Question about Maytag MSD2756G Side by Side Refrigerator
Freezer is almost always running....
I just bought a used Maytag side by side fridge model RST2200FAE and we decided not to hook up the water line for the ice maker unit. Do I have to disconnect the Ice maker to stop the freezer from circulating so much as it seems to go on about every 30 minutes for about 10 minutes. The fridge and freezer work well other than that.. There is a very slight grinding sound occasionally, almost like it is trying operate the ice maker .
Also do I need to plug the fridge fitting for the water supply line that is not hooked up?
  • 1 more comment
  • ironguts Feb 04, 2009
    thank you for your help .....however, I swung the arm up and it did not fix the problem so I physically removed the ice maker PS329574
    SUPPORT, MODULE HOUSING (HOUSING-IM) (Series 10)
    that has the thermostat in it and that didn't work either. It continues to cycle almost every 30 mins. I checked the seals around both doors and I don't see any obvious leaks and the seals look good.....could there be another thermostat that is the problem?
    PS the very slight grinding problems seem to be gone probably due to the ice maker being turned off....Thanks again for your time....
  • ironguts Feb 06, 2009
    I unplugged the icemaker at the fidge wall (which has the same effect as removing the ice maker housing module with the ice maker thermostat in it). the freezer still cycles every about 30 minutes. ....any other ideas??....tia
    thankyou for your well thought out explanation I assumed being that I am the only one using the fridge (seldom) and have been keeping the room temperature down around 60 degrees without any air conditioning that the fridge was cycling too often since my older westinghouse cycled way less........
    Thanks again for updating me on maytag's efficiency.....
  • 1,543 Answers
If you look at the icemaker, you will see a metal wire which runs along the side of the unit. If you manually swing the wire arm up until it locks in place (about 90 degree swing from the normal straight down position) you will have turned the icemaker off. (Alternatively you can unplug the electrical plug from the icemaker which goes into the freezer wall.)
If the icemaker is not turned off, it will periodically cycle, which turns on the ice cube mode release heater during it's cycle, putting unnecessary heat into your freezer. You do not need to plug the ice maker supply line. This should be a Fix-Ya for your refrig.
Posted on Feb 02, 2009
  • Carl Schulzetenberg
    Carl Schulzetenberg Feb 04, 2009
    Ice maker will cycle when the thermostat in it reaches about 8 degrees F unless turned off or ice maker is unplugged. As I stated, just unplug the icemaker from the freezer wall to prevent cycling and unwanted extra heat in your freezer. That is a Fix-Ya, saving you refrig run time and improving energy efficiency. Hope you can see to uping the rating. Thanks.
    Carl Schulzetenberg Feb 06, 2009
    When you wrote of the grinding noise associated with the non-hooked up water to icemaker, that would indicate the icemaker cycling, and thus the comments about the ice maker cube mold release heater. You don't want the ice maker putting heat in your freezer when you are not even using it to make ice.
    If you are concerned about the 10 minutes of compressor run time out of a 30 minute time period (33% run time) or 30 off, ten on (25% run time), that is not out of the ordinary. As a mater of fact, most modern refrigerators have a greater percentage run time (although while they run, they use less wattage per minute than old ones, and thus actually much less energy each month while often times running longer than an older unit) Depending on usage (food loads, door openings, etc) and ambient room temps, refrigerator run times can even exceed 90% and still be operating properly, within design specs, and efficiently. (Obviously the a refrig in an air conditioned home with only a minute or two of door openings a day will run less than the same refrig in a 95 degree humid non airconditioned home with a couple of teen age kids around.) Many newer refrigerators will use less power in a day than if you left a 60 watt light bulb on 24/7.
    If your refrigerator is cooling properly, don't worry about it.
I just bought a used Maytag Refrigerator MSD2454GR.I want to hook up the water. Underneath their are two(2) lines disconnected. One to the door and one to what looks like the drain pan.Is their a part...
there is nothing missing, the one to the drain pan is coming from the freezer, The one going to the door, is going to the water dispenser. If you pull the fridge out and go behind, you will also see one going up to the ice maker. At the bottom of the fridge in the back, remove the cardboard panel. Once removed you will see the water inlet valve with two lines leading from it. (The one going to the door and the one going to the ice maker. At the front of the water inlet valve is where the main connection gets hooked up to supply the water. Remember to use teflon tape or it will leak. Hope this helps
Mar 28, 2011 | Maytag MSD2436GR Side by Side Refrigerator
Maytag side/side model MSD2754GR- Ice maker while filling overflows running out of freezer section onto floor.
Remove the back panal in the freezer compatment to reveal the evaporator. You will notice the drain pan frozen up with ice. pour hot water on it or blow hot air with a hair drier. If the fridge is turned off the ice will melt and clear the drain hole. When the ice is cleared the water will be alowed to flow out to the evaporating pan under the fridge. Be sure that the water runs freely out of the fridge and allow a few hours to dry. Good luck. Be careful not to damage the evaporating coils.
Dec 07, 2010 | Maytag MSD2756G Side by Side Refrigerator
Ice maker won't work
Your inlet tube that goes to the icemaker may be frozen. To Check: Shut off water supply to Fridge, disconnect the water line that goes to the icemaker at top back. Use a flexible item to insert in the water line connection. I used a zip tie. If the flexible item won't all the through to the ice maker, the line is frozen. Thaw out the tube from inside the freezer with a hair dryer. Re-connect everything, you now have ice . . . Solution #2: You may have to replace your "Water Inlet Valve" located at bottom right rear of Fridge. Easy to do, just follow the color codes, be sure and shut off the water.
Jun 06, 2010 | Maytag MFD2562KES Stainless Steel Side by...
Periodically, water flows out of the bottom of the freezer door and pools on the floor. The water supply for the icemaker isn't hooked up, so it can't be that.
This is the water coming from your defrost cycle. I'm not sure on this model, but the auto defrost will always generate some water. Some brands use a pan underneath that collects the water and then lets it evaporate, and some put the water in the condenser coil that's under the unit. Yours must have the line that runs from the freezer to the place it's supposed to go unhooked or misrouted. It could also be clogged inside the freezer.
Aug 26, 2009 | Maytag MSD2756G Side by Side Refrigerator
Water leaking from bottom of freezer door, and ice buildup on bottom of freezer
The defrost drain line in the freezer has frozen closed. Turn off the fridge. Remove the freezer bins. Use a hair dryer to thaw the drain hole on the bottom rear shelf of the freezer.
P.S. Your fridge is on recall from Maytag for a defective start relay.
Apr 19, 2009 | Maytag MZD2766GES Side by Side...
How to hook up Ice & Water dispenser on freezer door
The water valve is on the back of the refrigerator. The water line connects directly to that valve. If there is no line available then you will need to run one from a cold water line in the plumbing using a drill type (1/4") saddle valve on that pipe. Hope this helps. If you need more instruction let me know!
Oct 06, 2007 | Refrigerators
Amana Icemaker not working
Sign guy, you have a bad water valve on your fridge. It's allowing a very small amount of water to bypass it and enter into the freezer section Ice Maker fill tube where it freezes. (I always pull those fill tubes out through the back of the fridge and run them under hot water, then blow through them to ensure that it's clear.) You'll need a new valve assy. for it. Open the fridge door and find the data tag, get the model number off of it and call your local appliance parts place. It'll be a dual coil valve assembly.
Jul 21, 2007 | Amana SXD524VW Side by Side Refrigerator
Maytag MSD2756G Side by Side Refrigerator Logo
345 people viewed this question
Top Maytag Refrigerators Experts
Bailey's...
Bailey's...
Shehu Pro
Shehu Pro
Are you a Maytag Refrigerator Expert? Answer questions, earn points and help others
