Question about Sony VAIO PCG-K23 Notebook
Dim LCD display
I have a Sony Vaio PCG-K23 (PCG-9RFL). The LCD display is very dim. I have tried using the hotkeys to brighten the display with no luck. Could this be the inverter or the display itself. Any suggestions you have would be very much appreciated!
Thank you,
B. Cowling
CEI
410-274-4384
  • 152 Answers
Ccfl tube goes down or inverter cirucuit is fail
need to replace it
Posted on Feb 02, 2009
I have sony vaio vpceh25fd ,my screen was broken but was still working before i replaced it to a new one,after replasing the screen i am having a very dim display.even i tried the previous (broken lcd) its...
The dim display could be caused by a faulty inverter. The inverter supplies high voltage to the CCFL lamp that provides the back light to the LCD screen.
If your laptop appears to boot up and the hard disk LED flashes, then the problem is probably a back light fault. This can be a faulty inverter or a faulty CCFL lamp. Please click on this link and follow my instructions to identify the fault and possible fix :- http://www.fixya.com/support/r3598095-faulty_laptop_lcd_screen
Apr 14, 2013 | Computers & Internet
SONY VAIO PCG-61611l has a very dim screen
Normally, this is in part due to you not replacing it with what should've been an LCD. The reason why it's dim is because those diodes are not getting the required voltage to emit as it should. LCD's work under a different concept where crystals use the light modulating properties of liquid crystals. Liquid crystals do not emit light directly as LED's, because it stand for light emitting diodes.
Mar 25, 2013 | Computers & Internet
SONY VAIO PCG-61813M
I have the same problem, It works at an external display and the lcd and lcd cable work on another laptop.
The problem is that i have a sony vaio and it has no inverter, or at least i dont see one like an hp laptop for example. i tried to switch image from external monitor to lcd and it doesnt work. i tried everything. dont know what to do more, Hope you can help.
I have a Sony Vaio pcg-61813M.
Thanks.
Aug 29, 2012 | Sony VAIO Laptop Intel Core i3 Processor...
The lcd display has become very dim on my sony dreammachine icf-c218 how do i brighten it up?
There is no adjustment on this model. Mine was too dim and the only way I was able to make the display brighter was by removing the front lens. I then used a nail and a knife to scratch and cut (from inside) the rectangular area of the lens in front of the display. It looked nice afterwards. If you need it dimmer, I would recommend putting a small shaded sheet behind the lens like the ones used for tinting car windows instead.
Dec 02, 2011 | Audio Players & Recorders
MY N5030 LAP LCD IS IN LAW LIGHT.CAN AS A SHADOW. I CONECTED TO EXTERNAL MONITOR IT WORKING BUT LAP DISPLY STILL AS
look khal sometimes most netbooks have a "hotkey" sequence to dim or brighten the screen on mine its Fn/F4 or Fn/F3 try this first or goto you manufacturers site and find the exact sequence of "Hotkeys" [remember Fn/F5 toggles between screen and monitor]!!
Good luck
Davey snake!
Jul 20, 2011 | Computers & Internet
Driver bright control for vaio pcg-k33
I understand that you are referring to the Function keys on the computer. To resolve the issue download and install the Hotkey Utility from the below link:
http://esupport.sony.com/CA/perl/swu-download.pl?mdl=PCGK33&upd_id=1704&os_id=7
Please get back to me for any clarifications.
Thanks!!!!
Jan 03, 2011 | Sony VAIO PCG-K33 Notebook
LCD problem with Sony DCR-SR200
O& ..)& '''ho 7... 007 I see his movies are old and so is your battery. Break down and buy a new and charge it to full capacity replace the battery
Buy the heavy duty isf there is. and when you store it when not in use ut the battery in the freezer. When you want it thaw it out and put a charge to it for a good practice and install
Jul 27, 2009 | Sony Handycam DCR-SR200 Camcorder
My sony vaio vgn-n365e screen is Dim
The fault could be a faulty CCFL lamp or inverter.
To determine if you have a LCD screen, inverter or video card problem, read this and follow these instructions.
Defective CCFL backlight, it may have the following symptom: Screen flashs on red/pink and off. Picture stays on in red and slowly be come normal. Picture flickering with dim display or appear black. Picture flickering on and off. All these symptoms indicate that the LCD backlight lamp (CCFL Lamp) has reached the end of the life and all you need to do is replacing the CCFL lamp.
Connect an external monitor to your laptop and power the monitor up first then the laptop, if you see the normal Windows images then the video card and laptop is OK and the problem is definitely the backlight. Dim image and/or dark display on the laptop's LCD screen indicates a faulty LCD backlight and it could be the inverter that supplies high voltage to the CCFL lamp or it is the CCLF lamp is nearly burnt out or burnt out, most likely this is the case.
The inverter can be replaced easily but the CCLF lamp is more time consuming and requires soldering skills.
Check out
www.lcdparts.net
for parts, repair service and DIY info.
Jul 24, 2009 | Sony VAIO PCG-K23 Notebook
Sony VAIO PCG-K23 Notebook Logo
526 people viewed this question
Top Sony Computers & Internet Experts
Alun Cox
Are you a Sony Computer and Internet Expert? Answer questions, earn points and help others
