Question about HP OfficeJet 6110 All-In-One InkJet Printer
I need the scanner to scan in a Word Document.
I don't see anywhere for that option. can you help?
    President:
  • 2,692 Answers
I am a little confused abotu you question Scanners copy what is there(Millions of dots on a page) and can save what they find as a picture. Nothing more.
Posted on Feb 03, 2009
Dont know how to scan a document
The first thing that you must do is make sure that the device is already installed to your computer. Insert the document to be scanned on the scanner. Double click the icon of your scanner and on the option menu click scan. After the scanning process, open the My Picture folder of your computer and locate the image file.
Sep 02, 2011 | HP Deskjet F4140 All-In-One InkJet Printer
I have a F2280 that scans but don't know how to do it. can you help?
Hi
Open your control penal and select the scanner and camera the new window is come put the your document in your scanner and select the next first option is file name and second where u want to save select the destination and click next your scanner scan your document wait second of earth and finish
your document is scan
good luck
May 05, 2011 | HP Office Equipment & Supplies
I get a Staple Detect error each time I try to scan a page. I've checked all of the rollers; they are fine. There are no staples anywhere in the picture. Can I turn Staple Detection off?
I presume you are using CpaturePerfect3 Scanning software. There is an option to stop checking of 'staples'.
In Canon 9080C staples are NOT detected by any metal detector! You'd notice a set of LEDs on one side and a set of sensors on the opposite side of the scanner wall, just above the paper tray. Incase there is a document thats stapled, while one sheet is going in, the other sheet will get lifted because of staple. Thus when there is obstruction in the LED sensor, it is presumed to be a stapled document. Conversely, even if a document is bent enough to block the sensors, the scanner assumes it as a stapled document. Ensure your documents are fairly flat.
S. Mohan, Chennai, India
Dec 30, 2010 | Canon DR-9080C Path-Through Scanner
I need help scanning a document on my hp photosmart C5200 printer/scanner. I can't find the option in menu to scan and save as document
scan by application.On your computer go to Microsoft word, go to insert then picture, from scanner or camera, choose the type of scanner you are using. Custom insert. The scanner scans your document
Sep 03, 2010 | Office Equipment & Supplies
How can I scan a document then print it with larger print?
You can scan a document or photo or negative film etc.. using a scanner, there a many types of scanners which you can choose as per your requirement. There are dedicated scanners, all in one integrated scanners, or two in one like that.. but if you need it for your professional use or daily use, it's better to get a dedicated scanner not "all in one" since with all in one if the copier fails or fax fails, the scanner will also fail because they are related and built-in integrated.
The process of scanning a document is as follows;
  • > Place the document on the scanner's flatbed.
  • > Press scan button or scan using the integrated software from the computer.
  • > Customize the scan settings/quality.
  • > Save the scanned documents.
Printing a document to a larger size is different, you can use photo editors like photoshop, paint.net etc..where you can changed the resolution as well as the size of the image. It's best to change the size or resolution before you give the print command. Or you can also change the print size with the paper size or print size.
If you still need more help, please let me know with more details. I am ready to assist you.
Good luck.
Thanks for using FixYa.
Jul 04, 2010 | Computers & Internet
My hp f4400 all in one scan light not working it is new and don't kntow how to get it to scan
For scan the document you need to open the paint.
click on "start/all programs/accessories/paint".
click on the file and select the option scanner and camera wizard . after that you will get a option to scac, click on it and put the document on the scanner tray which you want to scan, once when scan get complete, click on file and save as option to save the scan document.
Nov 09, 2009 | HP OfficeJet 6210 All-In-One InkJet...
How do I scan a document using the hp psc 1315 and then find it on my computer? I press the scan button and it seems to scan, but then I can't find the newly-scanned document anywhere. There needs to be an...
The scan button is setup to push the scan to an application, if you uninstalled the HP scanning software, it isn't going to go anywhere. If you didn't, it will put it into your documents folder under "My Pictures" in an HP created folder.
That said, you can also go into any application, like Word. then click "Insert > Picture > From Scanner or Camera" and carry the image in directly.
Oct 01, 2009 | HP PSC 1315 All-In-One InkJet Printer
CanoScan LiDE 25 Flatbed Scanner setting problems
You can help her by turning on the "Remote Assistance" in Windows XP...this will allow you to control her mouse and computer from anywhere in the world
Jun 11, 2009 | Canon LIDE20 Flatbed Scanner
Scan document
Is very hard to alter a scanned document if you are not sure how to, especially without the help of an editing software. but try to scan it to text if you have Word it sure will help, scan it to Word and after is saved you can type or erase certain portions of the document, browse trough the tools tab to search for the option that will suit better the type of work you want to do on your document. If you have Adobe Acrobat Professional this is very easy to do, you only have to scan the document on Adobe format and using the advanced editing tool.
Dec 06, 2007 | Canon CanoScan 4200F Flatbed Scanner
HP OfficeJet 6110 All-In-One InkJet Printer Logo
16 people viewed this question
Seeker5211
Seeker5211
