Question about Canon i850 InkJet Photo Printer
Cyan not printing,
I have cleaned the heads,air cleaned the printer itself, uninstalled, then reinstalled the printer, still doesn't print the cyan color. after all this now when I print document with only black ink, the ink is wet. never had this problem before.
Thanks for any help u can give me
  • 2 more comments
  • supergrams3 Feb 03, 2009
    windows xp, 3rd.addition
  • supergrams3 Feb 05, 2009
    I am using "Windows XP, 3rd edition
    The Cyan had run out & it was maybe 2wk before I could get a new one. Not a refill, but a new purchased one.
  • ROD GANDY May 11, 2010
    THE COLOR CARTRIDGE WAS IT REFILL OR NEW PURCHASED ONE.
    I NEW SOME MORE INFO, WHAT VERSION OF WINDOWS ARE YOU USING
  • 1,602 Answers
PURCHASE A NEW CARTRADGE OF GO ONLINE
CANON 850i WILL NOT PRINT IN CYAN
SEE IF ANYONE ELSE HAS THAT PROBLEM AND HOW THEY SOVLED IT
ROD
Posted on Feb 04, 2009
Color mismatch and blurry/smudgy prints
Remove ink catridges and clean print head, shake inks and reinstall the inks, if problem persist, Uninstall the driver and reinstall. thats should help. Some time if the print head are dirty it prints multi color. You have to make sure the Head is Clean and install th inks properly.
Dec 10, 2012 | Epson Stylus Photo R1900 InkJet Printer
HP Officejet 6310 will not print cyan
The Cyan print head nozzle maybe blocked.
If deep cleaning does not fix it then you need a new print head.
The cost of a new print head is expensive and it maybe better to get a new printer.
Oct 15, 2012 | HP Officejet 6310 All-In-One InkJet...
My printer, prints all but cyan. I did a self test it shows there is "CYAN" 1%used" which is strange because, nothing is printing w/blues in it. :-( i tried rebooting, I tried CLEAN Print...
Call Lexmark support, might be a bad print head.
You received a replacement What from Lexmark that was broken????
Reinstalling the drivers won't hurt anything, do it.
Nov 06, 2011 | Lexmark Pro901 All-In-One Inkjet Printer
AFTER THE INK RUNNING OUT IN MY S305 I HAVE REPLACED ALL 4 CARTRIDGES TO FIND THE CYAN WILL NOT PRINT. REPLACED THE NEW CYAN CARTRIDGE WITH ANOTHER ONE AND STILL NOT PRINTING ANY BLUE.
In most cases the printer driver software can have errors while being in use or is shut down. So to reset remove your printer from the PC and uninstall the printer software. Now reinstall the printer software and then connect the Printer to be detected as a new hardware as it will be installed. Now check the printer properties to see the ink levels.
Activate head cleaning before a test is taken .
Jul 16, 2011 | Lexmark S305 IMPACT LEXS All-In-One...
It appears that the yellow print head on my Brother MFC240 printer is clogged. There is lots of ink in the cartridge, but it does not print yellow. It will print black, cyan and magenta. Where is the...
some solution.
ry to clean by properties of program on your computer.
then you try to print some text or image use yellow ink only..
but if it doesn't changed. try to reinstall the driver.
May 31, 2011 | Brother MFC 240C All-In-One InkJet Printer
Cyan ink worked until needed to replace that empty cartridge. Now, all colors print but Cyan. I have cleaned inks, blocked eye with tape, cleaned where cartridge goes with warm water (in those holes),...
First do not use cartrigde compatible or refill because you clogged the print head,is verry sensitive.If you try to clean the print head and nothing you need to replace the print head is the only solution,after replace the print head you print all the colors.
NOTE!!! After you replace the print head use only original cartridge brother !!!!
Apr 07, 2011 | Brother MFC-230c Printer
Hi, I'm trying to print in b&w. The printer says " no cartridge" although all four of the cartridges are in. It says "open scanner cover, then reinstall ink". If I lift the cover it then says "install...
Remove your printer from the PC and uninstall the printer software. Now reinstall the printer software and connect the Printer to be detected and installed. Check printer properties to see the ink levels.
Use head cleaning before a test is taken . It is possible that the head is not reacting to the need of the command , can be an issue with ink drying , can also be poor ink cartridge contacts, tighten the cartriges onto the slots.
Sep 30, 2010 | Brother MFC 210C All-In-One InkJet Printer
Suspected clogged blue ink tube
most of the time, the print head need to be replaced for your case... but there are cases whereby it's the ink cart that causes the ink clogged.. you can try replacing the cyan ink and do another round of cleaning.. but chances are slim...
May 24, 2010 | Brother DCP-120C All-In-One InkJet Printer
Lines in the print
Nozzle check perfect? No ink drop outside lines? Cyan lines is random position. Print blank pages. It is still appear cyan lines? If yes, it caused by waste ink at bottom plate. Print blank pages more, it will clean itself.
Jun 29, 2009 | Epson Stylus CX9400 Photo Printer
IP4300 only recognizes magenta OR cyan
1. Get compressed air
2. Run Printhead under HOT water, do not worry about contacts getting slightly wet.
3. Blow compressed air with straw attachment into screens where the cartridge nozzle sits on printhead. then let it sit and dry.
4. reinstall print test page
5. if this fails open paint/photoshop and print a page of the color that is not printing correctly. rinse and repeat until colors flow freely.
I have several ip4300s and I have yet to give up the ghost on a printer with a clog ujsing this method.
Jan 04, 2009 | Canon PIXMA iP4300 InkJet Photo Printer
Canon i850 InkJet Photo Printer Logo
old marine
old marine
