Question about Imperial IR-6-RG24 Elite Gas Kitchen Range
Temperature Need to adjust temperature on stove. Do you have an online service manual? I have the same problem--anyone got a solution? How about a service manual?
  • 2 more comments
  • ssunshine Feb 02, 2009
    The oven temp stays at 113 degrees. I am trying to conserve energy and want to turn it down. Is that possible and if so, how?
    The temp stays at 113 degrees in the off position. Is that normal? Is it possible to turn that temp down in an effort to conserve LP gas? Sorry for any confusion in my question. If you don't know, I'll call the company.
    Thank you, you have tried very hard to answer my question. But unfortunately, it has not helped the problem. Guess I will call the local service man and ask him. Thanks again.
    No, the solution was not helpful to solve the problem, but the person tried really hard to help which I greatly appreciate. Now, I can either call the company who will tell me to call a serviceman. So, I will go directly to the serviceman.
  • 19,396 Answers
Service manual is not available for online download, contact Imperial Range and ask them a copyof the manual:
Imperial Range
Imperial Catering
Posted on Feb 02, 2009
  • 2 more comments
  • Ginko
    Ginko Feb 02, 2009
    I can fix regular ranges, but I do not have much experience in catering equipment, I guess you cannot have such a range working on temps inferior to 113, if that is the starting point.
    I will see if I can find something on this on the internet.
    In the meanwhile you can call Imperial at toll free number 800 343 7790 (US) , they should be able to tell you more on this.
  • Ginko
    Ginko Feb 02, 2009
    On spec sheet for IR6 ovens you get "Thermostat shall be adjustable from 150oF to 500oF. (66oC to 260oC)."
    I do not know if this responds to your model specs, but on all models you get a lower temp limit, and on your unit it must be 133 (50 C)
  • Ginko
    Ginko Feb 02, 2009
    Re: "The temp stays at 113 degrees in the off position"
    That is because the oven is not off, it is on standby.
    There should be a way to set the oven to go off completely instead of standby, unfortunately Imperial does not make available any manual apart brochures online.
    Try first cutting power (trip circuit breaker or unplug cord), and waiting five minutes.
    This will reset the unit to factory settings, even if standby mode can be a default setting for a catering unit like this.
    I will give a last try and search again.
    For sure there is a way to change the mode so that oven goes off completely when you do not need it.
  • Ginko
    Ginko Feb 02, 2009
    Hi there, I have found a user manual here, it says:
    "To turn off the oven completely turn both the termostat and power switch to 'off'' position.
    I am afraid that is the only way to turn the oven completely off, otherwise it will keep a standby temperature of 113 degrees, so that you do not have to re-ignite the oven each time.
    By the way, at minimum temp the oven should have a very low gas consumption, and not reingniting oven each time will prolong the life of your appliance.
Does anyone have any information on the Pine Ridge 500 wood stove? I'd like to know who the manufacturer is and what the EPA specs are.
PDF]installation and operation manual - Wood Pellet Stoves ...
Services) and the listing mark is Warnock Hersey. Testing: In accordance ... The assembled pellet stove model Advantage II-T C FS and. Advantage II-T C INS ...
[PDF]INSTRUCTION MANUAL - Ignite Dealer Portal - Regency ...
Tested by Warnock Hersey ... LISTED FACTORY BUILT FIREPLACE ACCESSORY HEARTH STOVE ... it is important that you read this manual throughout.
Nov 01, 2015 | Home
How do I adjust the door so it doesn't drop down to the floor when I open it to take food out?
make sure the hingew are tightly secured in position by the fasteners. If you have little mechanical experience get a mechanically minded person to assist.... I enjoy getting young people to fix things for me nowadays!!!
Aug 01, 2015 | Maytag Admiral LER3330AAW / LER3330AAZ /...
My Laser 30 went into power saver mode by itself and now I can't get it out of said mode, otherwise it's working well.
Sorry to hear you're having issues with your Toyo, first off do you have a manual for your stove? If not, you can download one online, I've included the link for your convenience.
Your Toyo has a series of control buttons across the top and/or the front, the "On/Off" button for the "Power Saver Mode" is located in the middle. You can turn the mode On or Off, though you actually WANT to utilize the Power Saver Mode. It's intended to prevent unnecessary ignitions on the stove, thereby lowering your electrical consumption as well as wear & tear on the stove. All you need to do is set a maximum and a minimum temperature and whenever the temperature is not within the parameters you've established the stove will then either ignite to heat the area to your pre--determined setting or shut off until the temperature is within the parameters you've established. If there is NO error code(s) showing, and the stove is running fine, then I would not be concerned. Though I do suggest you immediately download the manual, read it thoroughly, and when necessary use it to troubleshoot future issues.
I hope this helps you, good luck and stay warm!
North Pole, Alaska
Oct 09, 2014 | Rinnai Toyostove Direct Vent Heater: Laser...
I have bought a house in the UK containing a GD60 Gas Cooker from STOVES but there is no manual for it, and I would like to get one.
First of all, thank you very much for choosing FixYa today for your technical service needs.
Unfortunately, STOVES UK does not provide any online documentation to support their product after the sale. I looked everywhere on the internet but could not locate a copy of that manual for you.
I deeply apologize for not being able to provide the documentation you requested, but sometimes these things are simply not available anywhere online. In the future I would recommend sticking with major manufacturers who produce high quality products and provide better service and online support.
I hope we can assist you better next time.
Thank you and take care.
Feb 18, 2012 | Stoves Ovens
I dont know how to use the oven properly. when i need to bake or roast something i want to put in my own temperature, but there is no option for me to do that. when i turn on the stove all i have is the...
There should be a plus/minus sign OR a up/down arrow to adjust the temp.on the control/touch panel. The default setting is usually 350 and can adjusted up or down accordingly,the display starts at 120 and is supposed to rise as temp. increases.
The bigger issue though is to have it serviced and see why it doesnt rise above 200
Aug 04, 2011 | KitchenAid KEHU309 Stainless Steel Dual...
Anyone get the manual?
Hi There is a company that have all the reprint manuals and parts for you stove, if you visit this site maybe you could email them or find it online there
Im sure a manual is available
or here a second option
Jul 24, 2009 | Kitchen Ranges
Whirlpool Stove oven temperature not accurate
This unit has a calibration function which can compensate for temperature errors of +/-30 deg F. Hold the BAKE button for 4 seconds to enter this mode. Use the Temp UP/DN buttons to adjust the temperature offset. Push START to enter the new offset.
Also, the typical manual oven thermometers are notoriously inaccurate.
If this doesn't solve your problem, next items may be the temperature sensor or control board. If it is the control board we may be able to repair it for you at
Jul 13, 2009 | Kitchen Ranges
Yes you can make adjustments but you need a thermometer to set it accurately, you can buy them at Wal mart for 4 bucks. You will need to see if the thermal bulb is located in the flame, if not you will have to move it when it's cool. Some units have a screw to adjust the temperature some use a sliding tube to adjust the heat you will need to look at the stove to see. If you have the owners manual it will help, sometimes the thermal bulb goes bad and the temp control has to be replaced.
Jun 22, 2009 | Brown Stove Works 23 in. TL03-3 Gas...
Imperial IR-6-RG24 Elite Gas Kitchen Range Logo
81 people viewed this question
Top Imperial Kitchen Ranges Experts
Dan Webster
Dan Webster
Craig Butler
Craig Butler
Are you an Imperial Kitchen Range Expert? Answer questions, earn points and help others
