Question about Sony KV-32S40 32" TV
The picture flashs on and off and was wondering how to fix it myself... Robert rluxmore@rogers.com thanks the picture flashs on and off can you help me.
  • Anonymous Feb 14, 2009
    i have no idea but mine is the same i cant watch it like thiis
  • Sony Master
  • 8,457 Answers
U know how to solders?Take a backside of a screw driver hits the video board hook to crt long neck ,where flashes,resolders that parts or replaced it.
Posted on Nov 13, 2009
  • Chi Chu Nov 13, 2009
    Know how to solders?Take the back of screw driver hits the video board,where flashes resolder it or replaced it.
Where is the IAC valve on a 2003 Cavalier? - pictures would help. thanks
Hello ptrecek: My name is Roger ans I will help you. The idle air control valve or IAC is located on the side of the throttle boby. I have attached o picture that should help. Should you need further help please just ask. Please rate the answer. Thank You for using Fix Ya. Rogerrogerf1_49.jpg
Aug 13, 2011 | 2003 Chevrolet Cavalier
Whers the location for flasher plug? my turn signels flash when they feel like it. I got a replacment.
Hello mak2tis: My name is Roger and I will help you. You will find the flasher located in the left side of the dash. Remove or lower the hush panel. Look up above the left side of the dash area. You should see a relay panel. The flasher should be bottom row farthest away from the steering column. I attached a picture to help in locating the flasher. Should you need further help please just ask. Please rate the answer. Thank You for using Fix Ya. Rogerrogerf1_30.jpg
Feb 21, 2011 | 1997 Buick Skylark
I have a loose bearing on cummins engine where fan bolts and am wondering if that is the water pump as on gas engines?
Hello bigjohntucke: My name is Roger and I will help you. The part that the fan blade rides on is just a idler unit. The water pump has a smaller unit that sits to the left of the bigger pulley that the water pump mounts to. I happen to have one of these motors out at the moment and the parts are easy to see. I looked in my manuals and there are no clear pictures or I would send one. Should you need further help please just ask. Please rate the answer. Thank You using Fix Ya. Roger
Jan 26, 2011 | 2001 Dodge Ram 2500 Truck
Need instructions as to how to put a clutch on myself
here are some basic instructions
http://www.mr2-tech.com/bgb/mechanical/volume2/clutch.htm
Robert
Please take a moment to rate this solution thanks
May 22, 2009 | 1996 Toyota Celica
Wont turn on
FBT is most likely to be bad cost depends 150.00 maybe more .
Dec 12, 2008 | RCA D52W19 52" Rear Projection Television
Capacitors on DM Module
I just fixed the capacitors on my WS-65713. I can email you instructions with pictures if you wish. You will need to de-solder and solder on new capacitors but if you check out video instructions on utube you should be okay with some practice.
Jul 29, 2008 | Mitsubishi WS-65713 65" Rear Projection...
Trutech PVS21175S1 17" Flat Panel LCD TV
I HAVE THE VERY SAME PROBLEM!!!  HAS ANYONE FOUND AN ANSWER TO THIS PROBLEM???
THANKS LOADS!!!
May 25, 2008 | TruTech PVS31170S1W 17 in. LCD Television
Blackberry 8700c
You maybe able to request thru cingular if that is your provider to unlock the phone. If it shows cingular it was a cingular phone.
Jan 26, 2008 | RIM BlackBerry 8700c Cellular Phone
Does the sound still work when the picture shuts off? Also does the light in the front blink in any sequence?
Jan 05, 2008 | Sony KV-35S40 TV
Sony KV-32S40 32" TV Logo
129 people viewed this question
Top Sony Televison & Video Experts
Are you a Sony Televison and Video Expert? Answer questions, earn points and help others
