Question about Hoover H3045 Vacuum
Will not pick up water
I have a hover floormate H3045. It will not pick up any water. It is almost new so what can i do to fix this.
  • 257 Answers
Hi, Make sure you have the selector switch set to position "C" Wet Pickup. release the trigger. make sure the recovery tank is empty and clean as well as the filter in the top of the tank as there is an automatic shut off valve in this tank. All of these parts are washable and if you have been using it dry it still needs to be cleaned. You also need to make sure it is all back together correctly so it seals. Good Luck!
Posted on Feb 02, 2009
  • Jim London
    Jim London Feb 04, 2009
    Hi, I hope I solved your problem, Please rate my response, your
    favorable ratings help others that may have the same or similar
    problem. Thank you!
My new hover floormate is running very loudly and it smells like burning rubber. it seems to be working okay otherwise.
If it's new ( as in less than 30 days ) take it back where you bought it and get it repaired or replaced. If it's over 30 days take it to your nearest Hoover warranty station. It shouldn't smell like burning rubber.
Oct 13, 2013 | Hoover Floormate H3000 Upright Wet/Dry...
My hoover floormate hard floor cleaner is not sucking as stong as it use to. What can I do?
Sounds like the squeegee may be old and need to be replaced. Check that first. If you need a new one you can follow this link.
part number 93001095
http://www.usavacuum.com/h3040-h3044-h3045-s/213.htm
Feb 21, 2010 | Hoover H3044 FloorMate SpinScrub Wide-Path...
Hoover Floormate--Does not pick up water.
First make sure that you are getting suction from the bottom of he machine. Most of the time the squeegee is worn out which does not allow it to pick up the water like it use to. Turn over the machine and inspect the squeegee. If it looks worn or bent then it may be time to replace it. You may also consider replacing the filter. These are the two most common parts that wear out.
here is a link the parts for your a h3000 floormate
H3000 Parts
Feb 07, 2010 | Hoover Floormate H3000 Upright Wet/Dry...
HOOVER FLOORMATE SPINSCRUB WILL NOT PICK UP WATER
First make sure that you are getting suction from the bottom of the machine. Most of the time the squeegee is worn out which does not allow it to pick up the water like it use to. Turn over the machine and inspect the squeegee. If it looks worn or bent then it may be time to replace it. You may also consider replacing the filter. These are the two most common parts that wear out.
here is a link the parts for your a h3030 floormate
Hoover H3030 Parts Link
http://www.usavacuum.com/category-s/86.htm
Jan 16, 2010 | Hoover H3030 FloorMate SpinScrub 500...
Floormate stopped vacuming water
I'll answer last question first. Your floormate has a 1 year warranty. And should be taken in for repair.
Your issue of not picking up water, is related to suction and getting the dirty water to the recovery tank. check for obstruction in the nozzle, check the filter for debris clogging. If you have an issue with this dealer I would call customer support.
Sep 26, 2009 | Hoover Floormate H3000 Upright Wet/Dry...
Floormate will not **** dirty water.
Check the hose coming out of the floor assembly. It tends to split, keeping it from picking up the water
Apr 20, 2009 | Hoover Floormate H3000 Upright Wet/Dry...
Hoover FloorMate won't pick water up
Check for the filter in place and it also requires a filter lid for proper suction or it will not work
Jan 23, 2009 | Hoover Floormate H3000 Upright Wet/Dry...
Hoover floormate.
Can't do it. The machine vacuums in both scrub and pick-up. Sorry.
Kirk Thompson
San Juan,PR
Sep 01, 2008 | Hoover Floormate H3000 Upright Wet/Dry...
Hoover floormate plus model #H3010
It seems to be a common problem with this series of floormate... some home quickfixes (a hassle, i kno) but put downward pressure while using the solution.... Check your warranty that came with it, and how long you purchased the floormate... Alot of vaccuums come with 30-90 warranties, I'd recommend having it checked out. That, or if u bought it recent enough,take it back... like i said, these models are unfortunately known to have this problem... Some people have ones that operate normally, but alot do not. >.<
Jan 09, 2008 | Hoover H3030 FloorMate SpinScrub 500...
Hoover H3045 Vacuum Logo
Top Hoover Vacuums Experts
Gerry Harvey
Gerry Harvey
Are you a Hoover Vacuum Expert? Answer questions, earn points and help others
