Question about Nokia 6682 Cellular Phone
Nokia 6682 Phone Memory Full
I have a Nokia 6682. it keeps saying full memory. It has 1MB internal memory, only 128kb free. I don't know why, i moved everything to external (card) memory (I have lots of free card memory) . If I add all the internal memory used items (messages, contacts, etc) I get something like 300kb, looks like the memory is lost somewhere. Is there a solution? can it be "formated"?
Lately it doesn´t display who is calling me, and last dialed numbers don´t show.(this has been happening for the last 2 months). Local provider (Movistar) doesn´t know what the problem is.
I would appreciate some help, thanks.
    Cheetah:
    An expert who has answered 20 or more questions within one hour.
  • 158 Answers
Make sure that there are no hidden files or applications that consumes the memory... 1 MB is not that huge to accomodate more files
Posted on Feb 03, 2009
My cp is nokia N70... my problem is its says "memory full delete some data first" ive already format my memory card so then my free mb is big but its the same problem nothing changes i have a...
YOU NEED TO FORMAT YOUR PHONE NOT MEMORY CARD.FORMATTING THE PHONE WILL SOLVE YOUR PROBLEM.AND TO AVOID PROBLEM IN FUTURE INSTALL APPLICATION MANAGER ON YOUR PHONE AND WHENEVER YOUR PHONE SAY MEMORY FULL JUST USE THIS SOFTWARE TO COMPRESS MEMORY.
THERE ARE TWO METHOD TO DO FORMAT NOKIA HANDSET.
  1. MANUALLY.
  1. OPEN MENU>SETTING>PHONE SETTING>FACTORY SETTING.
  2. PRESS O.K. A MENU WILL POP UP LIKE YOU LAST ALL YOUR DATA PRESS O.K.
  3. IT WILL ASK FOR CODE ENTER CODE( DEFAULT CODE IS 12345).
  4. PRESS OK IT WILL DO FORMAT YOUR PHONE.
2. USING CODE.
  1. DIAL *#7370# ON MAIN SCREEN.
  2. A MENU WILL POP UP LIKE FORMATTING PHONE.
  3. PRESS OK IT WILL ASK FOR CODE ENTER 12345 AND PRESS OK
  4. IT WILL DO FORMAT FOR YOU.
3.METHOD NO.3(FOR S60 SERIES MOBILE)
  1. SWITCH OFF YOUR PHONE.
  2. WHILE SWITCHING ON PRESS THREE BUTTON AT THE SAME TIME.(1.GREEN DIALING KEY 2.*KEY,3 KEYPAD NO. 3 KEY) WITH POWER ON BUTTON.
  3. A MESSAGE WILL POP UP LIKE FORMATTING. HOLD BUTTON FOR 3 SECONDS AND RELEASE THEM AFTER THAT.
  4. YOUR PHONE WILL RESTART AND ALL YOUR DATA WILL BE GONE
Mar 11, 2011 | Nokia Unlock N70 N71 N72 N90 6630 6680...
Nokia n97- always say's my memory is full and say's that i need to delete memory from the phone memory.
it might be your internal memory in full and you should delete or move your data in internal memory to your sd card.
Feb 28, 2011 | Nokia Lands Phones
My nokia n72 says memory full when i have enough memory
the main reason the phone says memory full is if your text message inbox/outbox/drafts are full so try deleting all the ones you dont need.
Also another way of freeing up loads of memory would be to delete all the ringtones you dont use such as the ones you get free with the phone as you dont tend to use these so deleting them will free up loads of memory.
Also delete any pictures you dont need as this to takes up loads of memory so try deleting as much as you can as this will then free up your phone ok.
Let me know how you get on or if you need further assistance ok
Dec 29, 2009 | Nokia N72 Cellular Phone
My nokia n72 keeps on saying memory full delete some files...I have nothing on my memory card yet. What am I supposed to do to fix this...Please HELP!!!!!!!!!!!!
hie!
if ur cell is displaying the memory full warning, it means ur phone memory is full, try to reduce some software frm the phone memory, and always install the softwares on ur memory card whenever it ask to install the path, while installing a software.
if the problem is still there, of memory full after emptying ur phone memory, then soft format ur cell, by pressing *#7370# and then the security code(12345 by default)
bt before that backup all ur important datasuch as contacts and mesages of the phone memory, as then soft format reset all the settings and flash all the phone memory.
bunty
May 02, 2009 | Nokia N72 Cellular Phone
Automatic restarting problem with Nokia 3110c mobile phone
Normal 0 false false false MicrosoftInternetExplorer4 /* Style Definitions */ table.MsoNormalTable {mso-style-name:"Table Normal"; mso-tstyle-rowband-size:0; mso-tstyle-colband-size:0; mso-style-noshow:yes; mso-style-parent:""; mso-padding-alt:0in 5.4pt 0in 5.4pt; mso-para-margin:0in; mso-para-margin-bottom:.0001pt; mso-pagination:widow-orphan; font-size:10.0pt; font-family:"Times New Roman"; mso-ansi-language:#0400; mso-fareast-language:#0400; mso-bidi-language:#0400;} This is what happens. Nokia 3110 hangs, gets switched off and restarts randomly. More often, it restarts around 3 times or so and then gets switched off.
Possible Causes and Solutions Cause 1 - Phone Memory Full - Nokia 3110c mobile phone has got 9MB of internal memory.
Solution - Keep the free space between 350 to 500 KB, so as to keep things running smoothly on your phone and prevent Nokia 3110c from restarting.
Cause 2 - Changing Themes - Some people have reported that the phone restarts automatically when they try changing display themes on the phone.
Solution - Don’t get your phone loaded with too many themes downloaded from the internet or atleast, don’t switch themes frequently. These themes, mind you, also load up things into your already falling Nokia 3110c phone memory.
Cause 3 - Memory Cards - Some people have reported that Nokia 3110c restarts due to some issues with the memory card.
Solution - Remove the card, get it formatted and then insert it back and then restore factory settings. This just might solve the issue.
Cause 4 - Transferring data via Blueooth / USB data cable (or) Updating Music Library - A few people have reported that their Nokia 3110c mobile phone restarts when updating the music library.
Solution - Don’t try updating of music library frequently or don’t often transfer data in/out of your Nokia 3110c phone.
Cause 5 - MP3 files
Solution - This may seem dumb, but consider converting all your MP3 music files to WMA and then store them on the memory card. Some users suggested this.
Feb 12, 2009 | Nokia 3110 Cellular Phone
My renoir says memory full.
I had this problem with two Renoirs and finally managed to fix it yesterday after months and months!
I went into browser settings and hit reset settings. I took ages and I thought it had frozen but when it finally finished I had 69% free in common memory!
That worked on both my phones so might be worth a try.
Good luck
Feb 07, 2009 | LG KC910 Renoir Cell Phone
Formatting internal memory of nokia 3110c
Normal 0 false false false MicrosoftInternetExplorer4 /* Style Definitions */ table.MsoNormalTable {mso-style-name:"Table Normal"; mso-tstyle-rowband-size:0; mso-tstyle-colband-size:0; mso-style-noshow:yes; mso-style-parent:""; mso-padding-alt:0in 5.4pt 0in 5.4pt; mso-para-margin:0in; mso-para-margin-bottom:.0001pt; mso-pagination:widow-orphan; font-size:10.0pt; font-family:"Times New Roman"; mso-ansi-language:#0400; mso-fareast-language:#0400; mso-bidi-language:#0400;} Possible Causes and Solutions Cause 1 - Phone Memory Full - Nokia 3110c mobile phone has got 9MB of internal memory.
Cause 5 - MP3 files
Jan 14, 2009 | Nokia 3110 Cellular Phone
Problem with sending a text message
hello alexann, Your phone is out of ram memory. Symbian phones use the internal memory as rom memory (dinamically allocated) ram memory (for user programs) and firmware storage. If the internal memory is almost full the phone will begin to give you such errors because it can't load into ram the text aplication that is require to start in order to process sms messages. Please try to avoid to fill the internal memory and instead move anything from it to the memory card. A full internal memory can result in slow phone operation, errors, program crashes or even the failure to boot-up (start) the phone. Therefore, in your case you should try to free more internal memory (phone memory) and check the sms folder to see if you can send messages. If this doesn't solve, you may have a virus or a bad program installation that corrupted symbian OS's registry. This will require to hard reset the phone. Please come back with a reply if these methods fail. Good luck!
Jun 06, 2007 | Nokia 3230
Nokia 6682 Cellular Phone Logo
80 people viewed this question
Top Nokia Cell Phones Experts
Computer Repairing
Computer Repairing
