Question about HP DeskJet 3740 InkJet Printer
HP3740 won't print-indicates paper jam with each new job
Every job I send to the printer, it requires repeated rebooting of the printer as a paper jam message comes up .....there is no paper jam. Any ideas on a permanent fix?
  • Anonymous Apr 11, 2009
    Same Exact Problem - please help!
Thang you
Posted on Feb 05, 2009
Red light is constantly blinking and when try to print, there is always a paper jam
Every time there is paper jam, the printer knows the job is not completed and hence tries to re-print after the paper is removed and cover is shut.
Clear the print job from computer.
Power off the printer and Clear the paper jam (if any)
I would try to use different tray. The paper pickup roller in one path may be worn out.
eg Sheet feeder or multipurpose tray.
Load paper in new tray
Set the application to use new tray
Ensure you sue the right thickness (gsm) of the paper. Quality of paper is crucial. Too thin; too thick can affect functioning.
Mar 16, 2016 | Ricoh Aficio Sp 3300DN Laser Printer
How do I take Canon imageCLASS D320 All-In-One Laser Printer off from "paused" status?
On the printer properties on the computer there will be a paused option (Normally marked as "Pause Printing") in the printer drop down menu on the Printer Queue screen. Click this to remove the tick next to it and it should start printing again.
Feb 20, 2015 | Canon imageCLASS D320 All-In-One Laser...
Gympac 1600 manual
Device error An internal error occurred in the device. Press (Select) to resume the job. - Door open The printer door is open. The door must be closed before printing can continue. - Engine comm. error The device experienced an internal communication error. This is a warning message only. Job output might be affected. - Invalid driver You are using the incorrect printer driver. Reselect the printer driver appropriate for your device. - Invalid entry Invalid data or response. Correct the entry. - Jam in Cartridge area A paper jam has occurred in the print path. Open the door and clear the jam. Then press the (Select) button on the control panel - Jam in Output bin A paper jam has occurred in the output area. Clear the jam, and then press the (Select) button on the control panel. - Jam in print paper path. A paper jam has occurred in the print path. Open the door and clear the jam. Then press the (Select) button on the control panel. - Jam in tray 2 A paper jam has occurred in Tray 2. Clear the jam, and then press the (Select) button on the control panel. - Jam in tray 3 A paper jam has occurred in Tray 3. Clear the jam, and then press the (Select) button on the control panel - Load paper The HP Color LaserJet 1600 printer is out of paper. Please load specified paper type into the tray indicated. - Load Tray X [TYPE] [SIZE] The printer is processing job, but the tray indicated is empty. Please load specified paper type and size into the tray indicated. - Manual feed The printer is waiting for paper in the tray indicated Load the paper as indicated. - Memory is low The device memory has been almost completely filled. Allow the device to finish the job, or press (Select) to cancel the job. Break the job into smaller jobs that contain fewer pages. - Misprint The printed pages have been incorrectly placed on the paper. To continue, press the (Select) button on the control panel.
Dec 31, 2014 | Office Equipment & Supplies
HP C7280 wont print custom size card stock 7.25 x10.25 wont feed or paper jam, however will print when fed on the left side but no guide to keep paper straight. how to correct this issue, Ive cleaned
Your question does not provide all the information necessary to absolutely resolve the issue. By now I suspect you've already resolved the issue or given up. Perhaps someone can use this info.
Need to know: Operating System (Windows 95/98/Vista/XP/7/8), Application (Word, Paint, Firefox, etc), type of job (jpg, pdf, text, etc.)
There is no short answer possible; but, I may be able to help with a generic answer. I can't help on Apple but I suspect it's the same as Windows, (and Unix, Linux, OS2, etc.).
Provided the Printer works proper on normal 8 ½ x 11 stock (print media) then it is not a printer or Queue issue unless it is just confused. As a printer technician I have seen this resolved by rebooting the machine(s) and trying to print again. If that doesn't resolve the issue you need to know:
The application you send the print job from tells the Queue what stock (letter, legal, card, envelope etc) to expect. The Queue, a component of all versions of Windows, is created when the printer is initially installed on the computer. The Queue holds print jobs and then sends them on to the printer when the printer tells the Queue it is ready. Some applications are more robust allowing more options than others. However, printing from inside a browser is frequently sketchy. If you're printing from an application that is different from the one that created it you may face an issue of the printer not getting the correct stock information.
Very Important: First before you attempt to send the print job check the settings in the app to insure your job has the right paper stock selected. Then, as you prepare to send the job from the app to the Queue before you hit the final "Print" button, check the "Paper Source/Size/Media" boxes in the "Printer Properties" to make sure your sending the right stock information. If that doesn't fix it; try to save your project in a format readable by another application and try to print it from the other app.
Note: 1. Print jobs are served to the printer by the Queue one at a time on a FIFO (First In First Out) basis. Sometimes print jobs get hung up in the Queue. A hung print job will block all subsequent jobs until the hung job is cleared. When a print job is sent and nothing happens (no printer activity or error messages on the screen.) look in the System Tray for a printer icon. Open it up and see if there are any jobs hung. If so cancel them and start afresh. This may require a reboot.
2. Print Queues can (rarely) become corrupt and must be deleted and rebuilt.
There are still variables too numerous to mention.
You can get HP Support at
HP Photosmart C7280 All in One Printer support
Whew! I've never tried to help resolve this issue in a post. Good Luck!
Dec 28, 2014 | HP Photosmart C7280 All-in-One Printer
Fix repeated paper jams on Lexmark 901 Pro
If you are getting a jam and there is no paper visible then a likely cause is a false jam that is caused when the paper is not picked up from the tray at the start of printing. Send a print job and listen closely. If you can hear the pickup rollers turning but no paper is being pulled into the printer then either the rollers are dirty or are worn and need to be replaced. Trying printing from a different tray or the manual feed tray to eliminate a fault with a different component on the printer.
Oct 14, 2014 | Lexmark X Office Equipment & Supplies
How do I repair Paper jam message but no jam
First step is to unplug your printer, leave it unplugged for 30 seconds and then plug it back in.
Aug 03, 2014 | HP Hewlett Packard Laserjet Pro 200 M275nw...
Orange light blinking, cleared paper jam, changed printer cartridge, won't print subsequent documents.
Double check all doors/ rollers for small pieces of paper stuck in the rollers. Sometimes just opening the door in question and closing will reset the paper jam sensors. Paper jams can be smaller than your pinky finger nail. So double check,
Comment if it still isn't working.
Oct 21, 2011 | HP Deskjet F335 All-In-One InkJet Printer
Hp office jet l7680, paper jam, however no visible paper remaining, jam indicator still flashing.
If the printer shows ready and after you send the print or copy job it gives you paper jam, then the problem is with the pickup roller.
Let me know and I will help you further.
Oct 13, 2011 | HP Officejet Pro L7680 All-In-One Printer
When i power on my printer, its blinking indicating there is paper jam and no paper are in the tray, its also blinking at the part. kindly advice on how to go about it
if a computer is trying to send a print job, a no paper situation will make the printer think the paper jammed when it tried to pick it up.
Put at least one piece of paper in the tray.
If a page comes out, determine what computer is generating it, and kill the print job at the computer.
Then turn the printer back on and see if the error is gone.
Easier test - disconnect everything but power from the printer. have at least 1 sheet of paper in the tray. Power it up. If everything is normal, you need to track down the machine on the network that's trying to send a print job.
Mar 15, 2011 | HP LaserJet P2015 Printer
There is a paper jam
The solution depends on which type of printer and which model it is. Generally, you must open the access door/compartment and try to get the paper out. I had a bad paper jam last week and I had to open the access door (same access area you use to change out the ink cartridges) and do a lot of pulling and maneuvering. Don't force the paper too much or you might break the printer.
Mar 06, 2011 | Kodak Office Equipment & Supplies
HP DeskJet 3740 InkJet Printer Logo
351 people viewed this question
Seeker5211
Seeker5211
mukhtar21 shaikh
mukhtar21 shaikh
