Question about Recoton Advent Advent DV1418A 14 in. TV/DVD Combo
Broken cable connector
Someone pulled on the tv cable connected to the back of the tv/dvd combo and pulled the connector from the back of the tv. Is this a cheap fix and worth the trouble?
  • jsprague Feb 02, 2009
    Thanks banger. I took the back off with thoughts of resoldering the connector back on, but found that it's part of a little sealed modular unit that will need to be replaced. Sounds like it will be worth the fix.
    Genius:
  • 1,199 Answers
Yes this is a cheap fix that should only cost between 15.00 and 25.00 US if you take the TV in to be repaired! dont have them come to your house as it will cost much more!!this can be fixed in a few minites so dont let them take advantage of you!
Please rate my response to your question!
Posted on Feb 02, 2009
Sanyo TV connect to cable box connect DVD player
If your DVD/VCR combo player has three RCA connectors (yellow, red, and white), you can connect them to the corresponding inputs on the front of your TV.
Dec 29, 2012 | Sanyo Televison & Video
I have a toshiba MD13n1 can I connect cable to the tv if so how to make tv search for cable channels
Hello
How your combo is connected with cable. Is it by a set top box [converter] of direltly connected cable to its antenna socket?. Provide me details about how your combo is connected to cable? OK.
Sep 25, 2011 | Toshiba MD13N1 14 in. TV/DVD Combo
Phillips dvdplayervideorecorder connect w/zinwell converter box
First off get the TV on the right channel. It will either be ch3 or ch4. If you are using a cable box the dvd/vcr combo will have to be on ch3 or ch4 as well. OK, Make sure the input connector on the combo is hooked to the output connector of the cable box and the output connector of the combo is hooked to the input connector of the tv. Deal with one part at a time. First hook the combo to the tv and get the tv on the right channel (ch3 or ch4) so that you can see a pre-recorded dvd or video play. Then you will know what channel the tv is supposed to be on. When you find it don't bother the tv channel any more. Stop the dvd or video and hook up the cable box and turn on the cable box and set the box to a known good channel. Now put the combo on ch3 or ch4 with the combo's channel selector buttons until you see the cable box playing on the tv (remember you already set up the tv channel). Change channels on the box but don't bother the channels on the tv or combo anymore. You can put the box on whatever channel you want. The box will be your channel selector. I certainly hope that this helps. I know it can be confusing but don't give up. Just remember that the tv and combo have to always be on ch3 or ch4 (which ever one you found before). Good luck and thanks.
Nov 01, 2009 | Televison & Video
Broken connector, Panasonic PV-DF2004 20 in. TV/VCR/DVD Combo
its solder internally on the board.call the local tv repair person,.they have this spare second hand connectors and will get easily replaced.
Mar 30, 2009 | Panasonic PV-DF2004 20 in. TV/VCR/DVD...
Ant/cable hole on back of set looks broken
You are going have to soldered a new coax connector into the tuner, which is not an easy thing to do. It would be a lot easier just to replace the tuner. Check with Andrews Electronics, and get someone knowlegeable in electronics to help you with the soldering.
Sep 08, 2008 | RCA B27TF680 27 in. TV/VCR/DVD Combo
Cable connection
Just go to the dollar store buy new cable connector adapter it fits on end of cable so you can plug in & out / without breaking IF connector on tuner.
Aug 26, 2008 | Toshiba MD9DM3 9 in. TV/DVD Combo
Hook-up
first you do connect cable to your > combo VCR / DVD player & recorder then connect to > to your TV:
cable coax output or if that cable have video/audio ouput is going to INPUT >to combo VCR / DVD player video / audio output is going to INPUT > to TV,.that's the time you can record and playback;
click below for more information in hooking up:
DVD Players/Recorders: Home Theater Setup, Installation & Hook Up ...If i have helped,please click fixya,it is the only way i get paid for my work ,also please consider leaving feedback...
Good luck ,and Thank you in advance:
Jul 15, 2008 | Televison & Video
Connecting VCR/DVD combo
If you are able to you can connect to the RF connector (F Type Conncetor) on the TV. This should work. The layout is from the VCR (RF to TV) to the TV antenna F type connector from your Cable box to the Antenna in of the VCR that way you have cable through the VCR, and access to you VCR and DVD all controlled by the Cable and VCR remotes (set TV to Channel 3, set VCR to Channel 3) and use the Cable box as the tuner, Use the TV remote to switch between Cable and VCR inputs then use the VCR remote to switch between the VCR and DVD input.
Sep 20, 2007 | GE 25GT516 TV
Samsung CXD2512 TV/VCR Combo...Cannot hook up DVD player
We also don't have a remote. We hooked a DVD/VCR combo to the Samsung combo by attaching the cable from the cable line to the DVD player and an additional cable from DVD to TV and it used to work but after we lost the control, the DVD can only be listened to but not seen. The VHS from the DVD player works perfectly though.
When we had the remote (before connecting the other combo) we used line-in to see a DVD or VHS using the yellow red and white cables from the Samsung to the other player.
Sep 05, 2007 | Samsung CXD2512 25 in. Combo
Recoton Advent Advent DV1418A 14 in. TV/DVD Combo Logo
83 people viewed this question
Top Recoton Advent Televison & Video Experts
S. Gontko
Are you a Recoton Advent Televison and Video Expert? Answer questions, earn points and help others
