Question about Compaq Presario Notebook
Screen is jumping on my compaq what could be the problem?
My screen jumps, we had the connections checked in case one might have been loose but it has not correctec the problem.Please help me with a direction to go in.
  • 2,404 Answers
Its either going to be the screen or the cable going from the screen to the motherboard is bad. My suggestion if your notebook is under warranty, try to get the screen and the cable replaced. That way if the problem still exists then you know for sure its a motherboard problem. Hope this helps.
Posted on Feb 02, 2009
  • awthehellwit May 21, 2011
    I've got the same problem. I'd like to try to take mine apart and reseat the cable myself.
My car starts with a jump but not on its own ,batteries good alternator good?
Jump start only adds extra speed to starter and provides extra amps, so think bad coil or module. Check for nice blue fat spark at plugs when not jumped and compare when jumped.
Feb 20, 2015 | 1996 Chrysler Sebring
Ford f250 starts but after the 3 time I have to get a jump start
Check for loose ground wires on your engine. Many nowdays have multiple grounds and if certain ones get loose, it will cause your exact symptoms. I had a vehicle do this...and found a loose ground wire hanging beside the A/C compressor on a 4Runner. I re-connected it, and it worked like new.
Sep 10, 2014 | Cars & Trucks
Jumpy splash screen
There are a few reasons why? One the video card is going on the mother board. A loose connection that requires professional attention to check or make sure that the cabling is correct, which requires taking the laptop apart where the power button is located near there as well. BIOS could be going bad or need an update. I would start with inspecting the cable going to the monitor first to make sure it is solid. The laptop I assume works great once it is booted up and running. If this is not the case and you still getting periodic splash screen jumping then it would be the video card. This is why it is a great idea to purchase a laptop cooling fan while in use. John
Feb 06, 2012 | Dell Inspiron M5030 Laptop
1992 pontaic sunbird GT 3.1L V6 when I turn the ignition key to the position just before crank, everything seems normal for about 3 seconds, battery gauge shows full charge, gauges do their little...
SOUND LIKE DEAD BATTERY.HAVE BATTERY CHECKED AND REPLACED.MAKE SURE ALTERNATOR CHARGING BATTERY.WITH ENGINE IDLING BATTERY VOLTAGE OUTPUT AT BATTERY SHOULD BE 13.5 - 14.5 VOLTS. IF NOT CHECK ALTERNATOR BATTERY FEED WIRE AND VOLTAGE REGULATOR WIRES FOR DAMAGE OR LOOSE CONNECTIONS,CHECK ALTERNATOR FUSE AND MAKE SURE ALTERNATOR DRIVE BELT NOT LOOSE SLIPPING OR BROKEN.
Jun 26, 2011 | Pontiac Sunbird Cars & Trucks
Screen keeps jumping up and down
hi
you have to check you screen i thing you have some loose connection of screen may be some cable is loose
Jul 23, 2010 | Toshiba Computers & Internet
My laptop screen wont stop jumping.
Nx6310, that is retired PC, now. too old.... NO OS stated.
old square screen 4:5 PC, as old as 2006 , and old as windows2000 and OMG FREEDOS. sold like that. 110 years old in dog years. !!!
PC = DOGS. a fare relationship,
FAST ANSWER:
the screen is bad, lines = bad.
if the lines change with twists of screen bezel or angle.
the screen is bad, or cable inside fell loose to it.
in most cases, (insides not messed with by kids) the screen is bad
the screen costs 2 to 4 times more that the PC is worth working
and 10times dead. or bad.
why not go to Goodwill , pick out a $20 PC with a bottom COA
tag W7 and newer, with wide screen. easy
here is cheap PC page just for that idea
http://pcdied.com/cheaper.html
we can never tell anyone how they can fix it.
your skills or tools are unknown..,,
this PC is about to land in the DEAD POOL,
HP drops support after 10 years, (i think from last one made not first)
your support page is here.
https://support.hp.com/us-en/product/hp-compaq-nx6310-notebook-pc/1839143/manuals
Jul 08, 2017 | HP Computers & Internet
It did not jump start. unlike other ATX power packs that can jump start by bridging the green cable with the black cable. please give me directives on how to jump start it.
Compaqs have a different power supply compared to other computers. Compaq power supplys have 24-pin connectors; and if this is the case with yours, try bridging the gray cable to the ground (black) and see if that starts up.
Nov 16, 2009 | Compaq Presario 5005 (470014-507) PC...
1998 ford f250 brake lights and turn signals quit working checked all fuses in cab and under hood center brake light works
Check for a broken wire or loose connection at the multifunction switch. This can occur especially often if you use tilt steering. there is a few screws under the steering column shroud, unscrew the tilt wheel knob, you may vice grips to get it to unscrew. remove the shroud and check wiring and connections, remove the multifunction switch and make sure there are no wires loose in the connectors. If you have a wiring diagram you can jump the circuits at the connector, if no loose anything and you get lights to go on by jumping the switch, replace the multifunction switch (that's the lever on the left of the steering wheel, in case you were wondering)
Aug 04, 2009 | 1994 Ford F350 Crew Cab
Have 92 fuel injected mazda pick-up that won't start
your starter is dragging. you may need to replace the starter.
Feb 03, 2009 | 1988 Mazda B2200
COMPAQ EVO N610c MOUSE JUMPS
try reseating the keyboard and the mouse cables.
Nov 20, 2007 | Compaq Evo N610C Notebook
Compaq Presario Notebook Logo
77 people viewed this question
Top Compaq Computers & Internet Experts
Alun Cox
Abhinandan  Patil
Abhinandan Patil
Are you a Compaq Computer and Internet Expert? Answer questions, earn points and help others
