Question about Acer X193W LCD Monitor
Dell 86oo lapton, monitor goes black after start up completes.
Start up is normal, but once I select a user the monitor goes black and the computer continues to run. I have to reboot to get the monitor back however, it just goes back out again after I select a user.
    Problem Solver:
  • 8 Answers
The problem is likely that the resolution set on your computer is not compatible with the resolution set on your monitor. The easiest way to fix this is to hook up your old monitor and manually change the resolution to the native resolution on your monitor. Your documentation will have this info. If that does not work then you would need to reset your CMOS chip by shorting two pins. Input your computer make and model into google for a motherboard manual. It will tell you how to do this. Then it will be at the default resolution and you can adjust it from there.
Posted on Feb 02, 2009
I have a presario cq61 and have forgot my password can u help
Try starting the computer in safe mode. Turn on the computer and once the COMPAQ screen clears press F8 a few times - don't hold down the key however. Winodws stops loading at teh Startup Options screen (black, text only). From that menu use the cursor keys and ENTER to select "Safe Mode". Once Windows loads (it may look humungous!), login as the Administrator (which should now be visible). Use this account to reset your forgotten user password. Restart once complete - the computer will automatically start normally.
Apr 14, 2011 | HP Compaq Presario CQ61420us Notebook
There is a solid black 1" horizontal area covering the complete bottom of my Dell computer monitor model E209WFP
Have you tried booting the computer into the safe mode?
If it does the same with that mode as well then it means that there is some hardware issue with the monitor.
To get into the safe mode.. Turn on the computer and when you see the Dell logo.. start tapping F8 key continuously till the time you see Advanced boot options.. then using ur Up-Down key select Safe mode and check it out.
Feb 28, 2011 | Dell Computers & Internet
At start up screen goes black and get message can
Native/max resolution for this Dell is 1280x1024, try this setting.
Feb 19, 2010 | Dell E172FP 17" LCD Flat Panel Monitor
I had the blue screen of death come up on my wifes lapton inspiron b120. The computer shut down and now it goes to the black screen that says windows didnt shutdown correctly..... any tips on...
click on start windows normally and if the problem come back again. try these steps
in this case, we need to reset the computer back to factory settings.
here we go...this process will cause data loss.
1. Remove non-essential peripherals
like
a) Scanner
b) Printer
c) Modem or Network cables
d) Personal Digital Assistant (PDA)
e) USB flash drive or other external Hard Drive
f) Any other external devices (e.g., USB-attached devices)
g) Remove the computer from the docking station, if you are using one.
2. Turn on the computer.
3. When the Dell splash screen appears during the computer startup process, press and hold <Ctrl> and then press <F11>. Then, release both keys at the same time.
4. In the Dell PC Restore by Symantec window, click Restore. Alternatively, press <Tab> to highlight Restore, and then press <Enter>.
5. When a warning message appears stating that all data will be lost, click Confirm, or press <Tab> to highlight Confirm and then press <Enter>.
The Progress window will appear. Once the restore process starts, Dell PC Restore by Symantec usually takes about 8 to 10 minutes to finish.
When the restore process is complete, the following message will appear:
The system recovery process was successful.
6. Click Finish or press <Tab> to highlight Finish and then press <Enter> to restart the computer.
The software is now installed as it was when the computer was first received.
Oct 16, 2009 | Dell Computers & Internet
Monitor comes on for seconds and then goes black
This may be because the resolution that is set in your user profile when you log on has been changed to a resolution not supported by the monitor. The best way to fix this is by going into Safe Mode (press F8 as the computer starts to load Windows) and change it to a lower resolution once you get logged in. 1024X768 is a pretty safe resolution to start with. Then restart and see if that fixes the issue.
Sep 02, 2009 | Dell E152FP 15" Flat Panel LCD Monitor
How to reboot dell E173FP??
I assume you mean like a factory reset? Most Dells have a recovery partition, press the appropriate key when starting your computer (when the text goes across the black screen), it's usually F12. This should take you into 'recovery mode'. Then follow the prompts.
WARNING: IF DONE CORRECTLY THIS WILL ERASE ALL DATA FROM YOUR COMPUTER AND BE LIKE IT WAS WHEN YOU FIRST BROUGHT IT!
ENSURE BACKUPS FIRST!!
Jun 23, 2009 | Dell E173FP 17" LCD Monitor
Dell E173FP Screen blinking red, green, blue, white
The monitor is probably on protection.
To start unplug monitor from power and from computer and test computer with different monitor to find out if it is monitor or computer fault.
If it is computer fault and no video signal , then test:
  • Video cable.
  • Video adapter on PC (sometimes integrated on motherboard)
  • Motherboard.
If it is monitor fault , then the monitor is on protection.
When on protection you keep having a flashing led on front of the monitor , and monitor turning off by itself after a while, that indicates a fault condition.
The flashing light indicates a diagnostic state called protection.
When the Monitor goes on protection there are only two possible causes.
1The internal circuits are jammed because of electrostatic charges accumulating on capacitors, or because of a wrong voltage read by the main chip on your monitor controller board. this started the protection circuit.
2 The protection circuit detected a wrong voltage or a broken contact, identified an internal fault and kicked in , starting the flashing light.
If you are in situation one, then the monitor will reset just unplugging power cord for one or two hours,sometimes even minutes.
If you are in situation 2 , then there is an internal fault.
Common faults that can occur are a blown capacitor on power board, faulty inverter board, faulty input board, or a fault on LCD Digital Controller board.
Check also the video cable or any external connection cable, if the cable is shorting, or the connector is bad, you can get same flashing state because of the video cable.
Try moving the video cable, and if the cable is not built in, then also try a replacement cable.
If under warranty contact the manufacturer ringing the number on the user manual
If you want to repair at your own expenses, just locate any good qualified repairer.
Apr 16, 2009 | Dell E173FP 17" LCD Monitor
I have a Dell GX60 and I changed the display resolution and
So, with The computer, completely turned off, Turn it on, Can't you see the BIOS screen? , or a Dell LOGO?
It is when you see this BIOS or Dell logo Screen that you Need to:
  • PRESS F8
  • Press F8
  • Press F8, again, and again right when your computer turns on.
Then You should be brought to the Window that allows you to boot into SAFE MODE, DO NoT PICK SAFE MODE.
Pick: ------------ENABLE VGA (basically safe mode) Only!.
Once booted, log in and change the resolution to let's say 800x600,
then restart your computer normally.
You should then be able run windows normally, (Without F8 Key) where you can then change the resolution to what you want.
IMPORTANT! Remember this, if you set your display to a resolution that it Does Not
support, and the screen goes blank. DO Not Turn off your computer: ALL YOU DO IS PRESS
the (Esc) ESCAPE Key within 15 Seconds and your monitor's resolution will be set to it's
previous state again.
I Hope This Helps.
Jan 30, 2009 | HP Pavilion F1503 15" LCD Flat Panel...
Blank Monitor
Start pressing F8 at boot
When the Windows Startup menu appears, select ENABLE VGA MODE
This will boot the system in 640 x 480 resolution but the video driver will be installed. Once at the desktop, either reset the display to the normal resolution settings or reinstall the video driver.
Aug 06, 2008 | Relisys RLT1720 17" LCD Monitor
Acer X193W LCD Monitor Logo
77 people viewed this question
Mohammed Ebrahim M
Mohammed Ebrahim M
