Question about Water Heaters
Worcester bosch greenstar 25Si?30Si pressure gauge showing high
Gauge normally showsreading between 1-2 which i take to be correct. however when the heating was switched on today the gauge showed nearly 3. it started to drop after heating was switched off.
    Problem Solver:
  • 5 Answers
A couple of things , is your filling loop disconected ? , and are all your radiators blead from air, have you got a high point where the air can get stuck in system say pipes going into roof etc you may need to fit a air release valve in line at highest point to remove the air from system , your boiler should be around 1.5 bar running preasure average setting . if you are constanly filling with water you could be exceeding the pressure valve limet which releases pressure from system this could be faulty ?
Posted on Feb 05, 2009
Boiler fires for short time only then seems to switch off. we have tried over ride button but it only works for few seconds
Posted on Jan 08, 2010
How do you work the heating on a Worcester bosch 35cdi boiler
search for worcester bosch 35 cdi manual choose Greenstar CDI & download the pdf instructions
Dec 31, 2014 | Bosch Water Heaters
Worcester Boiler Greenstar 15Ri - The blue neon light is flashing - what does this mean?
http://www.worcester-bosch.co.uk/homeowner/literature/gas-boiler-literature/greenstar-15ri-literature. Hope this helps :)
Sep 19, 2014 | Water Heaters
Greenstar 30si
this is your safety valve letting by first try and check ur pressure bladder shud b 28lbs squr inch if it isnt pump up to 28 what happens if the bladder has no pressure then the water has no were to go but out through to pipe water expands when hot and thats why un have to top up the other problm is safty valve worn out needind replacment hope this helps u Susan
Sep 21, 2013 | Water Heaters
I have low pressure on my Worcester Bosch 30si but I can't remember how to fill it up, please can you help?
connect filling loop from cold main too heating flow or return you,ll find teed pressure system by short quick flicks at the valve on the cold supply best of luck
Nov 29, 2009 | Water Heaters
Pressure shows 0 psi greenstar 30si
open the water feed by raing the brass flat lever to 12 psi
Aug 02, 2009 | Water Heaters
Water Heaters Logo
3,528 people viewed this question
Top Water Heaters Experts
Donni Steen
Paul Carew
Are you a Water Heater Expert? Answer questions, earn points and help others
