Question about Daewoo KOR-630A Microwave Oven
Turn table broke
Need to order a new turntable for my Daewoo MT1510W. Where can I get one?
  • Daewoo Master
  • 9,098 Answers
You can visit Daewoo online or call them at 877-393-7823 or 973-249-3448 to find parts.
Posted on Feb 03, 2009
MY TURN TABLE IS NOT TURNING AND MICROWAVE NOT HEATING
the motor for the turn table has broke and when it doesnt turn it wont heat?needs new motor or new microwave
Apr 07, 2016 | Microwave Ovens
Kitchen aid kemms308sss04 plastic insert on turn table broke how do you replaace
That may be called the turntable coupler or turntable support or roller ring assembly.
You can find helpful exploded views and part numbers at the link below, by replacing XXX with the full model number found on the tag on your microwave (not on the service manual).
XXX&siteCd=WHRCOM&userType=Consumer">http://shared.whirlpoolcorp.com/product_literature/search_results.jsp?searchTerm=XXX&siteCd=WHRCOM&userType=Consumer
My preferred place to order Whirlpool parts is from the Pro here.
Feb 16, 2014 | KitchenAid Microwave Convection Oven
Turn Table does not turn is it suppose to
One could unplug the power cord and take off the back metal panel.
The turntable runs off a rubber belt.
Be very careful as the capacitor holds one hell of a voltage. It is usually encased by a metal shield... but be very alert.
Do not run the microwave with the cover off..
Apr 25, 2012 | Daewoo KOR1NOA Microwave Oven
I have an over the range DAEWOO MT1510W Microwave i think the fuse blowed my manual doesn't show where it located at
The fuse probably is internal. It may be necessary to remove your OTR microwave to get access inside.
Jan 13, 2012 | Daewoo Microwave Ovens
My 2009 daewood microwave oven/pizza oven is having a problem with the turntable not spinning?
If the turn table is not spinning it must be a broken or defective drive belt, you need to open the unit and check the belt (REMEMBER TO UNPLUG ALL POWER CABLES WHEN OPENING THE UNIT) to minimise risk of electrical shocks...
Sep 24, 2011 | Daewoo Microwave Ovens
My over the stove Sharp Carousel Model # R-1505F turn table stopped turning. What part do I need to replace. Also, I broke the glass turn table plate. What size is that and where can I order another...
Sears Parts Direct has the parts diagrams and many parts for the R-1505 microwave. The glass plate is part 4-3 ($33.99) on this page: http://www.searspartsdirect.com/partsdirect/part-model/Sharp-Parts/Microwave-Parts/Model-R1505/0958/0123370/50019999/00001?blt=06&prst=&shdMod= .
Without more tests, I can't be completely positive but the turntable motor is the likely problem. That is part 1-4 on the list above. However, it could be a wiring problem with the wiring to the turntable motor.
Partstore.com has many of the parts as well: http://www.partstore.com/Model/Sharp/Sharp/R1505.aspx .
I hope this helps.
Jul 29, 2011 | Sharp R-1505 Microwave Oven
Hi I have an Emerson microwave oven MW8998B. The turn table will not rotate while cooking. The smaller bags of popcorn just burn the bag. Does this need a repairman or can I fix it myself. Also, I am able...
Hi, I had the same problem with my Emerson microwave. As I rent out the house, and the turntable stopped working while I was away, my rental agent bought another Emerson microwave. On my return I tried using the new (brown) plastic turntable on the old microwave, and found it worked perfectly. Maybe it would be possible for you to order a replacement turntable part. Hope this helps. Good luck, Rosalind
May 13, 2009 | Emerson Black Microwave Oven
My microwave turntable is scrubing the finish off the surface underneath the wheels of the turn table. this has exposed bare metal. Is it safe to use? Weare currently useing it with the turn table turned...
The floor will have to be sanded smooth and clean and dried thoroughly.
Then you can apply some high-temperature appliance paint, available from places like Wal-Mart, Lowe's or Builder's Square.
I would then leave the door open to let it dry untouched overnight.
You didn't mention your oven's brand or model, but it may be that the wheels on the turntable support are worn or there may grease built up in the axles.
Or you may need a new turntable support.
If you need to order a new one, please reply back with your brand and model number so we can help point you to the proper distributor.
Jan 02, 2009 | Microwave Ovens
GE turntable microwave Je1540WW 002 Turntable doesn't turn
I have had the turn table motor go defective in microwave ovens.
Normaly, before ordering a new motor, I always checked to make sure that there was power going to the motor assembly. I never had a power drive failure to a motor so-far. When they did not spin, the motor was defective. But, one day there will be a first time for me.
The fix was to purchase a new motor from the manufacture and install it. In some cases, I had to also replace the spindle key because the original broke when trying to remove it when removing the motor assembly.
I suggest that for servicing a microwave oven, you give it out to a service center to have the work done. There are safety issues when working on microwave ovens.
Jerry G.
May 25, 2008 | Microwave Ovens
Daewoo KOR-630A Microwave Oven Logo
150 people viewed this question
Top Daewoo Microwave Ovens Experts
William Miller
William Miller
Oloyede Monsuru
Are you a Daewoo Microwave Oven Expert? Answer questions, earn points and help others
