Question about Whirlpool LER4634J Electric Dryer
Dryer started out squeeling and now is making loud sounds?
We have a whirlpool dryer and last week when drying is started out squeeling softly and over time got loud. We stopped using it, cleaned out all of the lint and now it works, but is sounding like it is grinding loudly, when it over heats its automatically shutting itself off? Got any pointers, before we spend an arm and a leg to purchase a new one? or pay to get this one fixed? We'd like to try to fix it ourselves.
My Whirlpool dryer Model # LER4634EQ0 recently started squeeking while running. Now it gets progressivly louder and gets really hot really fast. Is this a belt or what?
  • mp37 Feb 02, 2009
    I have the same problem, mine is a whirlpool dryer. Please help, I don't want to go to the landromat!!!
  • 32 Answers
This is very likely due to bad drum support rollers which is really not a difficult repair on these dryers.
Whirlpool Dryer Repair Manual
Posted on Feb 05, 2009
Whirlpool dryer runs, hums, then quits
Sounds like the motor is on it's last legs. Replace it. But, before paying huge money for a motor and the labor to install it, I suggest that you price a new dryer and compare it to the repair costs. It may still be a little more for a new dryer, but....IT'S NEW!
Mar 20, 2017 | Whirlpool Dryers
At start up I have a loud squeal on my 99 Mazda 626. Both belts are new and so is the alternator. The squeal only last for about 10 secs or so and goes away. I have started it in neutral and the squeal is...
Does your car have air conditioning.? Most cars use the A/C compressor to dry the air for the defrost. It will also come on for a short time when you first start the car. With the engine running after the squeel has stopped , try turning the A/C on , If the squeel starts again , then I would think your A/C compressor is seized. Also . are you sure the 2 new belts are tight enough?
Feb 20, 2011 | 1999 Mazda 626
Cycle Signal keeps beeping loud-soft every 15 seconds while dryin
Hi Celine, I just experienced the same exact problem. I came here looking for a solution. I got mine to stop by holding down the cycle signal button for 3 seconds, releasing it for three seconds, and repeating until both lights (loud and soft) went off. Hope it helps.
Apr 21, 2010 | Kenmore Elite Oasis 6808 Electric Dryer
Whirlpool dryer model #GEW9250PT1 not drying properly
when was the last time you cleaned your dryer?all a dryer does is move air around and if it can't cycle through the dryer the clothes won't dry. unplug the dryer and then you need to clean the duct that the lint filter slides into,vac out the inside of dryer where the motor is and clean out the vent line,if the vent line is a long run from the back of dryer to the outside vent i use a leaf blower to clean it out,make sure the outside vent is clear first then blow it out,if it's a short run vac it out,most problems start just from lint buildup,the clothes don't dry the dryer runs hot and parts start messin up,also vac out under your fridge,take the bottom kick plate off and vac it out,you can kill the compreesor if you don't,good luck
Apr 05, 2010 | Whirlpool Dryers
I have a LER4634EQ1 WHIRLPOOL electric dryer. Last week it started to shut down before completing a cycle. The other day it completed the cycle but the clothes weren't dry. It also makes a loud noise when...
if the noise is a rumbling sound tha that would be your roller's.the other problem sounds like a bad timer.time to think,do i put that kind of money in a 12 year old dryer or get a new one.
Nov 05, 2009 | Whirlpool LER5636P Electric Dryer
Squeeling while drying
worn belt, needs replacing
Oct 07, 2009 | Dryers
Dryer help
Pop the top and get the front off. Get the ball of lint out the blower housing and replace the bad blower wheel.e00d80d.jpg30eaeb0.jpg
Dec 16, 2008 | Dryers
Maytag Dryer squeeling
Drum support rollers. I cannot see your repyl due to some tech issue w/ the site, so it may be a day or so before I can reply again. Please leave feedback for me if appropriate. Thanks
Nov 28, 2008 | Maytag Neptune MDE5500AY Electric Dryer
Grinding and squealing noises with this model (if the model number is correct) are usually attributed to the drum support rollers and/or idler pulley needing lubricated. Use a light weight turbine oil on the shaft area only. DO NOT lubricate the rubber portion of the rollers.
If the front drum glide support is worn or has something caught in it, the dryer may also exhibit noisy operation. The same is true of the rear drum seal is worn. You shouldn't have to replace an ENTIRE dryer for noise.
All these parts COMBINED cost less than $80. There all available at Just type in you complete model number in the "Search by Model Number" window and the parts can be found under the following headers:
"Cabinet Parts"
Item 53 - Idler and Pulley Assy. (part #691366)
"Bulkhead Parts"
Item 44 - Roller Support (part #349241T)
Item 62 - Ring Bearing (part #279441)
Item 66 - Rear Seal (part #279857)
The website has helpful illustrations to assist on part location and assembly. The site also has handy Do-It-Yourself manuals by calling 1-800-252-1698 (if needed).
To access all the components, you need to lift the top and remove the front of the dryer. On some dryers this is accomplished by pulling the top panel towards you then lifting up. On others, you will need to lift the console by placing a putty knife under each front corner and pushing in while lifting up. Once the console is lifted, there are three screws to remove and teh top panel will slide forward then up. CAUTION: UNPLUG the dryer PRIOR to servicing. Pay particular attention to how the dryer belt is installed so you can re-install later. If you forget, has dryer belt diagrams for most major brands under their "Repair Help" section.
NOTE: If you disassemble the dryer to this point, take the time to inspect the dryer belt. This may be a good time to replace it.
I hope this information answers some of your questions.
May 12, 2008 | Whirlpool LER5636P Electric Dryer
Dryer stop drying
Check you venting,on gas units call for service.
Mar 17, 2008 | Maytag MDE2600 Electric Dryer
Whirlpool LER4634J Electric Dryer Logo
352 people viewed this question
Top Whirlpool Dryers Experts
Dan Webster
Dan Webster
Tim Whalen
Sal De
Are you a Whirlpool Dryer Expert? Answer questions, earn points and help others
