Agfa Arcus II Flatbed Scanner
Problem for Agfa Arcus II Flatbed Scanner
Flatbed scanners and Newton Rings
By Charlie - usenet poster
Has anybody come up with a method to eliminate or reduce
newton rings when scanning film negatives on a flatbed scanner?
I've got a linotype-hell saphir with linocolor 5.1 and I get mixed
results when scanning color negatives, sometimes rings,
sometimes not.
Am I hoping for too much from a flatbed scanner? I'd like to hear
ideas on film only scanners (I need to scan 35mm, 2.25" and
4"x5") Any suggestions in the 2-3 thousand dollar range?
thanks
kevin
Solution #1
posted on May 29, 2009
Not Rated)
rhrizvee
Rank: Apprentice
Rating: 0%, 0 votes
You can use some hair spray with fine mist on the transparency the side that touches the glass of the scanner and if the enlargement is more than 250 % you can use some gel/oil (long time ago used to be called as scan gel i dont know if it is still available) again on the side that touches the glass. Put a couple of drops of oil or gel on the transparency and tape the edges of the transparency leaving some gap and squeeze out the bubbles if there is any between the transparency and the glass with this way you can enlarge as much as the grain of your transparency allows,
Good Luck,
Rizwan Haider
Was this helpful?
Yes
No
Solution #2
posted on Aug 01, 2007
Not Rated)
Perkins
Rank: Apprentice
Rating: 0%, 0 votes
It seems you need to have a space between the two planes of glass and
the slide. Some scanners (e.g. Afga) come with slide holders for
un-mounted slides to provide the spacings. I guess you can try to make
your own holder with cardboard.
Was this helpful?
Yes
No
Solution #3
Not Rated)
Bomber
Rank: Apprentice
Rating: 0%, 0 votes
Try using anti-Newton's rings powder which you can get from a prepress
shop. Alternatively, Baby Powder can be used. You need to coat the
surface with a small amount of powder. Clean off the film with a
blower, then a brush, then a film cleaner. You may have some success
with Paraffin film oil. All of these methods are tricky and take
practice. See 4-9 of "Essentials of Digital Photography" by Kasai &
Sparkman.
Peter
Was this helpful?
Yes
No
Solution #4
Not Rated)
Jimmy NY
Rank: Apprentice
Rating: 0%, 0 votes
hello kevin .. the rings are formed when the film contacts the glass
.. i use a frame to raise the film just off the surface .. no rings at
all .. harry
Was this helpful?
Yes
No
Solution #5
Not Rated)
Peter1
Rank: Apprentice
Rating: 0%, 0 votes
There are more extreme solutions, too, like using a special oil meant for
floating film on drum scanners, but merely separating with air should
solve the problem.
I really liked the Agfa Arcus II for scanning film and flatbed; I've
always been dubious about dedicated film scanners, because of their lack
of flexibility and their usually persnickety software and hardware.
Glenn Fleishman, unsolicited pundit: read my work #
search and price compare if you know the book's ISBN # : #
chair, Web Marketing '99 in Monterey, Cal. #
Was this helpful?
Yes
No
Solution #6
Not Rated)
Peter1
Rank: Apprentice
Rating: 0%, 0 votes
I regularily scan Medium format negatives (6 x 4.5cm) on my HP ScanJet 4C
Scanner with Tranny Hood. You can see a sample as picture 1 on page:
I dont know what scanner you use or interface, however the main trick is to
scan with no exposrue correction in the scanner software, dont even invert
it. If your interface allows then sharpen at highest point and bring into
photoshop. Invert it in here and under variations add about 4 reds and three
yellows then darken the picture to your taste. You can then try auto levels
(Undo if not desirable) and the grey color picker under Image/Adjust/Levels,
and pick up a middle grey. This should eliminate color casts. Play with the
color balance, brightness contrast and try to slide the Hue slider a bit to
each side to see the results. It is touch and go and no two negs are alike,
but all are invertible.
I scan @600 DPI, and have made very good qulaity prints upto 6' x 8'. Bigger
sizes like 6 x 6 or 6 x9 will result better.
Cheers
NSAY
Posted via Deja News, The Discussion Network
# Search, Read, Discuss, or Start Your Own
Was this helpful?
Yes
No
Solution #7
Not Rated)
Hart
Rank: Apprentice
Rating: 0%, 0 votes
Converting color negatives to positives (for those without HP
PhotoSmart Scanner)
Peter
Was this helpful?
Yes
No
Popular Solutions for Agfa Arcus II Flatbed Scanner
Questions and Unsolved Problems for Agfa Arcus II Flatbed Scanner
Do you recommend Agfa Arcus II Flatbed Scanner?
Answer
Answer
I have an Arcus II Flatbed Scanner that I was using on a Power Mac. I purchased a new G4 Mac and... (More)
Answer
Hi can someone help I have losted my transparency template which the book says ' be sure this... (More)
Answer
This Scanner is awesome--- however, when going to scan from my Apple G3 today a Dialogue box... (More)
Answer
Troubleshooting Agfa Arcus II Flatbed Scanner rattles when..attempt to scan. This scanner was workig... (More)
Answer
I have Arcus II Scanner SCSI interface I would like to update driver to work on 10.4 OS Mac I would... (More)
Describe your Scanners problem:
Ask our Experts
Solve Your Problem Now!
Chat Live with an Expert
Chat Now
Top Scanner Experts
Top Printer Repairmen
(800) 836-9287
Celebrating 14 Years Of Outstanding Printer Repair...
Laser Repair 911
(972) 907-9771
Printronix, IBM, Tally, Genicom, TallyGenicom,...
Sinca Printers, Parts & Repair
Chat Now
Insert Link
Insert Image
Insert You-Tube clip
Insert List
Insert List
Spell Check
What is this?
Select
