Question about Xerox WorkCentre PE16 All-In-One Laser Printer
Xerox Pro16fx - H4 Error Massage after power outtage
Xerox Pro16fx
  • 565 Answers
Http://www.support.xerox.com/SRVS/CGI-BIN/WEBCGI.EXE/,/?St=473,E=0000000001213816584,K=3906,Sxi=8,Case=obj(6116)
Posted on Feb 02, 2009
LSU error in XEROX workcentre pe220. What is the
R/sir,
I have a Fax machine of Xerox make model PE220.From BSNL line connectivity is allways out of order.I want to connect FIXED CELLUR TERMINAL (FCT).After conecting machine give dial tone for outgoing calls.and other end caller received a fax tone on their machine when they want to make a call on my machine.But printer is not printing after some LCD diplayed a massage communication error.Kindly GUIDE me for change in settings.
Thanks and regards
PK Jain
(Pennywise)
Dec 15, 2010 | Xerox WorkCentre PE220 Series
We have a workcenter pro 45. The new fuser module is on order, but the fuser model went out today. Is there a way to override the error until the new module arrives?
What error? H4? If so then you can get the reset procedure by searching my tip for this under "Sharp AL series H4"
Your Xerox XD100 is made by Sharp
Mar 19, 2010 | Xerox WorkCentre XD100 All-In-One Laser...
XEROX COPIER XC865 HAS AN H4 ERROR CODE HOW TO RESET AND WHAT DOES IT MEAN
H4Fuser temperature too low. Must be reset in diagnostics
Dec 18, 2009 | Xerox XC356 Copier
My copier ( xerox xc1040 ) hit a power surge . It
i speak a littlebeat english.
H4
00
Low Temp
you cant erease this code
in panel control
press (clear ) (exposure select key) (clear) (exposure select key) (14) & (start key)
14: Resets H3, H4,
Feb 28, 2009 | Xerox Office Equipment & Supplies
Xerox Workcentre Pro16fx - H4 error code after power outtage
You shut the machine off then on, Press Clear, auto,clear , auto, then when the lights go out, program it as if you were running 14 copies. press start and that should reset it.
Thats the redish pink clear button and the auto exposure button, Clear, Auto , clear auto, and the display goes blank , enter 14 and start. Dont ask me why I repeated that LOL
Feb 02, 2009 | Xerox WorkCentre XD100 All-In-One Laser...
Xerox pro 215, error H4 please help
H4 is a fuser error....not getting up to temperature.
Press [C] (Clear), press [Image Quality], press [C] (Clear) again, press [Image Quality] again.
If this doesn't bring it back to operations then the fuser lamp needs to be replaced.
Jan 17, 2009 | Xerox WorkCentre M20i All-In-One Laser...
Xerox Copier problem
Turn power on and within 4 sec.press the following sequence;clear,exposure,clear,exposure.The screen will go blank.Enter '1' and '4' then hit print.turn off. This will reset H4 if the fuser has no problems such as a bad fuser lamp or thermal fuse.And yes it,s worth fixing with the right guy working on it!
Jun 30, 2008 | Xerox Office Equipment & Supplies
My Xerox B/W Copier XC 1044
When was the fuser last replaced?
Jun 09, 2008 | Office Equipment & Supplies
What does j2 mean on a xerox work centre xd 100
Normal 0 false false false MicrosoftInternetExplorer4 /* Style Definitions */ table.MsoNormalTable {mso-style-name:"Table Normal"; mso-tstyle-rowband-size:0; mso-tstyle-colband-size:0; mso-style-noshow:yes; mso-style-parent:""; mso-padding-alt:0in 5.4pt 0in 5.4pt; mso-para-margin:0in; mso-para-margin-bottom:.0001pt; mso-pagination:widow-orphan; font-size:10.0pt; font-family:"Times New Roman"; mso-ansi-language:#0400; mso-fareast-language:#0400; mso-bidi-language:#0400;}H4 is a power failure code. To reset the errorplease press in the following order:
CLR - AUTO - CLR - AUTO
(this puts the unit in tech mode).
Enter 14 (as if asking for 14 copies)
Press "PRINT"
Your unit should reset itself and start working
Feb 19, 2008 | Xerox WorkCentre XD100 All-In-One Laser...
Xerox printer xd100
H4 is a power failure code. To reset the error please press in the following order: CLR - AUTO - CLR - AUTO (this puts the unit in tech mode). Enter 14 (as if asking for 14 copies) Press "PRINT" Your unit should reset itself and start working.
Sep 24, 2007 | Xerox WorkCentre XD100 All-In-One Laser...
Xerox WorkCentre PE16 All-In-One Laser Printer Logo
244 people viewed this question
Top Xerox Office Equipment & Supplies Experts
Michel
Xeroxrep
Level 1 Expert
Philip Hughes
Are you a Xerox Office Equipment and Supply Expert? Answer questions, earn points and help others
