Question about Nintendo DS Lite Console
WHEN PLACING THE CHARGER INTO THE DS THE LIGHT TURNS RED THEN SWITCHES OFF. IF I PLAY WITH THE CHARGER PUSH PUCHING IT SLIGHTLY IN AND OUT THEN THE LIGHT FLASHES WITH EACH MOVEMENT? IS THIS A SHORTAGE OF THE CHARGER OR A DS PROBLEM?
    Problem Solver:
  • 4 Answers
This could be one or the other , both would have the same effect , i would recomed trying someone elses charger to see if that is the problem , and if not it might be the f1 or f2 fuse on the motherboard of the ds..
Posted on Feb 04, 2009
My ds lite battery wont hold chrge, can play for
use the charger so it can be green and then you can play longer
Nov 07, 2009 | Nintendo DS Lite Console
DS Charging Diffuculties
( times out of 10 here its the battery if by replacing the battery it still does not charge you got a bad charging unit inside the DS and your repair bill will be under $75 bucks to replace the chargin element inside.
Like my advice please accept and rate it today. We accept all postive answer ratings , Thanks.
Oct 09, 2009 | Nintendo DS Lite Console
DS Not turning on - both screens flash
Try this if you haven't yet.Take the battery out,read the voltage with a meter,If low your charger is not working.Also if no meter try reinstall batery.Good Luck. DS's are unpredictable,you could not touch it for another month and it will work.
Sep 05, 2009 | Nintendo DS Lite Console
I put the charger in the orange light turns on and I turn on the game and it's still on red after it's still charging for a while
I would say leave it charging for 5 hours tops! if it's still red something is wrong with your DS!
Apr 16, 2009 | Nintendo DS Console
Putin in charger orange light flashes then goes off an doesnt cha
Your DS is either fully charged or the battery got damaged/wet. When you play the DS, is the light red or flash red? If it does, then the problem is with your battery. http://www.nintendo.com/consumer/repair/dslite_repair_home.jsp
Click on your country, then "System and Game Problems," then "Power and Battery Charging Problems."
Hope this helped.
Apr 15, 2009 | Nintendo DS Lite Console
Ds lite charging lite comes on but when i press power button nothing happens
Are you leaving the DS charge until the light comes off? Remember that there are two likes too, one for charging and one for power. If you're just charging for some random period of time (lets say... One hour) then your Battery isn't going to be fully charged. The best way to ensure that your DS Lite is charged is to leave it charge until the charge light turns off. You can play your DS Lite while you are charging (I do it all the time), but it just means that you're just running off of the outlet.
A good test is to charge it fully (until the charge light comes off), unplug the charger cord (Make sure it's secured tightly to your DS while charging), then play for a little bit, your light should be a normal color (green).
If you cannot even play by using the outlet, then you need to
find a charger cord that actually works (You may need to send in the charger for replacement). If the same thing happens with 2 different batteries (assuming that you have two official Nintendo batteries).
TIP: Also run your fingers across the Charger cord. You're going to get a slight friction burn from the rubber, but you're going to get all of the kinks out of the wire in the cord. My charger cord had a similar problem (did not charge all the way, only charged until I moved the DS) but when I ran my fingers across it (pinching) it worked again.
Also check the pins in both charger cords, charging will not work if one pin is missing, nor if any are bent.
May 12, 2008 | Nintendo DS Lite Console
Ds lite
You never want to play the DS while it's charging, if constsntly persisted it can cause a form of battery leak.
IMPORTANT: Don't charge the DS until it dies on you completely!
When charging the DS the system will display a red light to show it's at its lowest energy, the time it takes to fully charge a DS can take up to 2-3 hours. In the second hour of charging the light will appear green but you don't want to disturb it until the light goes off. ( showing it's energy is full )
Nov 03, 2007 | Nintendo DS Lite Console
Nintendo ds
There are a couple of fuses inside the ds and one of them is right up next to where the charger plugs in try to replace it. It is a little flat black piece with solder on each end and it should have a number on it you with need to replace it with the same number fuse.
Oct 03, 2007 | Nintendo DS Console
Nintendo DS Lite Console Logo
111 people viewed this question
Top Nintendo Video Game Consoles & Games Experts
Bee Santiago
Raj Patel
Martin Murray
Are you a Nintendo Video Game Console and Game Expert? Answer questions, earn points and help others
