Question about JVC KD-AVX1 CD Player
Plobem with jvc kd-avx1 sirius ready!
The satellite radio tuner doesn¨t show on the diplay, because we don¨t know may be made a wrong connection with the satellite radio tuner, connecting the cd changer unstead of the head unit. appreciate all the opinion bring it to it!
SOURCE: kd-avx1
no take it back
Posted on Apr 13, 2007
SOURCE: JVC KD-AVX1 Sirius Just Quit
I had the same problem. My solution was easy, with the car off and deck off find the Sirius connect unit. When you do unplug the large connector. turn the deck on and off once. Then plug the siruis connect back in and turn on your deck. it should work then.
Posted on May 08, 2007
  • 6 Answers
SOURCE: getting reset 8
Be sure to check and make sure that your option output is selected to other, and not cd changer, and reset the unit.
Posted on Feb 06, 2008
  • 55 Answers
SOURCE: jvc kd-sh55 head unit
Have you tried pressing the "RESET" button on the stereo? I have a JVC unit in my car and the reset button is a tiny hole behind the detachable face. Take a pencil or a pen and insert the end into the tiny hole an hold for a few seconds. This will reset the stereo and you should be able to eject the CD as you normally would. If it's a mini-disc (8mm) you probably would have to take the unit apart and manually retrieve it - big hassle. Check the owner's manual to find out where the "RESET" button is if it is not behind the face. If you don't have the owner's manual, you can download one from jvc.com.. Hope this helps.
Posted on Aug 30, 2008
jimmo68
SOURCE: problem with jvc-avx1 car dvd player.
hi there . just connect the parking wire to a ground (negative).
Posted on Nov 30, 2008
Chrysler 200 convertable how to put pictures on radio
SiriusXM Connect Vehicle Tuner - Shop - SiriusXM Radio
https://shop.siriusxm.com/xm/ctl10600/cp49759/.../c...
Sirius Satellite RadioMy Account. I'm a Subscriber ... Image 1 SiriusXM Connect Vehicle Tuner · Image 2 ... Add Satellite Radio to any SiriusXM-Ready™ car stereo receiver. Connect ...
[PDF]User Guide - SiriusXM
www.siriusxm.com/.../pdf/SkyDock_UserGuide.pdf
Sirius Satellite RadioThe XM SkyDock incorporates an XM Satellite Radio Tun- er . A special .... image to match the XM SkyDock's .... found on the My Account screen (in Settings), ... Button: Tap to tag the current song and add it to your tagged song list . For.
Dec 10, 2015 | 2011 Chrysler 200
How do i set up the sirius xm
This radio is SiriusXM *READY*. You will need to purchase and install the *optional* SiriusXM-Connect Vehicle Tuner kit (tuner, antenna, cables, hardware) specific to your radio - linked below:
SiriusXM Tuner:
SiriusXM SXV300v1 Connect Vehicle Tuner Kit for Satellite Radio
Manual (.pdf):
http://www.clarion.com/us/en/pdf/CZ702_Manual.pdf
Jun 11, 2015 | Clarion CZ702 Car CD/MP3 Player - 76 W RMS...
Xm check atenna connection
If you are getting the same "check antenna" message with two different antennas, it is likely that the tuner itself is the problem. You can get just the mini tuner here:
http://www.tss-radio.com/products/xm-mini-tuner-replacement-home-dock
As far as the two plug connection, there are adapters available. Its likely a dual fakra connection, though I don't know for sure. At any rate, this is one adapter available. (I would call to confirm)
http://www.tss-radio.com/products/sirius-dual-to-single-antenna-adapter
Jun 27, 2012 | XM Radio XM Direct 2 Mini-Tuner Car Kit...
How do I display the radio ID number, so that I can listen to Satellite radio?
Verify if the radio is "Satellite ready" or if it comes with the remote tuner unit. I believe you have to buy a separate tuner add-on and antenna in order to activate the satellite circuitry - THEN it will show you a radio ID. I think ONLY the Alpine comes with the tuner. I would call Crutchfield and they can tell you what all you need with that tuner to make it work with the satellite radio.
Jan 14, 2012 | Panasonic CQ-DF783U CD Player
How do I add sirius radio to my sat radio ready jvc stereo model KD-AVX11
The frst the part you will need is the (JVC KSS-RA100) this part lets you control the Sirius tuner from the Jvc radio. The next part is the tuner for Sirius this part number is (SIRIUS SC-C1)
Jul 30, 2011 | JVC Car Audio & Video
I have a 625 dual tuner from Dish. When I do a check switch it shows that I have signals on both satellites on tuner 1 but tuner 2 has none. When I disconnect the cables from the receiver and reconnect...
Hi, Mary with Dish Network Customer Service, I will be happy to assist with this. This receiver needs to have a Separator (splitter) that has one coax cable coming from the Satellite into the single side and then two cables out, which connect to the receiver box. The Separator is marked with a SAT1 & SAT2. They will connect up to SAT1 & SAT2 on the receiver box itself. If you are using a different typr splitter, it is probably not rated for the splitting of the Satellite feed. I hope this helps you, if not feel free to contact me.
Jan 01, 2011 | DISH Network DVR-625 DTV Receiver /...
Listening to sirius satellite radio and "reset 8" message flashed
The Sirius tuner is bad. 1000's were sold and 1000's have been replaced! The new model will work with your unit and does not fail, it's manufactured by DEI not Audiovox. Or, you can check Ebay for a rebuilt tuner for around 40-50 that has the problem fixed and corrected. Hope this helps.
Sep 26, 2009 | JVC KD-G230 CD Player
I have a Siriusconnect Home Tuner and an XM Ready Receiver. Will they work together? What do I need to make the connection from the 8-pin mini DIN on the Tuner to the XM connector on my Denon AVR-587?
Not gonna work, sorry to say. You need the little two-piece "XM Ready" tuner unit (with antenna) to plug into your XM Ready receiver. Sell the Sirius Connect Home Tuner and buy the XM unit. XM unit still available at some Best Buy stores.
Sep 19, 2009 | Sirius Satellite Radio Receiver
Rosen navigation system in my 2009 VW GLI w/no satellite radio??
Usually when it says sat ready, it means it is ready to control a satellite tuner that will have to be added on. I work on alot of cars that are satellite ready, and sell alot of radios that are satellite ready, and the all need a separate tuner for satellite. And yes, for the price, you would think it was included.
Aug 14, 2009 | Car Audio & Video
No Sirius function available.
I have the same problem. When scrolling through the source options, the display goes from tuner-cd-aux and back to tuner...no sat. radio. need help.
May 29, 2009 | Clarion XMD3
JVC KD-AVX1 CD Player Logo
149 people viewed this question
Top JVC Car Audio & Video Experts
xxxxxx xxx
Are you a JVC Car Audio and Video Expert? Answer questions, earn points and help others
