Question about Electrolux UltraLux 2000 Bagged Canister Vacuum
Switch on Electolux Model E Vacuum
For starters, my problem is with a Model E - I don't own an Electrolus Ultraluz 2000. The wires are all disconnected from the switch and each other and I need to know how to reattach: - The two black wires that go to the motor and or brushes/field coils. - The black and red wired that come from what I think is a capacitor. I have the two pole switch and a two wire power cord. Thanks.
  • Mayk Feb 06, 2009
    Thank you.  That was right on.
    Unfortunately most of the other answers ranged from people only partially answering the question to the downright silly.  You folks really need to weed out the "experts" who just throw  things at the wall in the hope that something will stick.  I just about gave up until Rockitman came through with the right answer.
    Thanks to him...
    Mike Miller
    President:
  • 2,559 Answers
Posted on Feb 06, 2009
  • Randy Hough
    Randy Hough Feb 06, 2009
    Thank you for the kind words and I'm glad I could help.
    If there is anything else I can do,feel free to ask.
Need a wiring diagram to change batteries on an electolux zb2904X vacuum
Batteries are not usually replacement items in most rechargeables. Typically the batteries, if available, cost as much as the whole machine. These are intended to be disposable.
Jan 08, 2015 | Vacuums
Dissasemble System 90 Electolux
on the side of the vacuum there are rubber guards.These slide off....pull them off with a pair of needle nose.pull the slides off from the front. then open the front cover,at the bottom there are a couple little "nibs" that hold front off..Gently put a flat screw driver in and pull up..The machine will then be readt to open.best way is to put machine upside down and take the bottom off...
Jun 12, 2014 | Electrolux UltraLux 2000 Bagged Canister...
Recently bought electolux hoover , used it at weekend to hoover stairs and have noticed that it has burnt two small holes in my carpet , is there a phone num or address that i can send a complaint to
Since you were " hoovering" I assume you're in England ...or nearby.
If so you will have to look up AB Electrolux vacuum division.
The number in North America would be AERUS Electrolux for models pre 2000.
AB Electrolux has bought them out and would cover totally different units sold here since about 2002....
Oct 12, 2009 | Vacuums
Hi I have an electrolux vacumm cleaner, super J model. My problem is that the powerhead only works if the switch is in the off position. vacumm motor works in the on position, opposite of each other. Can...
Looks like there's an interchanged wires in your vacuum. Both the motor and the powerhead must go together. Check it up. Leave the
motor wiring connection intact. Just tinker and check the powerhead
wiring connection .
Sep 25, 2009 | Electrolux UltraLux 2000 Bagged Canister...
Handle gets very hot on my 5892BVZ vac
i have a 1998 chrysler sebring convertible stop starting by the ignition switch,we changed starter,ignition switch been changed,changed starter relay,trace the wire haven't found a broke are burned place in it,checked igniton fuse its good,didn't see a linkable fuse
Sep 23, 2009 | Eureka 5892AVZ Bagless Upright Cyclonic...
I have an older electolux vacuum. It says Epic
Vacuum either has a clog or full bag that is overheating the vacuum causing the thermal switch to shut it down.
Hope this helps.
Aug 14, 2009 | Electrolux Vacuums
Electrolux 2100 canister vacuum
Open the door to remove the bag. Pull the side bumpers forward when the door is open. The profile of the edge of the top and the bottom of the vacum body is a "L" shape. The cross section of the bumper is a "I" and that holds the body together. Carefully lift up the top just a little to free the plastic end cap that conceals the cord spool. There are two plastic pins on the top and bottom that hold this piece on and they frequently get broken. (If that happens repair shops drill and hole and insert a screw.)
There is a plastic protector plate that lifts up on either end and then is slid about 1/8th inch clockwise and then up.
Copy the wiring pattern on the four male connectors on the motor and the wire spool.
Post your wiring diagram and it will solve a lot of people's problem trying to reassemble this machine's -- including mine.
Oct 07, 2007 | Electrolux UltraLux 2000 Bagged Canister...
Electrolux UltraLux 2000 Bagged Canister Vacuum Logo
82 people viewed this question
Top Electrolux Vacuums Experts
Chris Nomland
Chris Nomland
Are you an Electrolux Vacuum Expert? Answer questions, earn points and help others
