Question about IBM 6400 Matrix Printer
Cutting letters off in 2 spots down whole report
I have an IBM 6400 matrix printer. Recently it started "skipping" parts of letters. Now in that same spot all the way down the sheet it cuts out part or all of the letter that should be printed there. Someone told me the actuator needs cleaned. How would I go about doing this?
  • cgrider2009 Feb 05, 2009
    Thank you that was very helpful. It ended up being the Fret (actuator) that needed replaced and unfortunately, we print clear across the page with some reports so we replaced it.
    Thanks again!
  • 26 Answers
IF trouble in first row - you ribbon is tracking wrong - replace
You may have junk in the ribbon mask also. No parts needed for that. You need to rotate the hammerbank. Remove ribbon and black cover, the whole shuttle will tipback toward you when you unscrew the allen wrench - watch out for the paper tractors they will hang on the ribbon mask. The ribbon mask is held on by magnetic field - just pop off carefully. clean holes with toothbrush and water - dry. (if the trouble is a bad actuator - 4 allen screws to remove a group of hammers - if using short paper - you can use a group from the end of the printer). reverse to fix
Posted on Feb 04, 2009
Printing last page first
Driver, the printer can't even hold one page in memory let alone many pages.
Jan 17, 2014 | IBM 6400 Matrix Printer
Ibm 6400-08p matrix printer service centre in tamilnadu where?
Might not find any anymore, IBM has discontinued and no longer supports the IBM 6400 series printers and or any printers at all. If you need some support or printer parts please contact me. Rory 708--597-4222
Sep 15, 2011 | IBM 6400 Matrix Printer
Hello I have an IBM 6400 printer at work. It prints documents, but every now and then it will print the documents with a white streak running down the paper, like it doesn't print in that spot. I tried...
Hi there, I hope you haven't throw away the printer.. :)
i face similar problem.. its solve by tightening the ribbon latch screw that secure the latch to the ribbon motor.
Feb 02, 2011 | IBM 6400 Matrix Printer
My printer is skipping characters....any idea what I can do to fix it?
try changing the font of the whole document and print again, at times some rear fonts are not recognized by some printers.
Jan 07, 2011 | IBM 6400 Model i10 Matrix Printer
How do I print Microsoft Word documents on an IBM 6400 matrix printer?
What driver are you using for the printer?
Also, when you go to print the document, you will see a printer listed on the top of the print menu screen.
Next to that, there will be a down arrow. Click on the drop down arrow and select the IBM InfoPrint printer you want.
Don
Jan 05, 2010 | IBM 6400 Matrix Printer
IBM 6400 Dot Matrix Printer - Need Drivers for Windows XP
Try running couple of these test, to see if it might be another issue.
It should be printing these test at 1500 Line Per Minute... ?
1500LPM is at 10CPI if you have (Font size: 6, 8, 12, 14) it will make a difference.
Change your driver to Generic/Text, rerun your report... any difference?
Apr 15, 2009 | IBM 6400 Model i10 Matrix Printer
I need instructions for tractor replacement on IBM 6400 printer
GO ONLINE ASK THE FOLLOWING:
WWW.IBM.COM/SERVICE
IBM 6400 TRACTOR REPLACEMENT INSTRUCTIONS
SERVICE MANAUL IBM 6400 PRINTER
IBM 6400 TRACTOR ASSEMIBLEY/DETAILS
ROD
Apr 02, 2009 | IBM 6400 Matrix Printer
Controller voltage Problem in IBM 6400 Printer
When you power on the printer, do you hear the fans kick in? If you checked the Maint. Man. skip steps 1 & 2, almost 80% of the time its CMX brd, not knowing your 6400 model? Part# for CMX 40mhz 157450-901, older models have 155802-901 CMX 25mhz V5.5...
Oh yeah if u don't hear fans kick in when you first power up, 80% jumps to 95% chance CMX bad.
I hope you have a current configuration print out! it will save headaches and a lot less down time...
Jan 24, 2009 | IBM 6400 Matrix Printer
Trying to use a jet direct box to make this a networked printer.
To "unlock" the operator panel on the IBM 6400 Line Matrix Printer, depress the Scroll Up and Scroll Down keys at the same time. On the IBM 6500 Line Matrix Printer, depress the Return and Enter keys at the same time.This acts as a toggle; if locked this action will unlock the panel, ifunlocked this action will lock the panel. The operator panel willindicate briefly which function is being performed. The printer powersup with the operator panel "locked."
IBM - Unlocking the Operator Panel on the IBM Line Matrix Printers
Nov 12, 2008 | IBM 6400 Model 010 Matrix Printer
IBM 6400 model 050
try part number 170613-001
Jul 23, 2008 | IBM 6400 Matrix Printer
IBM 6400 Matrix Printer Logo
203 people viewed this question
Top IBM Office Equipment & Supplies Experts
James Cagle
James Cagle
Don  Farrell
Don Farrell
Jim Keysor
Are you an IBM Office Equipment and Supply Expert? Answer questions, earn points and help others
