Question about Clarke Power Products Inc AC2001 2HP 4 Gallon Pancake Tank Compressor
Oil covering pancake and pressure adjustments
My model ac2001 pancake compressor has a film of oil across the surface of the tank.
How do I check the oil and fill?
What should be used to add oil?
Also, the regulator seems to adjust the tank pressure but I can't find a place to increase/decrease the output pressure. For that matter it is unclear if the regulator increases the tank by going clockwise or counterclockwise. What are the two additional rings on the regulator- locking rings?
The paper work that came with the compressor is a parts list only. No operating instructions. Where can I download an operating mauel?
    Problem Solver:
  • 13 Answers
Typically on the inside cover of the electical box it will illustrate the cut-in/cut-out controls. There should also be a fill port above the pump end of the compressor. Do you have a sight glass on the side of the compressor *(around the area of the leaking oil) usually if its coming out its due to overfilling or tipping over of the compressor.
Posted on Feb 10, 2009
What kind of oil do i put in my clark 4gal pancake compressor
If it's an oil-less, none. If it's a regular compressor, use compressor oil.
Jun 02, 2012 | Clarke Power Products Inc AC2001 2HP 4...
Ac2000b motor runs but builds no pressure in tank
Your compressor is worn out. It is repairable but you will quickly find out that the price of the rebuild kit and S+H is about the price of a new compressor at your local store.
Oil-less compressors cannot stand up to use and abuse they get like a oil compressor can but they are certainly affordable.
Thanks for your question @ FixYa.com
Aug 06, 2011 | Clarke Power Products Inc AC2001 2HP 4...
PANCAKE COMPRESSOR WON'T SHUT OFF AND WON'T BUILD PRESSURE.
most likely the regulator is shoot. But also try checking for leaks with dish soap and water in a spray bottle.
Mar 06, 2011 | Clarke Power Products Inc AC2001 2HP 4...
Where can I purchase a new pressure regulator for a Clarke ac2001a pancake air compressor?
Harbor Freight should have this or be able to order it for you and usually take them bout three days to get items in.
Oct 28, 2010 | Clarke Power Products Inc AC2001 2HP 4...
Don't know how to adjust differential pressure on air compresor
Most of the cheaper compressors use a switch that is not adjustable.
May 12, 2010 | Clarke Power Products Inc AC2001 2HP 4...
No pressure getting through to gauges
remove the intake filter and check to see if the compressor is sucking or blowing if it is blowing out air from the intake you have a bad valve
Apr 26, 2010 | Clarke Power Products Inc AC2001 2HP 4...
I need a drain plug for a Clarke Air pancake two horse compressor. Model AC2001 Serial # 1005188 Where can I locate one? Dan
Master tool repair is a good web site to get things like that, they sell a lot of generic parts like that
Dec 29, 2009 | Clarke Power Products Inc AC2001 2HP 4...
Type of oil used in ac2001 air compressor
It should take any standard compressor oil, available and Home Depot, Lowe's, Sears, and auto parts stores
Jul 11, 2009 | Clarke Power Products Inc AC2001 2HP 4...
Motor startup trouble while pressure in tank
My first thought was that the check valve is allowing pressure back into the compressor and preventing the motor from turning. That's still my best guess right now.
I think the cold weather start symptom is what you would see with any engine/motor -- it requires more torque to get it going. In this scenario, if the check valve weren't leaking, it would start okay when cold.
May 06, 2009 | Clarke Power Products Inc AC2001 2HP 4...
Clarke Power Products Inc AC2001 2HP 4 Gallon Pancake Tank Compressor Logo
273 people viewed this question
Top Clarke Air Tools & Compressors Experts
John Trevino
Ronny Bennett Sr.
Ronny Bennett Sr.
Are you a Clarke Air Tool and Compressor Expert? Answer questions, earn points and help others
