Question about Toshiba 57H81 57" Rear Projection Television
Toshiba v43j22p 42" red shadows and lines over screen
Red does not adjust to the right can adjust colours at bottom off screen but out at top any ideas
  • Toshiba Master
  • 3,459 Answers
toshiba v43j22p 42 You may have a convergence problem. Here are some of the most common symptoms.
  • Screen looks 3D
  • Colors don't line up
  • One or more colors can't be adjusted when using the convergence menu.
  • Screen is bowed or warped.
Here is a quick test....
Using your original remote go-to the tv settings then goto the convergence section.
Try to adjust the red and then the blue convergence.
You should be able to move them up, down, left, and right.
If you can't move them in all directions your convergence chips are bad and should be replaced. This is a common problem.
You need to replace the convergence chips and convergence resistors. Check the site www.TvRepairKits.com. They have put together a kits for most models. If you don't see a kit for your set send them a quick email and they will put one together for you. Their kits includes photo instruction guides, original Sanyo STK chips, convergence resistors, pico fuses, etc.
Posted on Feb 05, 2009
Coloured lines down the right side of screen
if the lines extend top to bottom and are thin, then the LCD panel is most likely defective.
Oct 21, 2010 | LG 42LC2D 42 in. LCD HDTV
BLUE SHADOW
Replace optical block Call Encompass Parts
1-800-638-3328
Jan 18, 2010 | Samsung HCN4226W 42" Rear Projection...
Mitsubishi TV Model #WS65903 - Green Shadow Lines on Screen
Something is not right here--The green is adjustable in the TECH menu--did this person adjust or try to adjust in the customer or the TECH menu?
If you confirm actual model number I can tell you how to get into the TECH menu--yes--green will not adjust in customer menu--it determines geometry and is only adjusted in the TECH menu.
Also, this set requires any convergence adjustments to be done in 480 and then in 1080--if only adjusted in one mode the other will still be bad.
Let me know if you know how to adjust in TECH menu or not--with exact model number I can tell you how to get there.
If this helps you rate this solution as I do this here for free.
SD TECH
Dec 20, 2009 | Mitsubishi WS-65809 65" Rear Projection...
Plasma tv problems
Thanks for the photos, it looks like an internal adjustment is required to the ramp generator which controls the sequence for the screen to refresh itself from a previous image to a new image. This is a precise setting & also a software update may be necessary to cure the problem. These settings are on the Y-Sutain board & need to be accurate.If this procedure does not cure the problem then the screen will need replacing. As it will out of warranty, it would be best to contact a local repair centre & ask for an estimate to try & set these adjustments for you.
Sep 23, 2009 | Televison & Video
I have a yellow line on the right side of my Toshiba 50 rear projection TV and yellow shadows around people
It sounds like a convergence problem---go into the customer menu and select convergence---set should offer center and multipoint adjustment--in the multipoint look to see if the outer crosses adjust--if red or blue will not adjust somewhere--bad convergence IC's.
Jul 17, 2009 | Toshiba 42H83 42" Rear Projection...
3 year old rca rear projection just started going blurry. green blue and red line across the top of screen. objects have shadow.
Focus and screen control box / remove front bottom panel there you will find it / it has 3 controls on top 3 on bottom top are focus for RGB tubes bottom controls adjust screen drives for RGB.
Jan 25, 2009 | RCA D52W23 52" HDTV CRT TV
Ghost like shadows
It seems your TV Samsung HCM4215W has problem in convergence board and need to be replaced.
You can get that board from Parts Store on $76
If you have bit electronics knowledge and know how about tv repair, you can replace it by yourself or get help of local tv tech person.
Oct 06, 2008 | Samsung HCM4215W 42" Rear Projection...
Color convergence alignment
change your convergence ICs that should solve your problem.If you need more info let me know.
Apr 08, 2008 | Toshiba 42H81 42" Rear Projection...
Convergence adjusting
you need to replace the 2 stk-110's mounted to the heat sink
i had the same problem
and works pretty good now
Dec 26, 2007 | Toshiba 42H81 42" Rear Projection...
Toshiba 42H82 convergence problem
Replace STK convergence IC's w/OEM or better parts.Senior tech soldering ability needed. Ex==Steel jumper wires feeding b+ to conv. IC's need resolder to prevent call-back.Also, best re-alignment done in service mode==consult service literature.
Sep 19, 2007 | Toshiba 42H83 42" Rear Projection...
Toshiba 57H81 57" Rear Projection Television Logo
64 people viewed this question
Top Toshiba Televison & Video Experts
Jaime Hernandez
Are you a Toshiba Televison and Video Expert? Answer questions, earn points and help others
