Question about Stanton Audio Players & Recorders
Stanton DJ pro 3000 heaphones only right headphone works?
Ive recently brought a pair of stanton headphones and i came to use them at college to work in cubase and only one of the headphones work i was going to send them back but i rang up first and they siad it would take over 4 weeks to repair so i decided to take them apart my self to which i have done to a certian extent... ive taken the actual cupa out and i cant find any broken wires or anything ive taken the head band apart which goes over your head and still no broken wires i cant seem to find anything wrong with them but still no sound
any help much apreciated thanks Josh
btw i'm advanced with electronics so any solderign or electronics required to be done wont be a problem. :)
Benimur
  • 6966 Answers
SOURCE: Left headphone does not work properly
Based on your post/description, it would seem that the cable of your head phone developed an open circuit somewhere. I would assume it is pretty near the headset itself. On most occasion, it is at the very entry point where the cable goes into the headset.
Normal repair would involve opening the side casing where the cable enters the headset, cutting the cable about 3 inches from entry point, strip exposing the three or 4 wires and reconnecting inside the stripped ends. Effectively what you have done is trim the cable a bit shorter eliminating hopefully the intermittent section.
Hope this be of help/idea, Post back how things turned out or should you need additional information.
Good l;uck and kind regards.
Posted on Oct 28, 2007
dj jagged
SOURCE: Repair of Technics DJ headphones
hi dj23 Ive have the same problem with mine but i was lucky to find the screws that undo the headphones their are just behind the right hand side headphone under the black bit that touches your ear theirs 3 screws hiding behind the coving with little arrow marking their they are but be very careful as you open it up as the wires are very bake able in side as their is not much room to get in their to fix them i am still trying to work out the best way to put a new wire on to them as the wire that comes with this headphones are not fixable as its unsleved and its the string in side the outer flex that stops the wires touching each other good luck it fixing them please let me know if you get any other info luck jagged
Posted on Jul 06, 2008
SOURCE: Windows Vista wont connect to these headphones
Try going to control panel->sounds->make the hands free audio the default.
Posted on Aug 09, 2008
SOURCE: Left Headphone not working
Most likely the wire has broken inside.
Posted on Aug 11, 2008
SOURCE: how to take apart
I figured out how to remove the headphone clip without causing cosmetic damage to the headphone casing. Unfortunately for me, this was after I had scratched up the casing already. Anyway, to avoid the cosmetic damage, use some kind of plastic tool, like a plastic spoon. After pulling off the headphone cushion, you will see the aforementioned 4 slots. Carefully slip the handle end of the spoon underneath one of the slots(not through them), and apply gentle pressure toward the center of the speaker. Do this for each of the 4 slots, and the tabs should easily come loose. Hope that helps.As for figuring out how to get the headphone to work, I'm waiting for that solution myself. The right headphone is out, but the left one works, none of the wires are loose, so the damage must be from my nephew being careless with the headset cable, and probably tugging on it once too often. Don't let your 15 year olds use your headsets, if they tend to be clumsy :)
Posted on Jan 11, 2009
Using a Motorola Rdu 2020 radio while using a regular pair of head phones I can only hear through one ear and the headphones work in other things
That radio does not have stereo. The heaphones are for stereo. If you look at the plug you will see three distinct areas of connetion for the sound. The tip, the midlle and the shell, The jack on the radio only has two inside it.
May 06, 2014 | Audio Players & Recorders
The pioneer djm 3000 ..the que bottons for headphones stay on when the mixer warms up. What to do .
gotta clean the silicone pad inside, you got carbon settling down there. Take it to a shop, is my best bet. Many ways to clean and restore these pads. Luck.
Oct 23, 2013 | Pioneer Pro DJ Mixer DJM 3000
Pair intex headphone with presario f700 laptop
Make sure the headphones work. Try the headphones in another computer.
Apr 27, 2012 | Computers & Internet
My connector is frozen on blinking red and blue. It will not connect with the head phones and go solid blue.
Have you tried doing the same with the headphones? If you hold the power button down on both the transmitter and heaphones (get them both flashing red and blue), they might pair.
Jul 15, 2010 | Logitech FreePulse Wireless Consumer...
The left ear wont work in stereo mode anymore, but the right ear still does
You may need to replace some parts. This site might help:http://www.metacafe.com/watch/1045725/how_to_solder_how_to_repair_headphones/
Oct 20, 2009 | Stanton DJ Pro 2000 Professional...
Left speaker doesn't work
Koss has a no questions asked guarantee on some of the Pro-4 series, all you pay is shipping. Call the repair department to check.
Apr 22, 2009 | Koss PRO-4AA Consumer Headphones
The headphone jacks on my mixer(Vestax PMC-06 Pro A)not working
did you try the headphone jack in the back? also is the cue fader crackling when you move it left and right? also check if the cue fader is plugged in. if none of the above, check with your warranty
Apr 14, 2009 | Vestax Pmc06proa Thin DJ Scratch Mixer...
110 people viewed this question
Top Stanton Audio Players & Recorders Experts
 Grubhead
Grubhead
Michial Gueffroy
Vito Vacirca Jr.
Are you a Stanton Audio Player and Recorder Expert? Answer questions, earn points and help others
