Question about Sony Ericsson K850i Mobile Phone
Phone goes to voicemail after 15 seconds ,how can i stop this
HOW CAN I MAKE THE PHONE RING UNTIL I ANSWER IT ?
  • 257 Answers
Hi, Sorry you can't, it is not a function of your phone but is a programmed event by the transmitting equipment so that it is not tied up too long. Sorry.
Posted on Feb 02, 2009
  • Jim London
    Jim London Feb 04, 2009
    Hi, I hope I solved your problem, Please rate my response, your
    favorable ratings help others that may have the same or similar
    problem. Thank you!
Increase number of rings before voicemail, vtechcs6419
The CS6419 isn't an answering machine. The phone will ring until you answer, an answering machine or voicemail system picks up, or the caller hangs up.
To change the ring count on an answering machine or voicemail system, refer to the documentation for that system. If you require further assistance, please add a comment to this question and identify the answering machine or voicemail system.
Jan 28, 2014 | Vtech DECT 6.0 Digital Cordless Phone
How do i change the number of rings before voicemail picks up on a samsung rugby
For all of you that want a real answer here ya go. This isn't something you can change on your phone this has to be changed with your service provider. If you are with AT&T, like I am, then this is the solution for you (link of where I found it below as well). 1. enter *#61*11# and press send/talk on your phone.
2. write down the number your calls are currently forwarded to (usually +1401#######, but not always). this is your voicemail deposit number.
3. decide how long you want the phone to ring in 5 second intervals. the maximum time is 30 seconds. i'd recommend 25 seconds or less, as using 30 may cause you to be billed for a minute of airtime each time someone is forwarded to voicemail.
4. now enter **61*[number from step 2]*11*[number from step 3, use 2 digits]# and press send/talk.
example
voicemail deposit number is +14015551212
you want it to ring for 20 seconds
you would enter **61*+14015551212*11*20# and press send/talk.
if you have trouble with the above procedure, you can always call customer care at 800-331-0500 to change it.
OR QUESTION: How can I adjust the number of times my wireless phone will ring before the caller goes to voicemail? ANSWER: Contact Customer Care at 1-800-331-0500 or dial 611 from your wireless phone to change the amount of time your phone will ring before going to voice mail. The adjustments made by Customer Care are based on the traditional ring heard by the caller, not the unique Ringtone you hear from your phone. I just wanted to add that increasing the ring length to 30 seconds will not cause you to be charged a minute should the caller go to voicemail. This was confirmed by an AT&T technician.
http://forums.att.com/t5/Voice-Mail/Increase-the-number-of-rings-before-a-call-goes-to-the-voicemail/td-p/2576651
Aug 11, 2011 | Cell Phones
Would like to reduce the number of rings before going to voicemail on our AVAYA phone.
You will need to go into Manager, and adjust teh voicemail timer. By default it is at 15 seconds. Figure 3.5 seconds/ring when figuring out how long you want it to ring before going to vmail.
Aug 01, 2011 | Avaya 5400 Series 5410 Phone
How do I change the number of times my samsun blackjack phone rings before it goes to voicemail
Go to settings, phone, voice calls, forwarding, unavalible or no answer. In there you can select the number of seconds. Each ring is equal to 5 seconds.
Jan 12, 2010 | Samsung BlackJack II Smartphone
Won't go to Voicemail
You will need your system administrator to change the call reroute assignment of your phone, or you have call forwarding active to a location the system can not route a call to. Either scenario your phone administrator can resolve quite easily.
Sep 02, 2009 | Mitel 5220 IP Phone
Call forwarding only rings once
You will have to have the admin lengthen the voicemail answer time, i would add another 15-20 seconds.....but this will make all calls ring your phone longer before going to vociemail
Mar 09, 2009 | Avaya 5400 Series 5410 Phone
Number of rings before going to voicemail on KX-T7630
Press the FWD/DND button, then scroll through the menu button until the screen shows "FWD No Answer time". Then use the number key pad to change from 000 seconds to 010 seconds (or longer if required). Then exit out of the menu.
Jan 22, 2009 | Panasonic KX-T7730 Corded Phone
Rings before KX-T7736 goes to voicemail
This is just the quick answer and may not be exact. System program 203 is the intercept time. It's probably set by default to 40 seconds. A ring cycle is about 6 seconds. Try adjusting that down to, say, 20 seconds and see if that works. I have your exact setup in my office, but I'm not in my office for the rest of today. I may get a chance to play with the timing on Saturday.
Carl
Nov 06, 2008 | Panasonic KX-T7736 Corded Phone (KXT7736)
Nokia 6120 Classic longer ringing time
This is an operator supported feature. You need to punch in this code.
**61*destination*11*nn#[SEND]
destination is the number the calls get diverted to
nn = time in seconds (5/10/15/20/25/30)
This will work if you operator have not disabled this code.
Dec 30, 2007 | Nokia 6120
LG Chocolate, De-activate Voice Mail?
There isn't a way to disable voicemail cause it automatically fowards the call.
Oct 12, 2007 | LG CHOCOLATE VX8500 Cellular Phone
Sony Ericsson K850i  Mobile Phone Logo
Top Sony Ericsson Cell Phones Experts
Computer Repairing
Computer Repairing
Sandeep Shenoy
Are you a Sony Ericsson Cell Phone Expert? Answer questions, earn points and help others
