Question about Indesit WA 115 Front Load Washer
Indesit WIA111 front load wash machine won't work
The machine is 2 years old but hasn't been used for about 8 months. Turn machine on it starts to fill stops abruptly after a second or two then starts to vac out, Door lock led flashes rapidly led by spin-cycle symbol flashes more slowly. Does this on any program, won't stop vacing out until socket is turned off. I used to be an appliance engineer so I don't mind taking it all to pieces if necessary. Any ideas would be much appreciated.Thanks
  • 32 Answers
Hi, check the heating element connections
Posted on Feb 12, 2009
Wia111
Turn the on/off knob to the position with the symbol I enclosed by a broken circle,.
This should turn it off.
Plz rate my solution.
Thanks.
Jan 11, 2009 | Indesit WA 115 Front Load Washer
It starts off ok but 5 mins in to the cycle (any cycle)all the lights start flashing and it just makes a sloshing noise but the drum is still.... .it an indesit wia111
Check the drain pump they haave a catch sleeve inside the drain line before the drain pump. Remove the lower front panel to access the pump and remove the large hose from the drum. Inside the hose is the sleeve, take out the sleeve and clean it.
Dec 11, 2008 | Indesit W 123 Front Load Washer
Three day old Indesit washing machine
Is it a maytag? My maytag front load washing machine had 2 long bolts with plastic braces on them, to keep the drum still during shipping. Mine would bang and shake all over. I got the book out before I finally figured it out. I had to take the back cover off and remove the bolts and plastic braces over them. They look like they' 8 inches long or so. It works great now.
Carolynn
Jul 15, 2008 | Indesit W 123 Front Load Washer
Drum filling with dirty water
hi as your machine got a non return valve on it to stop water from getting into your machine via waste pipe. worst case is call indesit as i am sure you now get 5 years parts g/tee as indesit is now part of hotpoint still cheaper than another machine hope this helps
Jul 11, 2008 | Indesit W 123 Front Load Washer
APPEARANCE OF SCUM
Hey there...
The only thing that can cause this is the filter is blocked, or its needed of a service....
Its not that big a deal but its something in all front and top loaders, it needs a good service at least once a year...
Hope this helps you.
Wouter...
Jun 12, 2008 | Indesit WA 115 Front Load Washer
Door locked
sounds like your interlock has failed you can buy from any appliance spares outlet or online regards jason
Jun 08, 2008 | Indesit W 123 Front Load Washer
Dial spinning on W123
Check your exit hose spigot, it may be clogged. This is if your filter is all clean. There should be air for passage in the standpipe behind. Your hose should not fit airtight into the standpipe and neither too deep into it. Snaking out your standpipe would be good too.
Rate me pl.....if helped.
Jan 29, 2008 | Indesit W 123 Front Load Washer
Indesit WIL103 flashing lights problem
because of the short time this runs then stops, there could be maybe 3 faults, 1 check water inlet valves and supply for water flow 2 check for any motor action (use another programme) 3 check heater element for open circuit number 1 or number 3 sounds most likely hope i have helped, if so rate me please
Sep 25, 2007 | Indesit W 123 Front Load Washer
Error codes for indesit front load washing machines
The F002 error codes relates to a motor problem. Do you know if the motor spins ?
Aug 11, 2007 | Indesit W 123 Front Load Washer
Open Questions:
See all Indesit WA 115 Front Load Washer Questions
Indesit WA 115 Front Load Washer Logo
444 people viewed this question
Top Indesit Washing Machines Experts
Gerry Harvey
Gerry Harvey
neilmoto
Are you an Indesit Washing Machine Expert? Answer questions, earn points and help others
