Question about Jenn-Air JGS8850ADS Gas Kitchen Range
Digital panel on front of stove won't light or come on.
This is a new installation. The gas burners work....the digital read out panel will not activate. Gonna bring back to Home Depot in two hours.
  • humeston Feb 03, 2009
    Installing contractor was leaving me with this piece of **** & I was hoping for a quick solution from someone who might know something. Silly me!!!
    Sergeant:
    Champion:
  • 338 Answers
So why post the question?
Posted on Feb 03, 2009
  • Robert Artiaco Feb 03, 2009
    Quick solution is to replace the board. however i would believe from your statements that is not adequate enough for you. Sorry. For a fast solution you should have talked to a live expert. you could have had an answer in minuites
Igniter glows but why doesn't burner light?
Igniter could still be faulty(not hot enough) or burner control valve
faulty. press the helpful button and check link videos below
Gas Stove Top Burners Not Lighting Not Working
Gas Stove Ignitor and Burner Not Lighting
Daddy Chores Gas range won ignite How to fix it
Jan 22, 2016 | Kitchen Ranges
Burner don't light no spark
the starter module that controls the TICK/TICK spark, is located in the main board, Digital Clock. To access it slide out the stove, screws are in the back, panel access and you will see the wires going into it, just take out the old board and replace with the new one. Not hard to do, my board was 200, but a new stove was 900. you can light it with a BBQ lighter for $2. My oven kept shutting off.
Mar 04, 2015 | Kitchen Ranges
JDS9860AAP Front e-burner does not light.
follow this instructions. God bless you
    • 1
      Unplug your unit and turn off the gas supply at the saddle valve near the unit.
    • 2
      Lift up the hood of the oven. If you have sealed burners, the lid will not lift up. Locate the ignitors near the burners of the unit. Clean any gunk away from the ignitor using a toothbrush. Test the unit.
    • Sponsored Links
    • 3
      Pull the burner dials off the front of the unit if the ignitors won't work.
    • 4
      Remove the screws at the ends of the front cover, where the gas supply knobs are located, using a screwdriver, and remove the cover from the oven.
    • 5
      Slide the wires off the burner valve switches and pull them off the burner valve by sliding the switch forward. The switch will have wires attached to it. Loosen the screws holding down the wires of the burner valve. Pull out the wires carefully. Place the wires in a new switch. Slide the new switch onto the burner valve. Replace the knob, and turn on the gas supply and power. Ignite the burner.
    • 6
      Follow the switch wires into the oven if the new switch doesn't work. Locate the module box, which is usually 2 inches by 3 inches. Slide the wires out of the module terminal by pulling on the wire connectors. Remove the screws from the old module and pull the module out. Insert the wires into the new module, using the same wire orientation as before. Reassemble the oven. Turn on the electricity and gas, and turn on the burner.
Read more: http://www.ehow.com/how_7925141_repair-electronic-ignition-gas-stove.html#ixzz2ZPuc5nad
Jul 18, 2013 | Kitchen Ranges
Stove burners won't light
sounds like the igniter is faulty try a local h/ware or plumbing shop for a new piezo ignition
Feb 02, 2013 | Hotpoint RGA524 Gas Kitchen Range
I have a maytag gemini gas stove three igniters work but won't light the burners. One igniter won't spark
Replace the "igniter switch assembly". The igniter's are getting a weak spark and since you have one that will not spark at all, this is the usual problem. Here is the assembly to order.
The part comes with a 365 day, any part, any reason return policy.
Nov 12, 2012 | Maytag MGR6772BDS Gemini Gas Kitchen Range
Clicking sound on my gas stove
there switches behind each knob, 1 of them is broken,or wet, when you remove the knobs then remove the knob panel you can test them and find the bad one,they are no more then $15.00 each. to test you can plug the stove and disconect the switches one at a time until you find the bad one replace and you are back in bussines.
Dec 11, 2008 | Maytag MGR5770 Gas Kitchen Range
KItchenaid supera gas stove
thers is a thermal cut-offs under the main control area little black thermostat one controls display andother turns fan on/off
Feb 08, 2008 | KitchenAid KESC307 Electric Kitchen Range
General Electric stove top burner does not light
whalerpaul, To get access to the gas burner valves you have to: 1.UNPLUG THE POWER CORD 2. Remove all burners 3. There are 2 screws under each burner, remove all of them and lift up the top panel 4. Remove all knobs, remove screws holding the manifold panel (two on top and four on the bottom) 5. Carefully pull out the manifold panel and remove two wires from the oven light switch, put the manifold panel on side Part number for the right front gas burner valve is WB21K12 and you can buy it here: http://click.linksynergy.com/fs-bin/click?id=SrmyP8LkIos&offerid=92089.542247749&type=10&subid=
Jan 14, 2007 | GE Profile Spectra JGBP90 Gas Kitchen...
Jenn-Air JGS8850ADS Gas Kitchen Range Logo
165 people viewed this question
Top Jenn-Air Kitchen Ranges Experts
Mike Carew
Dan Webster
Dan Webster
Richard Roth
Richard Roth
Are you a Jenn-Air Kitchen Range Expert? Answer questions, earn points and help others
