Question about Abit NF7-S V2 Motherboard
Noise may pc abit nf7 v.2 is very noisie what can i do with it can you help
    Sergeant:
  • 219 Answers
That noise is due to your Power-Supply-Unit, Hard-Drive, Optical Drives, other spinning devices, and ventilation fans. You can reduce some of it but not all of it.
For example, your hard-drive could be rather old and producing a lot of noise when it spins up, reads, or writes data. You could replace it with a newer hard-drive which barely makes any noise. The same with your Power Supply Unit (PSU). It could be old and rather noisy. You could buy yourself a newer one such as the ones made by PC Power & Cooling which gets you a quieter product. However that's about it as you DO NOT want to reduce the amount of fans in your system.
Sorry if this was not the solution you were after. However most noise from a computer stems from ventilation fans which can be replaced but should not be removed.
Posted on Feb 02, 2009
Fan noise loud and always present
If the fan is very dusty that an cause a lot of noise as it will be unbalanced. If the fan is on all of the time, maybe the bios requires updating. There may be a GPU issue and that will make the cpu run hot.
Jan 03, 2014 | Toshiba Portege R400-S4831 - Core Duo...
Noisy computer fan
If its a loud "whirring" noise almost grindy...you need to replace that fan...it's about to fail. if it's a vibration type of noise, you should try tightening the screws first...if it's coming from processor fan, replace it before you fry your processor...
Jul 03, 2012 | Computers & Internet
I have Acer Veriton 5800 desktop and often the noise get louder and faster and then it quieten down. Do you think it a fan?
Most desktops have fans fitted, especially in the power supply.
The bearings and not that good and become noisy when older. They are replaceable but a replacement power supply is far less effort.
Show the fans a plastic pipe from a vacyym cleaner from time to time, that will make the fans more efficient and reduce the wear and noise.
The hard drive can get noisy also, (if it is I would before it is too late), recommend replacing it.
Hope that helps.
Dec 09, 2010 | Acer Veriton 5800 PC Desktop
The HP dv6700 has a noisy fan but the noise
THE CPU IS AUTOMATICALLY CONTROLLED BY MOTHER BOARD. WHEN THE HEAT IS ON IT MOVES FAST AND AFTER COOLING IT WILL GET SILENT. U MAY CHECK IN CMOS SETUP FAN MODE
Apr 15, 2010 | HP Pavilion DV6700T Notebook PC
It makes a loud whining noise when it is on the spin cycle. Functions ok, but sounds like it is a jet engine...
Hello there: Here is a extensive list of things to look at and hopefully this will be very helpful for you Washing machine is noisy It's very difficult to advise on a noisy washing machine because you often can't describe noises accurately enough. People can describe the same noises quite differently. Please visit the following link for a detailed list of ways to help with your noisy washing machine. http://www.washerhelp.co.uk/diy-repair-help_2.html#cl_q4
Dec 25, 2009 | Whirlpool Cabrio WTW6600SBT Top Load...
My computer has always been extremely noisy.
has the cooling fans been cleaned lately?PC's shouldn't be noisy to the point you're asking for advise about it. Is it a grinding noise, a clicking noise..more info plz.
Don't Forget to rate the advice!!
http://www.aa1consulting.com
Jul 27, 2009 | Dell Dimension 3000 PC Desktop
Computer noisy
first tell me what kind of noise??
may be there is some problem with SMPS Fan check tham.
Thanks for using FixYa.
Jan 07, 2009 | Compaq Presario 5000 PC Desktop
Abit KN8 ultra chipset coller
Try cleaning with compressed air.But i believe the bearings in rthe fan are bad..replace new.RichardM69
Nov 30, 2008 | Abit KN8 Motherboard
Dvd writer makes noise when copying movies
if the movies are copying ok then it will just be a noisy burner, possibly some vibration also, mine is the same, noisy but burns ok. You can try and reduce some of the noise by taking the side panels off and make sure the screws are tight on the writer
regards
Nov 20, 2008 | Computers & Internet
Noisy fan
its because of heat build up inside the pc..you may need to clean the dust off the fan and give the pc air to breathe!check your pc's temperature using http://www.almico.com/speedfan.php hope it helps!
Oct 28, 2008 | Dell OptiPlex 170L PC Desktop
Abit NF7-S V2 Motherboard Logo
47 people viewed this question
Top Abit Computers & Internet Experts
Alun Cox
David
David
Jerry Umali
Are you an Abit Computer and Internet Expert? Answer questions, earn points and help others
