Question about Dishwashers
Siemens dishwasher, water supply interupted
We turned the water off in error whilst the dishwasher was running and now it wont work properly. The check water light was lit.
We checked the manual and it corresponds with water supply interupted but doesnt tell us what to do to sort it.
Please can you help
    Problem Solver:
  • 19 Answers
I'm sure you disrupted the sequencing! If its full of water, drain it. If its got no water in it, then manually fill it! This should get you back into sequence and up and running.
Posted on Feb 05, 2009
Siemens SR65E000EU dishwater check water supply indicator flashing, wont power off. Any ideas on the issue? Water supply seems fine. Thanks.
Sounds like no water going into the machine. If you have already checked the stop tap and the hose isnt kinked, then you probably need a new solenoid
Jan 31, 2018 | Siemens Dishwashers
We have a Siemens dishwasherSN66T091GB. The unit is not showing a fault code but the 'tap' light and 'rinse aid' lights are flashing continuously.
Tap symbol indicates a water problem.
Check that the water supply to the dishwasher has been turned on.
Check that the water supply hose hasn't bent or kinked.
Check the water supply first, see what you find.
Rinse Aid symbol light indicates low on rinse additive.
Hope this helps?
Oct 16, 2016 | Siemens Dishwashers
Siemens Dishwasher Fault
there is a water level sensor in the bottom of the machine if this is faulty and stays on, this will indicate to the pump there is water still in the machine. I would check this sensor it might be blocked with debris and has blocked in the closed position. that woudl be the best start for this issue.
i hope this was useful.
Feb 15, 2013 | Dishwashers
Siemens dishwasher has stopped taking in water red light on indicating this problem, I have checked water supply that's ok
Click this link for tips : Inlet valve
Check the voltage to the valve to confirm that the control panel is working,
Jan 24, 2013 | Siemens Dishwashers
Dishwasher wont stop working
You will have to check if the dishwasher pump is constantly running . If the only way you can stop is by turning off the power supply, the float switch has tripped. This means ther is either water collected at the base of the dishwasher due to a leak or the float switch is faulty. ther may be an error code on the panel if this is the case.
Jul 18, 2012 | Baumatic 23 in. BDW13 Built-in Dishwasher
I have a Bosch SHE4AM15UC Dishwasher that short cycles. After about 2 minutes it quits and the clean light comes on. The unit doesn't fill with water and the soap dispenser does not open when this...
they will send out an engineer not supply you the part while still under warranty if you fit parts under warranty you will in validate it get the engineer out.
Mar 03, 2017 | Bosch SHX65P05UC Dishwasher
Siemens dishwasher pump runs while door open wont turn on!
There are a few possibities...
if you remove the lid and take the two t20 screw off the left side panel at the front you could check the pressure chamber and its hose are not blocked. Use the link and go to page 4, part 263834 and 361113. You can also remove 165263 (remove t20 screw via the sump after all filters are removeds) this will expose the pump impellor and you can check for any obstruction. There may be water in the base of the d/w (base as below the tank, not under the filter) this will activate the flood safety and give the scenario you have described, so check valve, hoses etc for leaks. You will have to manual clear the water from the base pan to deactivate the safety device. Sit the front of the d/w on a large tower and tip the whole unit forward, the base water will then come out. Whilst you have the side panel off, check that the red rod connected to the pressure chamber is not activating the microswitch. ps I appreciate the link is not for your model but the part placing should be the same.
I hope this helps, Good Luck.
May 11, 2010 | Siemens 24 in. SL84A305UC Built-in...
No water in the dishwasher Bosch SHX43M02-48. We turned of the water and forgot to turn it back on and ran the dishwasher. Now the it will not let water in?
Hi, By the information you've supplied, I'd guess you burnt out the coil in the water/fill valve by running it without a water supply to the valve. Are there any other unusual symptom's or error codes ? i.e. drain pump running none stop ? Can you put water into the tub manually and run a rinse cycle without issue ? In any event the valve is pretty inexpensive, usually about $30 or so. The part # 425458 works on all bosch, thermador, gaggenau, and siemens dishwasher built since the early to mid 90's up to present day. Hope this was helpful to you. Thanks for visiting "fixya" today. Good luck. macmarkus :)
Mar 05, 2010 | Bosch Dishwashers
Our Siemens dishwasher retains water and smells
I would check the bottom of the dishwasher to see if there are any bones, old food built up as some of these collection systems have a small disposer built into them.
If you find any food, it's probably that.
Also, you can make sure that the drain line is the proper length and high enough as this is a common problem. Do a good search on proper drain height for dishwasher.
You may run an empty load of dishes with a cup of bleach added to eliminate the odor as well. Bleach will kill any bacteria causing the smell. More than likely the drain hose wasn't installed correctly.
Sep 10, 2009 | Siemens 24 in. SE64A630GB Built-In...
  • hot water valve selinoid and cold water selinoid valve are magnetily operated valves located in the lower part of the dishwasher that need electricity-----
  • wire loose?
  • kinked supply hoses and
  • my favorite is the valve at the kitchen sink angle stop is lying to you, indicates open but is really still shut (broken valve stem) or it has corroded shut .
Aug 14, 2008 | Siemens 24 in. SE64A630GB Built-In...
Dishwashers Logo
741 people viewed this question
Top Dishwashers Experts
