FixYa.com
Tags:
Nikon 20MM F2.8 AF NIKKOR Lens
AF Nikkor 20 mm f2.8 Vignetting
By Luisa_K - usenet poster
I have noticed a very slight light fall off (vignetting) on the corners of the
pictures taken with the AF Nikkor 20 mm. I suspect that this is caused by the
protective Hoya UV filter (not the slim version) on it. I have yet to try the
lens without any filter but I would like to have a filter on at all times.
Is this a problem with the 20 mm? Will a slim filter from Hoya, Nikon or B+W
solve this problem or do I have to live without a filter?
Posted via Deja News, The Discussion Network
# Search, Read, Discuss, or Start Your Own
This Problem has been added to the Share Your Expertise Page under "My Work Queue".
Best Solution
posted on Aug 01, 2007
FixYa! (100)
pawa
pawa - usenet poster
Rank:Apprentice Apprentice
Rating: 0%, 0 votes
If there is a fairly sharp darkening only in the far
corners, this is vignetting, generally caused by a filter
and/or shade that cut into the angle of view of the lens.
If there is a slow roll-off of illumination only at wide
stops, this is normal and it generally is gone by f5.6
in good wide-angle lenses. BTW, much as I like the Nikkor
20mm f2.8 (and consider it one of the very best very-wide
lenses), I do not use it wider than f5.6 (where its
edge/corner performance "hops up" in quality) if at all
possible. (the lens can easily be hand-held at 1/15th, and
even 1/4 second is not difficult...). Lenses have optimum
stops for best performance, and that is one of several
consideration to be included in exposure decisions (which
is partly why I prefer manual exposure determination
to auto modes...).
David Ruether
Was this solution helpful? Show your Appreciation by rating it:
Solution #2
Not Rated (0)
Lizzy
Lizzy - usenet poster
Rating: 0%, 0 votes
My experience with the lens is that @ f2.8 there is noticeable vignetting, @ f4
the problem is still there but far less noticeable, and by f5.6 it is gone. These
were from taking pictures on chrome of a uniformly lit wall (left edge was 0.2
stops under the reading at the right edge, but it was as uniform as I could get).
@ f2.8 I believe the fall-off is something like 1/2 stop, at f4 less than a third.
This test was done without any filter.
Can you Help with these Camera Lenses problems?
Camera Lenses
lens malfunctoin
The image in the viewfinder... Answer This...
Camera Lenses
how can i fix a stuck lens on a...
The lens is out to where it... Answer This...
Camera Lenses
camera lenses and errors
i went to websites to see if my... Answer This...
Camera Lenses
Step up ring.
I have the kenko KUW-042... Answer This...
Camera Lenses
problem
j perdu mon cd d'istallation de... Answer This...
Repair Service
Find Camera Lense Repairman Near You:
FixYa does not evaluate or guarantee the accuracy of any information provided through its proposed solutions, posts, or Expert Assistance Sessions. By entering this site you declare you read and agreed to its Terms. You may NOT copy or distribute the content that appears on this site without written permission from FixYa Inc.
© 2005-2008, FixYa, Inc. or its affiliates
When the original poster rates a solution that was given to his own problem, that rating is locked!
X
Are you sure the solution content is Inappropriate?
Tech buddies can communicate directly to answer questions. Become a Tech Buddy and have direct access to your favorite expert for FREE!
