Question about Kenmore 22422 Top Load Washer
Kenmore washer-top loader-replacing water pump
We purchased the part, removed the clips from the pump but it will not come loose from the center shaft.
Had to pry it off. It took about 45 minutes to get it to come off. The reason it was so hard to get it off was that the shaft of the motor was pitted and rusted some. The new pump then wouldn't easily slide onto the shaft, so we had to use a file and sandpaper to make the shaft smooth. We then used WD-40 on the shaft and it went on rather easily, but was still plenty snug. We put the clips back on, the hoses back on and bingo, we fixed it and saved about $150.00. Neither myself or my husband had ever attempted to fix a washer or any large appliance before. Times are hard and we decided to try it on our own and were happy we did. No more leaking at all. It was a "high five" moment!!! Barbara Giles
Posted on Feb 06, 2009
Kenmore 90 series heavy duty super capacity plus quiet pak washing machine leaks a small amount water from the bottom front of washer when running a wash cycle.
If your TOP LOADING Whirlpool manufactured washer (Kenmore) is leaking, the following link explains how to remove the exterior washer case in order to accurately inspect the washer interior components for the source of your leak:
http://www.fixya.com/support/r3576648-washer_leak__top_loader
If the leak is more like a constant drip, a common source of leaks with Whirlpool manufactured top loaders is a leaking drain pump. These pumps are not serviceable and if damaged, must be replaced. The following link explains how:
http://www.fixya.com/support/r3794382-replacing_water_pump_whirlpool_top
Don't forget to check all drain hose connections under the washer and the center tub seal.
Replacement parts (if required) can be purchased at any of the following websites:
searspartrsdirect.com
pcappliancerepair.com
appliancepartspros.com
repairclinic.com
Prices vary between sites, so shop and compare. The first three sites listed also have helpful exploded view parts illustrations to assist you with locating and properly identifying the parts you may need.
If you have any questions, please post back with a complete MODEL NUMBER and let me know. I hope this helps you.
Aug 12, 2010 | Kenmore 3.2 cu. ft. Plus Top Load Washer
Kenmore top loader leaking from bottom when loading
could be leaking from your drain pump seal, main tub seal which is between tub and tranny, also your outter tub could have a crack in it! i would remove the base to see inside and run it through a short cycle and see if you can pinpoint the leak
Feb 17, 2010 | Kenmore Washing Machines
Kenmore70 series washer 110.26752502 leaks water while filling
If you have a leak on a TOP LOADER, the most common cause is a worn drain pump, leaking drain hoses or the hose to the air dome has come loose. You will need to remove the exterior case of the washer to be sure. DO NOT lay the washer on its back. The gearcase contains oil and it may leak through the breather hole.
The following link explains how to inspect a TOP LOADER for leaks:
If the drain pump is leaking, it is not serviceable and must be replaced, the following link explains how to replace one:
Replacement parts (if required) may be purchased on line at any of the following websites:
searspartsdirect.com
repairclinic.com
Read through the instructions provided and let me know if you need further assistance. The choice is yours if you wish to pursue this repair on your own. In my opinion, you don't need a "certified repairman" to find the source of a leak in most cases. Many of these repairs are simple with a little guidance. I hope this help you.
Feb 11, 2010 | Kenmore 22422 Top Load Washer
I have a top load washing machine model #11028912791 that has a water leak under the left middle area but how do I get inside the machine to look for the problem?
repairclinic.com
Prices vary between sites, so shop and compare. The part number for a new pump (if required) is 3363394.
Read through the instructions provided and let me know if you need further assistance. Please let me know. I hope this help you.
Feb 09, 2010 | Kenmore 24032\24036 Top Load Washer
Pump leaking. can i replace it by removing the hoses and the two clips that are holding it to the motor?
Yes, this is a very simple repair. The following link explains step-by-step how to replace the pump on a Kenmore top loader:
http://www.fixya.com/support/r397092-replacing_water_pump
I post this only to give you a reference to work from. If you've already figured out how to access the pump, great. Now all you need to do is remove the drain hoses and the two retaining clips that hold the pump in place.
NOTE: To minimize any mess, you may want to use a wet/dry shop vac to pull a vacuum on the drain line to remove any residual water that may remain in the drain line and tub.
If you have any questions, please let me know. I hope this is helpful to you.
Oct 10, 2009 | Kenmore 22982 Top Load Washer
Kenmore top loader washer - No spin - motor rattles - wtr pmp ok
Bad/broken coupler/ http://www.davesrepair.com/DIYhelp/DIY285753.htm
Sep 01, 2009 | Kenmore Washing Machines
Kenmore 80's series top loader only works on wash and rinse cycle
This is a problem with the pump being stuck so the motor cant turn the whole thing. Turn the washer on its side, underneath you can acces the pump, which is connected to the motor by two long clips. remove the pump and take out the colg that caused it to get stuck.
Jul 01, 2009 | Washing Machines
Kenmore series 70 tip loader washer is leaking
your just seeing the water that is leaking dureing the wash cycle unplug washer there will be 2 screws on the header panel 1 on each side take them outgently pull header panel to you then flipupunplug wiring harness thas to the cabnet there will be 2 clips 1 on each sideuse a flat screwdrive and pry back they will come out tip cabnet back to you the whole thig will come off look at the pump in the front it has a weep hole in it see if it has been leaking from there
Jun 27, 2009 | Kenmore 22422 Top Load Washer
Water is coming out of the bottom of the washing machine
Tip the machine back and remove the 2 clips holding on the drain pump. Remove the hoses. Then turn the pump over to where the motor shaft enters it. There will be signs of water leaking out of the pump. Your local parts store will have the pump instock.
Nov 22, 2008 | Kenmore 22422 Top Load Washer
Older Style Top Loader Washing Machines
if the image on your posting is correct and model number 2 there is no belt washer is driven by coupler between motor and transmission it could be broke if washer drains but won't agitate or spin ..remove end caps on console by pulling up remove screws on each end of console lift console up and roll back remove clips on each corner and lift cabinet forward and off remove pump clips remove motor clips by removing screws first drop motor remove coupling and replace
Aug 06, 2008 | Kenmore 24032\24036 Top Load Washer
Kenmore 22422 Top Load Washer Logo
215 people viewed this question
Sal De
fordexpert
Jim Goldsmith
Jim Goldsmith
