Question about Amana 22.6 cu. ft. Side-By-Side Refrigerator with FrontFill Ice and Water
My Amana refrigerator has water and ice on the outside door. The ice works fine but I am not getting any water. I have replaced the water filter. Can you tell me what the problem is?
    President:
  • 2,976 Answers
Did you check to make sure you have water going into the filter? Sometimes, the tiny hole used in the flow valve gets clogged at the source. Shut the valve and reopen it.
Posted on Feb 02, 2009
Were is the water filter on a amana sxde 526 m does it have one
I looked up your Model with both P#'s. Sadly no water filters for your Refrigerator. Amana only has a few models with water filters.
Sep 04, 2012 | Amana 22.6 cu. ft. Side-By-Side...
Slow water coming out od water dispencer in door.
first off replac ethe water filter in the unit this will slow down the flow
Feb 15, 2009 | Amana ARSE66MB Side by Side Refrigerator
Internal water dispenser stopped working
I lowered the temp on the freezer to 4 overnight, by morning water dispenser is working fine. I think that when we changed the temp to 7 (in order to make more ice ) it froze the water pipe going to the dispenser. I am going to keep both fridge and freezer at 5 ,and hope this will not happen again.
Dec 31, 2008 | Amana AFD2535FES Stainless Steel Bottom...
No water flow
turn the freezer side to zero fridge side will zero also . click for water it should work . just worked for me no water for 1month replaced the filter and everything.
Dec 06, 2008 | GE GSH25JSRSS Stainless Steel Side by Side...
Amana Refrigerator ARS9167AB Ice Crush does not produce ice at all.
either the switch is bad that moves the selection from crushed to whole ice or the ice crushing motor is out
Oct 28, 2008 | Amana Refrigerators
Ice and Water not dispensing. Light button not working
INSIDE THE DISPENSER ASSEMBLY IS A SEPARATE ELECTRONIC BOARD THAT CONTROLS THE DISPENSER.
OCCASIONALLY, THE DOOR SOLENOID OR THE CUBE ICE SOLENOID WILL SHORT OUT CAUSING A BURNOUT OF THE DISPENSER CONTROL BOARD. CHECK FOR A BURNT SMELL COMING FROM THE DISPENSER HOUSING. IF YOU SMELL IT, THE BOARD AND/OR SOLENOID NEED TO BE REPLACED.
Apr 10, 2008 | GE (PSS26MSRSS) Side by Side Refrigerator
No ice or water from dispenser
Kathryn, make sure you do not have the dispenser locked out. Press and hold the lock button for 3 seconds. If you have a green light above the pad this indicates lock. You are going to have to hold the water lever for a while until all the air in the new filter is purged. Catriver...post back.
Nov 12, 2006 | Amana ARS9265B Side by Side Refrigerator
Amana 22.6 cu. ft. Side-By-Side Refrigerator with FrontFill Ice and Water Logo
80 people viewed this question
Top Amana Refrigerators Experts
Charles T Nevin
Charles T Nevin
John Tripp
John Tripp
Dan Webster
Dan Webster
Are you an Amana Refrigerator Expert? Answer questions, earn points and help others
