Question about Audiovox Xpress EZ XM Satellite Radio Receiver with Vehicle Kit
How do i install the xm receiver?
I dont have a tape deck in my car. Is there another way of installing the receiver?
  • 20 Answers
Yes, the unit should have a FM mode where you can use it to transmit the signal over your FM stereo. The unit should come with a FM transmitter and it should be in the instructions on how to install it. All you have to do then is make the unit play on the same station your radio is on.
Posted on Feb 03, 2009
On a kenwood KR597 reciever, where do i hook up my KE597 graphics equalizer. Also must i remove my DP-R797 cd player to hook up my Maeantz PMD520 Cassette deck? Finally divorced
If you only have one set of tape in/out connectors, then hooking up two tape decks and an equalizer is going to be difficult. You could hook the "tape out" to one tape deck, that tape's output to the second tape, and the second tape's out to the equalizer, connecting the output of the eq back to your receiver....
Nov 01, 2014 | Audio Players & Recorders
Need an In Dash XM Radio Installed on 1997 Honda Prelude
well...there is an after market for this, but it's a little high end at this point.
Jun 18, 2008 | XM Radio (XMP6000)
Looking to hook up an audiosource EQ100 to an a sony cass deck
Simply place it in line with the analog input. Or install it in a Tape Loop on your integrated amp/receiver and attach your tape deck to ITS tape Loop.
Ins to Outs
Receiver Tape Out (Rec) - to the External Processor (EQ, whatever) Preamp-, Rec, Line-In;
Receiver Tape In (Play) - from the External Processor (EQ, whatever) Preamp-, Play , Line-Out.
Be advised, using analog processors on digital-capable multichannel elcetronics will only work for analog 2-channel sources.
Mar 05, 2011 | AudioSource EQ-100 Home Equalizer
My 2005 Toyota Camry tape deck keeps ejecting the tape to my XM Radio. I bought a tape cleaner and it also rejects that tape after a few seconds.
Thank you for your question.
Tapes can cause problems if they have a bit or drag on them causing them not to roll smoothly. The chances that this is happening with two of your tapes is unlikely.
This usually means that the sensor switch needs to be replaced. You should take it to a Toyota dealer and get an estimate fixing the problem.
The other option is to simply get a new deck and have it installed by an independent car audio shop.
An estimate from the dealer and a new deck are sometimes not too far apart. It may be time to upgrade.
Feb 20, 2011 | Audio Players & Recorders
KDC-MP532U (Lost ESN # ??)
That will be a problem with the XM box you connected to it, call xm see if thay can help, the radio is just liike a screen for the XM nothing more the box controlls all of it.
Don
Jul 09, 2008 | Kenwood KDC-X590 CD Player
Satellite Radio
 Yes, but it will require a tuner adapter so that your deck will properly recognize XM. However for my deck I noticed that "Sirius" will still be displayed as the satilite provider on the display menu. Confusing but don't cause much concern.
May 22, 2008 | Car Audio & Video
FINDING A RADIO FOR A SEMI TRUCK
Those measurements are a standard single DIN automotive radio.
You need to find a "XM ready" or "With XM controls" radio and install a separate XM receiver box. For example this would be the in dash deck:  http://www.crutchfield.com/App/Product/Item/Main.aspx?o=p&showAll=N&g=300&i=158XRCA350&tp=5684 And this is the XM receiver: http://www.xm-radio-satellite.com/index.asp?PageAction=VIEWPROD&ProdID=3951
I would suggest finding an in dash receiver that also does HD radio as well as XM.
May 16, 2008 | Car Audio & Video
Roady xt and car kit under warranty but part is obsolete
Wow, sounds like a tough break, Personally I would take the XM offer, or perhaps look at Ebay for a new dock. YOu can go throught the warranty process with delphi they usually are simple enough to deal with, but that will be a long process. Wiring it into the radio is still going to require a working dock, and most stock car radios dont have an input. Some will say AUX input or XM ready on them. Now if your car has a tape deck you might try one of those handy tape adaptors that plugs from your dock to your tape deck. You can pick those up at your local electronics store for 10-20 dollars, and they work pretty well. Hope that helps Let me know there is anything else I can do
Apr 11, 2008 | Delphi Roady XT XM Radio Receiver
Help
Just connect you EQ to your receiver as if it were a tape deck: EQ's outs connect to receiver's tape ins (play) and EQ's ins connect to receiver's tape outs (record).
Then you hook the tape deck up to the tape ins and outs on the EQ: Tape deck outs connect to EQ's tape ins (play) and tape deck ins connect to EQ's tape outs (record).
This will put the EQ in your receiver's tape loop. To hear the EQed signal with all receiver sources you'll need to engage the 'Tape Monitor' button or switch which will route the tape loop to the speakers.
Nov 22, 2007 | Technics RS-TR272 Single Cassette Deck
Audiovox Xpress EZ XM Satellite Radio Receiver with Vehicle Kit Logo
262 people viewed this question
Top Audiovox Audio Players & Recorders Experts
John
John
Chinmay Joshi
Chinmay Joshi
Computer Links
Are you an Audiovox Audio Player and Recorder Expert? Answer questions, earn points and help others
