Question about Kenmore 56549 / 56542 / 56544 / 56546 Side by Side Refrigerator
White door handles for Kenmore Model 106
I need to replace the door handles on a white Kenmore Model 106 9555722 side by side refrigerator manufactured in August 1996.
Any help would be greatly appreciated.
  • 833 Answers
SOURCE: pink fluid under refrigerator
Loklok...no, I don't think so. The only fluid in refrigerators is an oil which is sealed in the cooling system and we know you are cooling. Your fridge may need a full defrost. This occurs because you may have left items uncovered and the moisture condensed in the cooling coils. It could also be the result of improperly sealing doors caused by dirt/ bad gaskets or the like. Best thing to do: shut it off, open the doors and let it defrost fully for a day. Clean the condenser coils under the unit with a long brush. Dry out as best you can and restart. You'll likely be okay. Make sure your freezer side is at about 0-5 above...refrigerator side 35-45. Use a regular thermometer and leave the door closed for at least an hour. (Do these measurements a day after you've restarted.)
Posted on Jan 28, 2008
SOURCE: GE Side by Side refrigerator door handles yellowing
I have tried everything to clean these handles. This refrigerator was a piece of junk from the onset. The fan on the ice maker has had to be replaced twice and the motor once. The ice maker has always leaked and frozen. This was extremely disappointing and I will not be buying GE products again!
Posted on Apr 05, 2008
aborcass
  • 2651 Answers
SOURCE: yellowing handles on Maytag side by side refrigerator
only solution is to relpace the handles, there are 3 parts to each upper, middle nad lower here are teh part numbers youll need 2 of each, both the freezer and refrig are the same parts
61005445 handle upper
61005494 handle lower
61005609 handle main
Posted on Jan 25, 2009
SOURCE: kenmore refrigerator model 106, 2doors, ice forms
I had the same problem and discovered that the water control valve was not shutting off completely between cycles. The water seeping through the valve was freezing in the water inlet tube. I replaced the water control valve for the icemaker and solved the problem.
Posted on Mar 02, 2009
How do you reverse the door on a kenmore cold spot 106?
Take door off, reverse the handle and hinges to other side of door and reinstall.
Mar 04, 2016 | Kenmore Refrigerators
Kenmore coldspot 106 door handle is loose
Gently slide the handle up until it releases. Then slightly turn the screw underneath it, and slide the handle back on. Do this until it fits properly.
Jul 28, 2013 | Refrigerators
The white plastic(?) full length door handles OUTSIDE the refrig are turning yellow on my white, side by side refrig. What can I purchase or use to re-whiten them and make them look clean and white again?
That yellow coloring is most likely a result of the white paint coming off, and the yellow plastic color showing underneath. Other than painting them with a good paint, which you would have to ask a paint expert for the proper type, my suggestion is to replace the handles altogether.
Oct 13, 2010 | Kenmore 55612 / 55614 / 5561 / 655619 Side...
On my Kenmore Elite #106.56683501 the refrigerator door is loose
Depending on the model, and the color, here's your fix.
Stainless with stainless handles- you'll need a hex key. The tiny hole is on the inside of the handle, close to the center. Turn the key until it's tightened.
Stainless with black handle/white/bisque/black- push the door handle up. Careful not to scratch the finish! once the handle pops, pull it straight off. Take a phillips head screw driver, tighten the top screw A LITTLE BIT and then attach again. Insert screws on the door into the holes on the handle, slide down. (will need to be a little tough with it.)
Sep 03, 2009 | Kenmore 56549 / 56542 / 56544 / 56546 Side...
No ice from icemaker of Kenmore Elite model 106
I just resolved an issue with my kenmore elite side by side refrigerator icemaker (model 106).
It was expensive because I took the long road to fixing the unit myself.
My problem: No water going up to the freezer water dispenser into the icemaker but the water in front of the door working just fine.
-first thing i tried was the simplest. The Internet is clogged with this miracle fix of using a hair dryer to melt the frozen water line going to the dispenser output. This is highly unlikely for our model since the water line is protected within the refrigerator frame.
-2nd thing I replaced my water filter (thinking that there wasn't enough water pressure to trigger the solenoid valve. $40, and still no luck.
-3rd thing was I tested for voltage going to the solenoid. No voltage going to solenoid, so I wasted $30 for a new solenoid.....still no water.
-4th thing was I ordered a new IR sensor and receiver (since the reciever end is where the relay that sends the voltage to the solenoid to turn on and allow water to go up to the dispenser).
My IR sender and receiver appeared to be working flakey.
Installed, still no water. $58 BUCKS ON EBAY (EVERYWHERE ELSE $100+)
-I finally removed the freezer front little white door, I TURNED OFF THE FREEZER SWITCH SO NO VOLTAGE WAS PRESENT, removed the release latch underneath the freezer unit and disconnected, and removed the freezer unit to inspect it further.
When I removed the protective white cover that covers the mechanical wheel, I had a few parts come flying out of it. Turns out that the wheel accessories were damaged. THERE ARE NO REPAIRABLE PARTS ON THE FREEZER UNIT. I FOUND ONE ON EBAY FOR $39 BUCKS + $9 SHIPPING! $48 BUCKS, SWAPPED THE HARNESS AND BOTTOM COVER, AND IN 20 MINUTES, I WAS BACK IN BUSINESS. STARTED MAKING ICE IN ABOUT A HALF HOUR!!!!!
when in doubt, replace the freezer unit for $48 bucks! 7 out of 10 times it will fix your problems. All techs replace the IR set at the same time too which will set you back another $58 bucks.
Good luck! ;)
Feb 23, 2009 | Kenmore 55612 / 55614 / 5561 / 655619 Side...
Kenmore water on floor
Hi!!! You could have a plugged drain line. Open your freezer door and remove the bottom tray and look to see if you have ice on the bottom if you do then its a frozen drain line get a hair dryer and and apply heat to the bac evaporator fins and all the ice..sometimes also some sxs refrigerator model leak a small amount of water right after you use it..Good luckk..
Jan 03, 2009 | Kenmore 57029 Side by Side Refrigerator
Kenmore 56549 / 56542 / 56544 / 56546 Side by Side Refrigerator Logo
239 people viewed this question
Top Kenmore Refrigerators Experts
Sal De GO PATS
Jim Goldsmith
Jim Goldsmith
Arnel
Arnel
Are you a Kenmore Refrigerator Expert? Answer questions, earn points and help others
