced. This is a common problem.
Note: If you TV has as flash focus or magic focus button only try pressing the button. If it fails to fix the convergence your need to fix it. See below for a fix
69189a5.pngCONVERGENCE SOLUTION
Aug 13, 2010 | Panasonic PT-52LCX65 44" HDTV
TV HAS HAD RED SHADOWS AROUND THE BOTTOM OF THE SCREEN FOR A FEW WEEKS, THEN IT SHUT OFF ONE DAY ABOUT 20 SECONDS AFTER BEING TURNED ON
This is a very common failure on these projection sets and a fairly simple DIY fix. All projeciton sets including Samsung, RCA, Sony, Philip Magnavox, Panasonic, Pioneer, Akai, GE, JVC, Toshiba, and others at some point will have the same problem.
  • Screen looks 3D
  • May have shadows
You will need to replace the convergence chips and possibly some convergence resistors and pico fuses.
This is a a fairly easy DIY job if you are handy and can follow directions. You can get complete repair kits from TvRepairKits.com or click here. They have put together DIY repair kits that include the OEM parts and step by step photo instructions for each repair. If you are not handy or can't follow directions we would suggest calling a shop.
Jan 20, 2010 | Mitsubishi WT-42313 42" Rear Projection...
I have a Sony kp53xbr35 rp tv, the problem is that i turn it on the lights begin to turn on. the screen turns blue to blue green then red and the tv shuts off. i can still get sound but no picture. the...
Projection sets have two very common problems outlined below.
The first common problem is convergence
These sets need to have all three colors - RED - BLUE - GREEN - lined up correctly on the screen in order for the picture to look normal. This is called convergence.
When its out of alignment the video will look 3-D, wavy, distorted, etc. The TV can also shut down when the convergence starts to fail.
Most of the time you just need to adjust your convergence in the menu. If you cannot adjust it in the menu - then your convergence is broken and needs to be repaired.
Convergence problems are very common on all Projection TV sets including Sony, Samsung,JVC,Philip Magnavox,Panasonic,Akai,Pioneer, Hitachi,Mitsubishi,Zenith, RCA and others.
You can get more information and a DIY convergenece repair kit with instructions from TV Repair Kits using the link at the end of this article.
Here are some of the most common problems with these sets...
*Screen Looks 3-D
*Colors wont align
*Screen may look distorted or warped or bowed
*No Audio/Video - TV Shuts down - May also make a constant chirping sound
Problem #2 - Another common problem is dull or washed out video.
Your set may have one or more of the following symptoms....
*Dull looking picture
*White looking picture
*Halos around objects
*Red/Orange looking picture
bb0cf99.pngSOLUTION
Nov 16, 2009 | Sony KP-53XBR45 53" Rear Projection...
I have a Sony kp53xbr35 rp tv, shutting off
If you know that the convegance IC are bad then I would replaece them frist and see if that will fix the whole problem, it just might. Here is a sight you can go to that may help you if that does not fix it www.somelifeblog.com has some good info on sony not your model but could be same problem. check it out and see.
Nov 16, 2009 | Sony Televison & Video
MITSUBISH WS 65807 GREEN LIGHT TURNS OFF PROBLEM
you could try checking your convergence board, i have a samsung that when powered on the red timer light flashed a few times and then went out , turns out it was my converge board, when i unhooked it the worked again colours were out of align ,but fixed board and all is well
mikeyfix
May 07, 2009 | Mitsubishi WS-65413 65" Rear Projection...
Blue ghosting all over the screen TV screen stays dark blue whether turned on or off. Indicator light keeps flashing green when TV turned on.
The most likely cause is shorted convergence chips and possibly a few pico fuses.
When its out of alignment the video will look 3-D, wavy, distorted, etc. Most of the time you just need to adjust your convergence in the menu. If you cannot adjust it in the menu - then your convergence is broken and needs to be repaired. Convergence problems are very common on all Projection TV sets including Sony,Samsung,JVC,Philip Magnavox,Panasonic,Akai,Pioneer2_bing.gif Hitachi,Mitsubishi,Zenith and others.
You can get a convergenece repair kit with instructions from the links below.
Yours may have one or more of the following symptoms...
*Screen Looks 3-D
*Colors wont align
Problem #2
You can see some more examples and find a fix herebb0cf99.png http://www.fixya.com/support/r2861467-solution_video_looking_whiteish_dull
Feb 26, 2009 | Sony Grand WEGA KF-50WE620 Television
KE-42XBR900- SYSTEMS SHUTS DOWN ON ITS OWN
Replace the G board. I had same issue and Sony accidently sent me two boards. I will sell the other for $450
danmathieu@aim.com
Jan 28, 2008 | Sony 42XBR900 Television
Sony KP-51HW40 51" Rear Projection Television Logo
69 people viewed this question
Top Sony Televison & Video Experts
Are you a Sony Televison and Video Expert? Answer questions, earn points and help others
