Question about Epson LQ-590 Matrix Printer
My printer stops printing
I own an Epson LQ590 printer. When I print something, it is very slow and then it stops and all of the lights (paper out,Pause,Tear off bin,Font light, and Pitch light) all blink at the same time. The manuel says to turn it off and wait a few minutes. This does not correct the problem. Any ideas?
Thanks,Brian
I LOST MY SETUP DISC IS THERE A WEB SITE THAT I CAN DOWNLOAD A SETUP PROGRAM THANKS SOCKSQUATCH
Posted on Jun 05, 2009
  • Epson Master
  • 5,568 Answers
I don't know how many hours your Epson has behind it but several printers in this series have some power supply problems relating to service hours and the decay of certain capacitors in the supply. Finding ones that need replacement requires the availability of a capacitance meter with DF (Dissipation Factor) measurement capabilities. Sometimes, a failed electrolytic will deposit some chemicals on the board around its base.
Posted on Feb 06, 2009
My epson office tx600fw printer is very slow since I start using Windows 8.1 how can I restore its original speed
Steps to Troubleshoot Epson Printer Slow-to-Print Problem?
Learn to troubleshoot Epson Printer Slow-to-Print Problem as not all printers are created equal. Print speed may vary depending on system configuration, print mode and document complexity. Processing time on the computer system is not included in the print speed. The several factors where printing is slow are mentioned below:
    ·Printer driver settings
    ·Size of the data being sent to printer
    ·Windows spooling error You can also get in touch with Epson Printer Technical Support for further query or simply follow the steps to troubleshoot the slow-print issue.
    Steps to fix Epson Printer Slow-to-print issue:
    Step1: Observe the data cable
    Check whether the data cable is less than 1.8 meters in length and is connected directly to computer system. Use of long cable and connecting through third party such as USB hub can cause communication and print delays.
    Step2: Paper type
    Check that paper type you have selected in the printer driver matches the paper loaded in the printer and selected paper print is also appropriate
    Step3: Some general tips
    Click on icon shown for general information on how to remedy slow printing
    Step4: High Speed enabled
    Check for high speed if it is enabled in the printer driver. Depending on the driver the setting may only be available on certain quality and paper selections.
    Step5: Enable High Speed
    Open the printer driver from printers, printer and faxes or Devices and Printers folder and check whether the high speed is enabled in speed and progress
    Step6: Other Settings
    Check for other settings as well in speed & progress for better printing speed
    Step7: Spool folder
    Create new folder of spool on the hard drive and point the driver to it
    Step8: Carry a test
    Print a test page form general tab of your Epson driver
    Step9: Perform
    If printing is still slow try reducing the size of the data sent to printer
    You still have doubts to execute the above mentioned steps you can contact via Epson Printer Customer Support Phone Number USA Toll-Free 1-800-213-8289 UK @+44-800-046-5291(toll-free) to receive immediate and instant solution. The trained technicians are present 24*7 to deliver you high speed printing printer machine.
Epson Printer Customer Support Phone Number 18002138289 Help
Feb 11, 2015 | Epson Stylus Office Equipment & Supplies
Red light stays on and printer won't print
My C60 Epson Stylus printer is not printing. First of all the paper jammed, I pull the paper from the front and since then the catridge holder is not going to the middle to print. also the green light keepon flashing and the red light stays on. I need your help.
Jan 16, 2010 | Epson Stylus C60 InkJet Printer
Both the green light and red light on the top of printer are flashing. There is ink in the printer but it will not print
1 st clear all pending print jobs by In run window type services.msc and the go to print spooler option just stop and restart the service.
make sure there is no paper jam or out of paper massege coming.and when you inserting the paper not deep inside just insert and stop it when you feel any resistance .and try to print something. If it is print then well otherwise you have to show it service center
Nov 24, 2009 | Epson Stylus C46 InkJet Printer
Epson stylus color 3000 printer operate,pause paper out and media type all led lights flashes. What is the problem?
Make sure you inserting the paper not deep inside just insert and stop it when you feel any resistance .and try to print something. If it is print then well otherwise you have to show it service center.
Nov 21, 2009 | Epson Stylus Photo R1800 InkJet Printer
Printing too slow
hi it's normal to print slowly u can configure the printing settings to choose the printing qualtiy so if change ur printing quality to draft it will be faster but if u choose the resolution to be higher then the speed of printing will decrease and so on.
Jun 08, 2009 | Epson Stylus Multifunction Inkjet Printer/...
Light Flashing
print a test page and allign the cartridges from printer maintenance....
Aug 10, 2008 | Epson Stylus 880 InkJet Color Printer
Epson lq590
check if your LQ590 is set for manual feedor continuous feed. There is a toggle switch somewhere near the rubber rollers,there are symbols that will indicate for continuous paper printing or manual, select manual printing. Also in your print window,select printer properties, select manual printing. Yourprinter might be set up for sheet feeder or continuous paper printing. hope this helped.
Apr 23, 2008 | Epson LQ-590 Matrix Printer
Epson c88+
Ther is a obstruction in paper path, something has dropped down where paper goes in, or a fragment corner of a removed paper jam is in paper pathway
Nov 16, 2007 | Epson Stylus C88 InkJet Photo Printer
EPSON SYLUS C80 indicates "printer error: paper jam"
Epson has an interactive troubleshooting guide on their support site. http://www.epson.com/cgi-bin/Store/support/SupportIndex.jsp From the link above, choose your model printer. You will then be brought to the main page of your printer. Then, click on the "interactive help program" link under the Troubleshooting Guide section. Through this, you will be able to find an article describing what all the indicator lights mean and how to possibly resolve the issues.
Sep 21, 2006 | Epson Stylus C80 InkJet Printer
Epson LQ-590 Matrix Printer Logo
399 people viewed this question
Top Epson Office Equipment & Supplies Experts
Alun Cox
Are you an Epson Office Equipment and Supply Expert? Answer questions, earn points and help others
