Question about Lexmark Wheelwriter 3500 Typewriter
Faint printing on checks
When typing checks especially, the print is very light and the bottoms of the letters do no print. The longer you type, the worse it gets.
Have tried to get a different ribbon but office suppliers says they have been discontinued. My typewriter is an IBM wheelwriter 3500, and I'm using a IBM Easystrike superior cassette, #1380999. The manual says this cassette is not recommended for checkwriting, but cannot locate any other recommended ribbon.
  • 4 Answers
The reason Lexmark/IBM do not recommend the use of correctable ribbons for typing checks (cheques) is that they can sometimes be easily altered (ie forged) using nothing more than Selotape, or for a good quality forgery using another similar model with the same typestyle and precise alignment you can simply 'correct' and overtype the value of the cheque. The multistrike non-correctable ribbon is recommended for negotiable documents.
In your case, a probable cause for the poor printing is a coating on the check paper which is not adhering the carbon ribbon, but it may be made worse by a poorly adjusted machine and would be the case where you say the bottoms are cut off. This can either be the height of the characters in relation to the platen, or the ribbon adjustment is wrong. If the characters are printing very close to the bottom edge of the ribbon it may need adjusting.
Posted on Feb 01, 2015
    New Friend:
Code Q darkens the print, I keep my on 3 when typing checks.
Posted on Jan 29, 2015
  • Lexmark Master
  • 3,594 Answers
To my knowledge the 999 ribbon is the best avaivable. Try these things. put a little light (WD40 works well) oil on the back side of the print solenoid, then perss code and "Q" the display will show 1,2 or 3 set it at 3 and then try code "B" for bold print. These should help.
DickyO
Posted on Feb 12, 2009
SOURCE:
My Brother ML100 is not printing what I type
Hammer sticking and typing incorrect letters (and or skipping letters): 1) make sure daisy wheel installed correctly. 2) hold down CODE key & Q (RESET) to reset wheel...if still not corrected 3) WD40 the hammer at the base & joints where moving parts are, keep typing until oil seeps in (this last one fixed it for me)
Typing light and inconsistant-top part of letter okay but bottom too light or not there: to left of hammer (at base) are 2 screws, I losened them and adjusted hammer to different forward and backward spots..finally found the ideal location where full letter printed and had the correct force it needed to print correctly.
Feb 21, 2013 | Brother ML-100 Typewriter
When I type half of the letters or numbers are printing
You didn't give a make or model but if it is an IBM wheelwriter press down firmly on both ends of the platen they do work loose.
DickyO
Jan 04, 2013 | Office Equipment & Supplies
Nakajima typewriter model AE830. New ribbon installed. when typing printed letters appear only lightly printed on paper. Any way to adjust?
Check to see if the ribbon is moving, then advance the ribbon manually about 6 inches, the ribbon may be old and they do go bad especially the exposed part. If the ribbon isn't advancing Code peroid, comma or slash will get you out of the overstrike mode.
DickyO
Jun 24, 2010 | Nakajima Office Equipment & Supplies
When typing, all of the letters do not print,
There are two possibilities, Most likely the print solenoid cap is broken but the solenoid may just be gummy. The sol. is just inside the L. printer side frame just L of the selection motor, just in front of and directly below the small blue rubber damper. Spray some WD40 on the rear of the solenoid. If that dosen't help we sell the solenoid cap with shipping and instructions for 20.00.
DickyO
Cleveland Business Machines
216-241-0027
Apr 29, 2010 | Lexmark Wheelwriter 10 Series II...
I have a really old SD 660 and I no longer have manual. It is printing great but it is not typing correct letter for example when you type a it prints the letter p and so on?
Remove the printwheel check for bent spokes, look for debris in that area, try it without the correction tape, check that the correction tape is dry not tacky, also check to see if the pitch selection isn't in PS proportional space. If allis good the homing pawl spring is probably broken, you need a tech.
DickyO
Jun 26, 2009 | Smith Corona Office Equipment & Supplies
When typing does not print whole letter or doesn't print at all.
it would help if i knew exactly what model # we are talking about. but try this. look closely at your ribbon film after you type some characters. are the letters overlapping themselves? if so, press and hold the "code" key down while pressing the period key. let up and try typing. if that doesn't help, write back with model # and maybe i can assist further.
razors
Mar 30, 2009 | Swintec Office Equipment & Supplies
Everytime that I try to print a document, I am getting a lot of boxes. I am not getting the words printed that I need.
Hi Goody2Shoes6, what a great nickname!
If the boxes are a rectangle for every letter, try changing the font, especially if the printer is an old model and the font is recent, if it does it for every font, type up a letter (or type =rand(3) in word and it will put some blurb up for you) then press the Alt key at same time Print Scrn key. Then open paint and go to edit menu / paste. go File Print preferences and set the page to 1 by 1 pages, File / Print preview, if good Print.
The printer should print it, as it is taking it as a picture file, if that same font won't print straight from word (and gives you little squares) it means the printer doesn't have that font listed in it's memory
If it is the case, buy a new printer, or use an older font that works.
Sep 29, 2008 | HP Computers & Internet
Wong letters & numbers
I downloaded the manual from http://www.devicemanuals.com/downloadguide.php and then, following the instructions there, I removed then re-inserted the daisy wheel. This solved my problem. Perhaps it had somehow gotten out of adjustment. At least, it is something to try if you haven't tried it already.
Jul 15, 2008 | Brother GX-6750 Typewriter
Skipping parts of the letters
If the ribbon isn't moving a full space for each letter printed try code . or , this changes yhe spacing.
DickyO
Feb 19, 2008 | Nakajima AE-740 Typewriter
Lexmark Wheelwriter 3500 Typewriter Logo
266 people viewed this question
Top Lexmark Office Equipment & Supplies Experts
Clive
Clive
Ekse
Thomas F. Schneider
Are you a Lexmark Office Equipment and Supply Expert? Answer questions, earn points and help others
