PC turns off
When you turn on th PC, it lights up for a few seconds, then immediately turns off. HP Pavilion Slimline s3137c TV PC.
  • Peter Steiert
    Peter Steiert May 11, 2010
    Has the computer recently undergone an upgrade, taken a fall, or been opened? There is a possibility something was dislodged and is causing the system to shut down.
    When you start your computer, do you get any information from the screen? If so, how far along in the boot-up process does it go before the computer crashes?
  • 1,602 Answers
PWER SUPPLY ISSUES, JUST REPLACE PWOER SUPPLY TAKE YOUR OLD ONE WITH YOU, IF YOUR A GAMER OR GRAPHIC OR PHOTO GET A MORE POWERFUL ONE MAYBE 300/400 WATTS
ROD
Posted on Feb 02, 2009
How unlock keys the hp pavilion slimline s7520n pc
Your question is not clear. Can you be more specific?
I'm not sure if you are looking for the BIOS password but here is a guide you might want to use -
1. Turn on your HP Pavilion Slimline computer.
2. Press "F2." This attempts to load your HP BIOS. You are prompted to enter a password.
3. Type "merlin" into the password prompt and press "Enter" to unlock the password on your HP Pavilion Slimline BIOS.
Jun 26, 2014 | Gateway Computers & Internet
How to unlock keys
Try these -
Jun 26, 2014 | HP PAVILION SLIMLINE S7520N AMD Turion 64,...
Install power supply
No Power on an HP Pavilion PC Desktop b> Desktop computers are simultaneously more complex and easier than laptops when it comes to troubleshooting. There are more physical components on a desktop, so locating a specific troublesome part can be tricky, but working inside of a desktop computer is straightforward compared to opening and fiddling with a laptop. Power problems are always hardware problems. There are a few simple, preliminary steps to troubleshooting, but power problems often require opening your computer and having a look inside.
The Basics
Unplug everything from your PC except for the power cord. Try turning on the system and look for lights on the front, then on the back. When the power supply is on (receiving power), the small light beneath the plug turns green. If this light doesn't come on, the problem is either connected to the cord or the power supply. Try swapping power cords with the monitor cord to isolate the cord as the source of the problem. Look closely at the voltage selector and make sure it's set appropriately for your country -- 110 in North America and 220 for most other regions. b> The Socket b> Unplug the power cord and switch the voltage selector to the opposite setting. Wait five seconds, then flip it back. This ensures that the switch is engaged. Plug in the power cord again and try turning on the PC. Check the outlet to make sure it's working, and plug your computer direction into the wall socket (remove it from any surge protectors or power bars). Check the power button. If it sticks when you push it, it may not be making contact to engage the system power and will need to be replaced. If the button is going in and out freely, you've done about everything you can do from the outside of the computer. It's time to go inside. b> Open it Up b> Unplug the power cord and hold down the power button for five seconds. This clears all electrical charges from the circuitry and makes it safe to open the computer. Remove the side panel from your system. This process varies a bit from model to model -- some have one or two captive screws on the back of the system, some have an easy release button. Check your manual. b> Power Button b> Locate the power button from the inside and trace the cables to where they plug into the motherboard. Lift up on the connector and then push it firmly back down. Plug the PC back in to its power source and try to power it on. Unplug the computer immediately if the system doesn't power up, and continue troubleshooting. b> Hardware Components b> Disconnect each of the devices in your computer one at a time to locate a faulty piece of hardware. Power cables run from the power supply connect to your optical drive, hard drive, floppy drive (if one exists) and into several places on the system board. This step takes some trial and error detective work and a few minutes: unplug one device, reconnect the power, and try turning on the system. Then disconnect the AC power, plug the device back in and try the next one. If the system powers up at any stage, the device you are unhooking is shorting out the power and needs to be replaced.
http://www.youtube.com/watch?v=HJvYGtbwmh8 To Replace HP Pavilion Desktop Power Supply http://www.youtube.com/watch?v=VcEFUpZSmI4 Hp Pavilion 750n desktop computer basics on this computer b> http://www.youtube.com/watch?v=D8Y2PPMiiB0 HP Pavilion Slimline PSU Upgrade Guide This guide compares the Sparkle SPI270LE - 270 watt PSU against the Shuttle PC50 -300 watt as possible power supply upgrade for a HP Slimline. The s3600t Slimline I used for this video has a Intel Hope this helps.
Jan 03, 2013 | HP Pavilion 761n PC Desktop
I have a HP Pavilion Slimline, when I turn it on it seems like everything is running fine since I hear the fans and the light turns blue. But my monitor keeps telling me to check my video cable, then goes...
It could possibly be a power supply failure. Make sure all connections are in place.
The only other solution I see to this is a bad motherboard.
Good luck and do not forget to rate me :)
Jan 15, 2011 | HP Pavilion Slimline S3123W Desktop PC -...
How can I turn of the HP blue Invent window? My comuter is HP Pavilion 735N
if window Xp installed on ,just press the window button on the keyboard,once wait for feww sec,press letter U,wait for few sec,then press letter U again.
Feb 09, 2010 | HP PAVILION SLIMLINE S7520N AMD Turion 64,...
Video input
You may need to run the install disk on this computer in order to insure that all drivers are present. Thank you, Dana
Jan 27, 2010 | HP Pavilion Slimline S3123W Desktop PC -...
Connecting xbox 360 to play through hp pavilion
turn on your pc'd TV application and set to the AV in.
Sep 11, 2009 | HP Pavilion Slimline s3400t, Intel Core 2...
Computers & Internet Logo
106 people viewed this question
David Payne
David Payne
