Question about Zebra Stripe S600 Thermal Label Printer
Speed of printing barcodes
How do you speed up the printer so that it doesnt pause between printing barcodes?
  • Stephen Clouthier
    Stephen Clouthier May 11, 2010
    Depends on the amount of barcodes your speaking of. if your talking 5-10 then the pause is a page break in your formating. If your talking hundreds from a batch report then the pause is more than likely for the printhead to cool down.
    So what type of printing are you speaking of?
    Problem Solver:
  • 10 Answers
Generally the ZM 400 can cope with printing at the lower speeds when printing barcoedes that are the same. You may get pauses if the barcodes are sequential numbers or are all different, then the data to be transfered to the printer cannot cannot keep up with the printer and pauses while it gets more data. We have found that if you can select in your labelling software to print the barcode as a graphic, then it speed up quite a lot. It is a matter of matching your print speed and quality to match your expectations, sometimes you will just have to put up with the pauses.
Posted on Feb 17, 2009
Hello, I have a problem with Zebra Z4M Plus
Hi, if is the vertical line, its the print head that need to be replaced,
try to clean the print head and try this to confirm:
turn printer off, press PAUSE button and at the same time, power on, don't release the button, please wait until printer LCD screen come on, then release button. It will print the PAUSE test and after few 3-4 prints, u can turn off and on again otherwise printer not ready to print your labels until u restart it. (pause test stops after 10-15 labels). this pause print just show how the print head is and if come with vertical lines, u will need to replace. other idea is (if u can) turn the bar code different position or on vertical way at label format. Thanks.
Aug 04, 2013 | Zebra Office Equipment & Supplies
Intermec printer prints slow
The print speed is surely the bottleneck. I did find this:
http://apps.intermec.com/downloads/eps_man/937-028-003/Content/Print_Speed_Set.htm
Page 65 of the manual discusses adjusting the print speed, for "fingerprint" not IPL. (I'm not sure what that refers to, but it appears to be the language used by the printer.)
Jan 20, 2018 | Intermec EasyCoder PM4i Thermal Barcode...
Z4m printer problem
You may have an element or two on the left side of the printhead that is worn out and not printing. The best way to see if elements are not working is to use the widest label you have and run the PAUSE test. Turn the printer off, press and hold the PAUSE key while you turn the printer on. Keep pressing for about 10 seconds and then you can let go. When the printer is finished starting up, a test pattern will print. Part of the pattern is a black box. Any elements that are not working will show as white vertical lines. The only way to correct is to replace the printhead.
Hope that helps !
Jun 09, 2010 | Zebra Z4Mplus Label Printer
Gaps in barcode with Zebra S4M
By gaps, do you mean a "void" area ? Over time, the elements on the printhead will wear down and finally they won't transfer heat to the ribbon. This causes a gap or void area. Usually the elements go out one or two at a time. If the area that is worn out is supposed to be printing bars for the barcode, this will cause the scanning problem you are experiencing.
The best way to see if elements are worn out is to design a label that has a thick solid black line across the label or a solid black box. You will see white vertical lines in the areas where elements are worn out. Another method would be to use the widest and longest label you have and print a 'pause" test label. This is done by turning off the printer, pressing and holding on the PAUSE key while turning on the printer. Hold the pause key for 10-15 seconds and when the printer is done with it's power on self test, it will start printing out a test pattern label which includes a nice black area where you can look for the white vertical lines.
Hope that helps !
Mar 30, 2010 | Zebra S4M Thermal Label Printer
Ladder orientation barcode printing bad resolution needs correcting
Try slowing down the speed of the printer. Faster speeds degrade the quality of your print. Try printing your serial (ladder) barcodes at 2-4 inches per sec. It should improve the quality of your format.
Apr 13, 2009 | Zebra Z6M Plus Thermal Barcode Label...
How do you speed up the printing speed on a Paxar 9800/9850?
Press "escape"
Press Right arrow til display says "setup"
press "enter"
Display now says "supply"
press "enter"
right arrow til you see "speed"
press enter
adjust print speed IPS is "inches per second"
press enter after you change speed. hit escape key 3-4 times, then enter - you should see "print mode ready
If speed doesnt change it could be because the print speed is set by the software OR by the type of barcode you are printing. Serial barcodes default to 2.5 ips.
Apr 08, 2009 | Paxar Monarch 9825 Thermal Label Printer
How do you speed up he printing speed on a Paxar 9800/9850?
Are you printing a serial or parallel barcode? If you don't know, a serial barcode looks like a ladder as it prints out on the label. A parallel barcode looks like a picket fence. A serial barcode (ladder) prints at 2.5 ips by default. You can't increase the speed. If you're printing a parallel barcode (picket fence) you must hit "enter' once you adjust the speed setting in the printer menu. If you've done that and it still won't increase speed, then the speed is set by the software itself, and overrides any changes you make in the printer menu. The speed adjustment must then be made in the software, not the printer.
Apr 08, 2009 | Paxar Monarch 9850 Thermal Printer
Datamax I 4208 prints slow when set to landscape
try using a seagull sceintific driver.
also if you are sending graphics (barcode) instead of an actual barcode decoded font, the printer will process as a graphic.
If serial, speed up to max, if parallel it should print quite fast
Jan 21, 2009 | Datamax M-4208 Thermal Label Printer
Manual calibration of labels not working, printer not feeding labels correctly
printer manufacturers has different standards depending from the varieties of model and brand of printers for example an epson printer model who is older version is not the same speed print with the recent model likewise with the other brand. Therefore calibration of labels is depending to the version of the printer you are using now.
Apr 22, 2008 | Zebra Z4Mplus Label Printer
Can't get barcodes to scan?
have you tried different darkness settings? it sounds like you only need to turn the darkness up a little.
Apr 02, 2007 | Zebra 110XiIIIPlus Label Printer
Zebra Stripe S600 Thermal Label Printer Logo
239 people viewed this question
Top Zebra Office Equipment & Supplies Experts
Dave Busselle
Level 1 Expert
Are you a Zebra Office Equipment and Supply Expert? Answer questions, earn points and help others
