Question about Sharp AR-207 Copier
I have a Sharp AR-M207 Copier , it has H2-00 on the display , how do I fix this .
  • Anonymous Mar 18, 2014
    my sharp ar-m207 displays f2-04 at start up
Perform the following procedure to enter the simulation mode.
"#" key “*“ key "C" key “*“ key then enter 14 press start machine will switch off then on
Posted on Feb 02, 2009
MY SHARP AR-M207 DISPLAY ERROR CODE L4-00 KINDLY GIVE ME A SOLUTION
Hi Alafin,
An error code of L4 suggests a motor error. It could be something as simple as a loose cable but it could be a bad motor. I would suggest you call on a local dealer to repair this as you will probably need new parts.
Jun 14, 2016 | Sharp Used AR-M207 Copier Printer Scanner
I need a printer software to enable me print with my window 7 software
To help you install printer software for Sharp AR-M207, please find the link given below and find the topic mentioned as 'Software' and select Windows xp:
http://www.sharp-cee.com/cps/rde/xchg/scee/hs.xsl/-/html/product_details.htm?product=ARM207
GuruAid.com
Mar 31, 2016 | Sharp Used AR-M207 Copier Printer Scanner
I need a software that can enable me print from my 26 bit computer and my copier AR-M207 PHOTOCOPIER
You can download a printer driver from here.
http://www.sharp-world.com/support/download.html
Microsoft is ending support for Windows XP so I would suggest updating your operating softwaere.
Mar 09, 2016 | Sharp Used AR-M207 Copier Printer Scanner
Call for sevice 4H-00
enter the following on the machine ar-m207 #-___ * ________ C____* very fast the machine would display simulation then type 14 and OK,then press print button.press the press button consistently and machine restart by itself.
Dec 19, 2012 | Sharp AR-M207 All-In-One Laser Printer
Hi i refil the toner for my sharp ar-m207 and later the copier say add toner can not print or copy help my please
You have to replace the whole toner cartridge because there is a crum chip on the back of the toner cartridge. When the cartridge reaches empty and the copier says change toner the copier burns that chip so it can not be reused again.
Aug 24, 2011 | Sharp AR-M207 All-In-One Laser Printer
My copier is sharp AR-M207 all in one printer is problem E1-00
Communitcation error between the MCU PWB and the IMC PWB. Check connections.
Aug 24, 2010 | Sharp AR-M207 All-In-One Laser Printer
Lost key operator code for Sharp Copier AR-M207.
The default is 00000
Simulation 22 - 07 will display the Key operator code.
"#" key -> “*“ (star) key -> "C" key -> “*“ (star) key (do this in quick sequence order, the display should change, then enter below)
Main code {22} ->
(Green Copy Button) Start key ->
Sub code {07} ->
(Green Copy Button)Start key
Press the "CA" button to go back to Copy mode.
Jan 24, 2009 | Sharp AR-M237 Copier
Sharp AR-207 Copier Logo
511 people viewed this question
Top Sharp Office Equipment & Supplies Experts
Anthony Karuku
jasbo
jasbo
Adorjani Laszlo
Are you a Sharp Office Equipment and Supply Expert? Answer questions, earn points and help others
