Question about Homelite Consumer Products 9.0 Amp, 14 In. Chainsaw
Replace bar and or chain ...saw runs but not with the chain
Today Sunday ...if yes please come back another day .
runs but carb' needs adjusting, the bar seems a bit crooked...bowed. and the chain has a kink in it. Do not have money to have repaired again this year too not yet at least. I would like to fix the problem.
  • 2,976 Answers
The bar MUST be straight. Soak the chain with penetrating oil. If that doesn't free it up, replace it. If it is kinked sideways--replace it. Never run a chainsaw with damaged parts.
Posted on Feb 02, 2009
Installed new carb-saw will idle fine,but will not rev.Idle scew has no effect on r.p.m.As soon as you hit the throttle,saw dies.Almost act's like the chain brake is on but it is dissengaged.Both...
There are a few things to check, if the muffler has a spark arrester gauze in the out let this may well be blocked, remove the muffler and the gauze, does the engine now rev? if yes either the park arrester is blocked or the muffler itself is blocked, if this does not cure it, check the flow of fuel from the tank to the new carb, replace the filter in the fuel tank and try again, if this does not help try running the saw with the air filter removed, if it revs normally the filter is blocked.
Aug 28, 2011 | Poulan Pro PP4620AVX 46cc Gas Chainsaw...
Poulan " Wild Thing
It is running lean, they always need to run a little on the rich side free running, once the engine is loaded it will then need the excess fuel, it runs ok without the bar and chain because there is no load, start by replacing the fuel filter in the fuel tank, check the fuel hose up to the carb for signs of fuel leakage, replace if reqired, if the carb has standard adjuster screws, increase the H screw by 1/4 turn out ( anto clockwise ) this will richen the mixture.
Aug 22, 2011 | Husqvarna "Chain Saw - 16" Bar, 3 Hp
42cc 18 inch craftsman chainsaw model 358-351910-18. Saw runs great at idle or while not cutting wood, when starting to cut wood just after the entire bar gets into the wood engine bogs down and chain...
Generally this is a fuel / air ratio problem. Usually it can be solved by a carb adjustment. On the carb there are usually two screws, one marked low or L , the other marked high or H. Low is your adjustment for idle mixture, high is for mixture at full throttle. The saw should Always be adjusted to run well during the cut. Make adjustments a little at a time, then try The saw. Continue small adjustments untill the saw is performing well at full throttle while Cutting.
Aug 09, 2011 | Poulan Pro Chain Saw 46cc 20"
I was using my Remington 14'' limb N' trim chain saw and the chain slipped off. How do I put it back ??
First, inspect the chain for bent links or other damage. If ok, loosen the bar mounting nut(s) and turn the tension adjust screw CCW until the chain can be passed over the sprocket, then threaded over the far end of the bar. Make sure the chain cuts toward you on the bottom. Turn the adjusting screw CW until the chain begins to tighten. Proper adjustment is when the lower run of chain doesn't droop from the bar, yet allow easy movement of the chain by hand. Tighten the mounting nut(s) and recheck the chain adjustment. Pay attention to chain droop and readjust as needed during use of the saw. Make sure it is being properly oiled by running the saw in front of a piece of cardboard for several moments--it should throw off a thin line of oil. Hope this helps!
Mar 21, 2010 | Remington Electric Chain Saw
Replacing Remington Electric chain saw blade
Where the bar meets the body of the saw there is an adjustment lug that will either push the bar outward tightening the chain or may be retracted allowing slack in the chain. When backed off (loosened) sufficiently, the chain may be removed for replacement. In order to use this feature, however, there are two bolts that secure the bar to the body that must be loosened prior to any adjustment and tightened bach up after making adjustments to the chain. The above will be enough to remove and replae the chain. If you are taking off the bar (that the chain runs on), you will need to remove the two bolts that were just loosened for the chain adjustment (above).
Regards! --WoobieDog--
Jul 07, 2009 | Remington 16" Electric Chain Saw Assembled...
McCulloch chain saw wont stay running after it warms up. I go to cut wood it start to bog down if i let go of the button it idles fine
Is the chain brake engaged? The brake lever should be in the back position. Toward the handle.
was this helpful?
Mar 23, 2009 | Poulan Wild Thing 2375 18" Gas Chain Saw...
353 husqvarna chain saw won't start.
did you try adjusting the throttle cable? does it start at all then die ?
Feb 27, 2009 | Husqvarna "Chain Saw - 16" Bar, 3 Hp
Need true chain/bar size for my husqvarna Model 254 chainsaw
Maximum bar size of 20" but would recommend 18", if it is running sluggish, check compression, if low replace the piston, if it is 135psi or more then make sure the airfilter is clean and then tune the carb and make sure you get good revs and throttle response throughout the rev range, use the typical carb adjustments from the owners manual from the Husky web site. This is a 5hp saw and is capable of cutting some big lumps of hardwood so no excuses on the power front
Feb 25, 2009 | Husqvarna "Chain Saw - 16" Bar, 3 Hp
If today is Sunday please comeback later
I recommend that you go to the farm center or chain saw shop and purchase a new bar and chain. If you are not sure which bar and chain to get take the saw with you and ask.
Feb 02, 2009 | Homelite Consumer Products 9.0 Amp, 14 In....
Engine runs but wont idle!
set you carb adjustments at 1 1/4 and try that
Jan 30, 2009 | Husqvarna "Chain Saw - 16" Bar, 3 Hp
Homelite Consumer Products 9.0 Amp, 14 In. Chainsaw Logo
91 people viewed this question
Top Homelite Garden Experts
Roland W VanLue
Roland W VanLue
Mike Squire
Are you a Homelite Garden Expert? Answer questions, earn points and help others
