Question about Emerson EWL3706 37 in. LCD Television
At the bottom of the Emerson 32" started to be darker
I called Emerson and they told me to take it to specified TV repair shop. Cost me $129.95 just to look at it. Emerson only covered it up to 3 months, mine was within the year. Good thing I bought a Walmart warrenty. It been there going on 3 months, they had to order the parts. All I got was the runaround from Emerson.
  • kahall Feb 02, 2009
    From the bottom of my TV started getting darker up to 5 or 6 " at the bottom. They said it would have eventually went all the way up.
  • Devon Sacco
    Devon Sacco May 11, 2010
    Not sure if your asking a question here. The tidal of the page says" At the bottom of the Emerson 32" started to ........." I don't think your question came through.
    President:
  • 1,077 Answers
It's possible that the Power Inverter Board is starting to go out. It has 6 small inverter transformers to power the LCD screen. Each transformer powers one section from top to bottom. If you are a do it yourself-er, shopjimmy.com might have one in stock. Those boards are hard to come by right now. But, if you have warranty it might be cheaper that way.
Posted on Feb 03, 2009
Free tv repair advice
Hitachi 42" plasma TV all of a sudden death. Power failure, no lights on the front panels. No signs of life.Found solution through my very honest repairman called Johnny's TV Repair in Hollywood:
There is a kill switch to protect against power surges. Located under the bottom edge nest to where the cable goes in the body, all you have to do is press it back in and voila; LET THERE BE LIGHT and probably save yourself a min $200 trip to the repair shop. Of all the places my friend called non mentioned this switch so next time you have TV problem and can't fix yourself go to this guy if you're in Los Angeles. Johnny's TV 4452 Melbourne Ave Los Angeles, CA 90027 (323) 660-9900 1df09a55-a543-44e3-9508-ff918ce89dd4.jpg
May 26, 2013 | Emerson LC320EM9 32 HDTV LCD TV
EMERSON LC320EMX WHEN TURN ON GREEN LIGHT FLASHES THEN GOES TO RED
Sounds like capacitor/s failing on the power board. This is a common issue and there is lots of literature and even videos on how to perform the repair on web. A shop will charge upwards of $200 for this repair yet if you find the components and only have them change those; perhaps they will work with you on cost. GL!
Sep 12, 2012 | Emerson LC320EMX 32 in. LCD HDTV
The bottom third of the tv is darker than the rest. It is like a light bar burned out. The tv is 3 years old and has had this problem for 6 months now. Can this be fixed?
Hello There,
It looks more like one of the LCD matrix controller connectors got loose or the chip went out for good. I'd open the case to verify for back light on the bottom portion behind the screen; If you see back light, then check for a loose connector in that area, if no loose connectors are apparent, then the matrix controller is bad. You are in for a new TV set.
HDalacarte.com
Feb 27, 2011 | Emerson LC320EM9 32 in. LCD HDTV
My 32 inch emerson powers up and cuts off after a few seconds.
Hi, I own the same TV and had the same problem. It's the #1 plaguing issue with flat panel TVs made by Funai corp. Emerson is made by them. Normally, when this happens, the TV goes into " Protection Mode " because of a failing circuit board.
The most common thing to go out on flat panel TV is the circuit board that supply power to the screen. Commonly called a Backlight Inverter Board. But, I can't say it's 100% the problem because I can't actually look at the tv over the internet. I can only make guesses with the symptom. I'm willing to bet you have the same problem like mine. One of six Inverter Transformers when bad on my Power/Backlight Inverter Supply Board. I replaced it and it works fine again. d66cb18.jpg
You have a few choices:
1. You can try leaving the TV unplugged for 30 minutes so the TV can reset itself.
2. If you have some electronic experience, if you can find and purchase a Service Manual at Tvtechcenter.com:
http://www.tvtechcenter.com/xcart/search.php?mode=search&page=1 It will help you diagnose the source of the problem and fix it by soldering in the new part. The Service Manual will give you circuit diagrams, test points, and part# lists.Usually, cost under $6. And most cases the new part cost less than $15.
http://www.partstore.com/Part/Funai%20Corporation%20Inc/Funai/LTZ2PC0MS008.aspx
http://www.encompassparts.com/products/?LTZ2PC0MS008
3. Pay a TV shop to do the repairs. It maybe costly, but get an estimate of how much they will charge. That way you can decide if it worth repairing or replacing the whole TV.
Sep 10, 2009 | Emerson LC320EM8 32 in. LCD TV
My tv starts to turn on then goes off???
2. If by chance the TV is still under warranty, go that route.
3. If you have some electronic experience, if you can find and purchase a Service Manual at Tvtechcenter.com; It will help you diagnose the source of the problem and fix it by soldering in the new part. The Service Manual will give you circuit diagrams, test points, and part# lists.Usually, cost under $6. And most cases the new part cost less than $15. The service manual at the site is under LC320EM82S.
4. Pay a TV shop to do the repairs. It maybe costly, but get an estimate of how much they will charge. That way you can decide if it worth repairing or replacing the whole TV.
I hope I shed some light on the subject for you.
Jul 02, 2009 | Emerson LC320EM8 32 in. LCD TV
My smart set radio stoped working
This clock/radio may not be repairable. If Emerson does not support the repairs, service center cannot get the parts to repair it. That is more or less what they told you. These clock/radios are short production runs and that does not allow for a lot of extra parts and service information.It would probably cost you as much to repair it as it would cost to buy a new clock/radio. That is if you can find a place that will repair it. I hope this information helps you with your problem.
Jun 08, 2009 | Emerson Smartset Clock Radio
Won't turn on
I want to save you time and money here.
A new TV just like the one you have at Walmart cost $189.
A TV repair shop will most likely charge you $100 just to look at it. And the part, Backlight Inverter/Power Supply Board ( I believe that is broken ) will cost $110 min ( That's a used part).
It would definitely cost more than $210 to repair the broken TV vs buying a replacement 19" TV at Walmart for $189.
May 25, 2009 | Emerson LC195EM9 19 in. LCD TV
Emerson EWL3706 37 in. LCD Television Logo
132 people viewed this question
Top Emerson Televison & Video Experts
matt martin
matt martin
 Grubhead
Grubhead
Are you an Emerson Televison and Video Expert? Answer questions, earn points and help others
