Question about Goldstar MV-1715 1000 Watts Microwave Oven
Plastic piece for turning turntable has partial meleted.
The plastic piece for turning the glass turntable has melted exposing a portion of the metal. This is on my gold star built in microwave. My question is: is it worthwhile to replace the plastic piece or should I replace the whole microwave?
  • Goldstar Master
  • 9,086 Answers
This is a pretty simple, inexpensive fix,
The best place to order parts for this brand is Encompass (formerly Tritronics).
If you don't find the part on their Web site, I would call them with your model number. They are toll-free at 866-779-5835.
Posted on Feb 02, 2009
Melted plastic turntable teeth
If only the teeth, get a new replacement ring . If it has melted so bad that it is part of the m/wave floor, you don't have much choice. Have you tried speaking to manufacturer?
Aug 07, 2013 | Samsung Microwave Ovens
It burns thru the glass trray and melts the wheeled tray holder...
There are two possible reasons for this to occur.
1.there was dirt on the turntable and that carbonized and got so hot that it melted the tray. That heat would've melted the plastic spider as well.
2.the microwave oven was turned on with nothing. or almost nothing, in it: the glass turntable is what is known as "a matching load". That means it is there as a safety precaution, protecting the magnetron, in case there's nothing in the microwave oven when it is energized. As such, the glass turntable can get hot enough to melt. That, in turn, will melt the plastic spider.
If either of those is the case, it is OK to buy a new spider & turntable.
Mar 10, 2011 | Microwave Ovens
I have the CWM 100 - the microwave is only about 1-1/2 years old. It runs, but the glass turntable no longer turns. No matter what we've tried, removing the glass plate, cleaning the wheels of the...
Check to make sure the Spindle that the plastic piece fits on is turning when the oven is on.
If the spindle turns, your problem is either the plastic wheel adapter is worn or not making proper contact with the spindle. You can replace th e adapter by going to Cuisinart.com.
If the Spindle is not turning, you can go to Cuisinart.com and find the nearest repair facility.
Nov 20, 2010 | Cuisinart CMW-100 Microwave Oven
The turntable has stopped turning. is there a
It could be the plastic coupler part #942560. Remove your glass tray and lift up the plastic piece in the middle. It slides off of the motor. If it is broken that is your problem.
Oct 16, 2009 | GE Spacemaker JVM1640SJ Microwave Oven
No heating, turntable does not turn, but clock & lights work.
Check to make sure the plastic on the shelve holders or tuntable guide did not wear and expose metal. If these holders or brackets are wore and exposed metal it shorted out your micro wave. They need to be replaced and a fuse needs to be replaced inside the control panel,
Sep 17, 2009 | GE Spacemaker JVM1640SJ Microwave Oven
Flashing is occurring around the plastic turntable piece which is causing it to melt. Took off and saw that the enamel was pitted around the turntable opening. When I remove the plastic turntable piece, no...
It sounds like you are talking about the turntable tray adapter in the bottom.
What usually causes arcing is the reaction of the RF (microwave) energy acting on carbon. It's great that the motor and orifice are OK. Sounds like you just need to replace the T/T adapter. If the paint is pitted or altered, you need to use a special catalytic paint for microwave cavities to touch it up. The paint's main purpose is to protect the metal from rust but it is a high temperature paint to stand up to the higher temperature of that environment.
Sep 12, 2009 | GE JVM1350BW/WW/AW/SY Microwave Oven
Goldstar 1310W built in
The following parts are in the turntable system: The turntable motor, underneath the floor of the microwave; the turntable coupler, which is like a small plastic piece; the turntable support, either a three-legged or circular piece with wheels; and the glass turntable tray.
It sounds like maybe your turntable support is missing?
You can see and hear a video of how a turntable motor should sound when you rotate it by hand.
If yours is not set to be off via the control panel, and it won't rotate or it sounds like it's grinding, etc., you may have a bad motor or plastic coupler.
To replace either, you need to unplug power, then remove the bottom cover of the oven.
For Goldstar / LG / L.G. help, call 1-800-243-0000 (M-F, 7am-8pm CT, Sat 8-5 CT) and choose the appropriate prompt from the menu or visit here. Goldstar owner manuals can be downloaded here.
Aug 11, 2008 | Goldstar Microwave Ovens
E-wave KOT-152UB glass tray and turning ring melted
Sounds like some metal is involved somehow. If the unit otherwise works, replace the damaged parts. Test with a cup filled with water.
Dec 08, 2007 | Dacor DMT2420 1200 Watts Microwave Oven
Microwave Ovens Logo
99 people viewed this question
Top Goldstar Microwave Ovens Experts
William Miller
William Miller
Devabhakthuni...
Devabhakthuni...
SHARCNET-USA
SHARCNET-USA
Are you a Goldstar Microwave Oven Expert? Answer questions, earn points and help others
